My Docker container needs port 80, but synology uses it for redirecting nginx. Is there any negative removing that redicrection?
What kicked this off is this error:
2020-04-17 21:20:50 ERROR (MainThread) [homeassistant.components.emulated_hue] Failed to create HTTP server at port 80: [Errno 98] error while attempting to bind on address ('192.168.XXX.XXX', 80): address in use
I have searched around and found some code I could use to remove the nginx redirect, I think… if I can trust the internet with these things I am not sure what I might lose by removing the nginx redirect… so I am nervous to do it.
On the other hand maybe there is another solution I can use that is less intrusive? Any help would be appreciated!
sed -i -e 's/80/81/' -e 's/443/444/' /usr/syno/share/nginx/server.mustache /usr/syno/share/nginx/DSM.mustache /usr/syno/share/nginx/WWWService.mustache
synoservicecfg --restart nginx
