Synology DSM + hass.io
Anyone that can update me on the current state of this combo? Docker possible? Virtual machine :slight_smile:
hassio has a built in docker container manager/supervisor. So it would be redundant to run a docker manager inside a docker container. Instead look into setting up the home assistant docker container and then setting up the docker containers for whatever else you want/need. This is what I do. I then have the containers linked as needed using ip:port notation in the component.
Synology DSM with docker containers:
  • let’s encrypt
  • home assistant
  • mqtt
  • mariadb
  • homebridge
  • dockermon
  • unifi
  • influxdb
  • grafana
