Synology: Frontend does not start due to eventlet
I have been trying to install HA onto my Synology DSM215j without luck thusfar. I followed the guide https://home-assistant.io/getting-started/installation-synology/ and https://community.home-assistant.io/t/error-starting-home-assistant-on-synology-for-first-time/917/3, but i get this in my logfile:
16-06-11 14:08:14 homeassistant.util.package: Attempting install of eventlet==0.19.0
16-06-11 14:08:24 homeassistant.bootstrap: Not initializing http because could not install dependency eventlet==0.19.0
16-06-11 14:08:24 homeassistant.bootstrap: Not initializing logbook because not all dependencies loaded: http
16-06-11 14:08:25 homeassistant.bootstrap: Not initializing api because not all dependencies loaded: http
16-06-11 14:08:25 homeassistant.bootstrap: Not initializing frontend because not all dependencies loaded: api
16-06-11 14:08:25 homeassistant.bootstrap: Not initializing history because not all dependencies loaded: http
I have tried to install this eventlet manually using
python3 -m pip install eventlet
but that fails to
creating build/temp.linux-armv7l-3.5 /usr/local/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-ccache-gcc -Wno-unused-result -Wsign-compare -Wunreachable-code -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -DOPENSSL_NO_SSL3 -DOPENSSL_NO_SSL2 -mhard-float -mfpu=vfpv3 -march=armv7-a -mcpu=cortex-a9 -mtune=cortex-a9 -DSYNO_MARVELL_ARMADA375 -DSYNOPLAT_F_ARMV7 -O2 -fno-diagnostics-show-caret -Wno-unused-local-typedefs -DBUILD_ARCH=32 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DSYNO_PLATFORM=MARVELL_ARMADA375 -g -DSDK_VER_MIN_REQUIRED=600 -pipe -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -D_FORTIFY_SOURCE=2 -O2 -Wno-unused-result -fPIC -I/volume1/@appstore/py3k/usr/local/include/python3.5m -c greenlet.c -o build/temp.linux-armv7l-3.5/greenlet.o unable to execute '/usr/local/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-ccache-gcc': No such file or directory error: command '/usr/local/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-ccache-gcc' failed with exit status 1
does somebody know how to solve this issue?
Same problem found on synology 212j, greenlet is failing…
https://github.com/home-assistant/home-assistant/issues/2261
this helped me forward…apparently the newest version of home assistant requires some component that needs to be compiled, and the synology doesnt have the required packages
I fixed it for now by installing the older version v0.20 of home assistant
