since the last couple of months I performed all HA updates without any problems.
Now 0.88 keeps restarting the docker container in a loop. Back to 0.87.1 as temp solution.
I tried also to delete the container and install it fresh, but no fun.
Is anybody experiencing the same issues?
How could this be diagnosed or the problem been isolated?
- download Portainer in docker
- run image
- go http://IP:9000/ (IP is the IP of your nas)
- set portainer
- select image section
- delete all HA image
- back to the docker on synology
- download HA image again
still not working, but thank you very much for recommending Portainer. I had in total 35 HA images and 22 volumes. I have deleted everything including my current working HA version.
Falling back to 0.87.1 again.
- Read changlog and verify you make any required change
- Any Log output?
- Disable all component (check default install work)
- I’d default OK, enable component 1 by 1
Any of above may point your issue
Likely restart because it crashing and you set container restart=always
many thanks for advice. I am back online, after starting from scratch and enabling components 1 by 1.
Was more time consuming as I thougt, because all home matic components have been given new names. Worth doing it…
I believe the custom component hue sensor was causing the issue.
