Have the problemm too with reintegration of DSM
Same problem I got a not loaded message on the integrations page
I’m setting up HA for the first time and getting Unexpected error
Edit: My problem was due to not logging in and configuring MFA.
Maybe this will help someone - had the same issue with configuring the integration - turned out my HA IP was on the Synology’s IP blocking list due to some failed logins. After removing the entry from the list everything worked like a charm.
Thank you SO MUCH!! Helped me and stopped me from messing things up
This solved my issue, it was being blocked by the Synology.
