Since 42.3 I have the following errors:
17-04-13 18:55:05 WARNING (Thread-7) [homeassistant.components.emulated_hue] Alexa type is deprecated and will be removed in a future version
17-04-13 18:55:06 ERROR (MainThread) [homeassistant.components.camera] Error while setting up platform synology
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 148, in _async_setup_platform
entity_platform.async_schedule_add_entities, discovery_info
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/camera/synology.py", line 86, in async_setup_platform
query_resp = yield from query_req.json(content_type=None)
File "/home/homeassistant/.homeassistant/deps/aiohttp/client_reqrep.py", line 697, in json
return loads(stripped.decode(encoding))
File "/usr/lib/python3.4/json/__init__.py", line 318, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
raise ValueError(errmsg("Expecting value", s, err.value)) from None
ValueError: Expecting value: line 1 column 1 (char 0)
Anybody can help?
THX in Advance
Peter
