Synology Cameras - cannot click to enlarge
My synology cameras work (display image in the lovelace UI) but when I click one to get the bigger image I get the popup with (eventually) a broken image icon.
I tried to go directly to the URL that Home Assistant uses, and when I do I get:
504: Gateway Timeout
I tried extending timeout in my config but no dice (and it’s also clearly not waiting that long).
I swear this used to work, and I feel like it broke after the last time I updated the Synology Surveillance Station.
Same problem here!!
Think you are right about the fact that it happened after updating Synology. Either that or it must have happened updating to one of the latest Hass.io versions.
Hope somebody can fix it!!
Read this:
“Synology has disabled the livestreaming API and the component is currently broken if you are using Surveillance Station version 8.2.3-5828.”
Bummer. Well at least that explains it.
Here is some interesting info. Make sure to read the entire thread, Hopefully it will be fixed:
