Well, apart from the fact that HA won’t properly work a lot of the time, this forum software apparently has its issues too. No matter how many times I hit the format button, this is the best I get - and I also miss documentation on how to manually format my code properly. Which is also right in tune with the rest of the documentation. Cheers.
Error doing job: Future exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/synologydsm/sensor.py", line 107, in run_setup
for volume in config.get(CONF_VOLUMES, api.storage.volumes):
TypeError: 'NoneType' object is not iterable
I also got problems with DSM integration…was working fine before but now stopped i deleted integration I tried to added again but no luck… it seems that it can not find or connect to dsm… user should work i tested it on dsm.
the plex that is running on dsm connected great thru plex integration so IP should be ok.
Same on my side too.
All entities are now “unavailable”
I uninstall the integration and try to add it again ==> Impossible also, the system return “Unexpected Error”
All the fields are filled properly
User & Password are OK (when connecting directly to DSM)
IP address is pingable
Port is 5001 (SSL) (this is also how I access my DSM)
Has anyone come up with a solution to Synology being unavailable and then not being able to reinstall the integration. I keep getting “unexpected error” when I try to set it up.
