Problem adding DSM (Xpenology 6.2.1) via integrations.
I get succes login in log of DSM but HA integration tells me Failed to connect. Tried with and without ssl
same here
I’m on HA-Version core-2021.8.8, as mentioned in this thread it should be resolved with
021.8.7
Huh?? Im on 2021.10.1 today. So it had to be fixed long time ago
Remember Im on Xpenology.
I Have the same Problem. Since a few days im not able to fix it. It was running perfect and suddenly there where no cameras and the integration says. “Try to configure again”. But that doesnt work. So i deleted the integration . Now i can not connect again.
I Have
- Home Assistant 2022.9.1
- DS 415
- DSM 7.0.1-42218
Did any of you ever found a solution for this? I probably have the same issue.
I see the web request for /webapi/entry.cgi?api=SYNO.DSM.Info&version=2&method=getinfo&_sid=cut getting a timeout.
I see this in the apparmor.log when I do the request:
dmidecode: AppArmor: /dev/mem denied by profile /usr/sbin/dmidecode
dmidecode: AppArmor: /lib/openhook.so(+0xafb) [0x7f819b2ecafb]
dmidecode: AppArmor: /lib/openhook.so(open64+0x52) [0x7f819b2eccb2]
dmidecode: AppArmor: /usr/sbin/dmidecode() [0x409ff6]
dmidecode: AppArmor: /usr/sbin/dmidecode() [0x401731]
dmidecode: AppArmor: /lib/libc.so.6(__libc_start_main+0xf0) [0x7f819af67030]
dmidecode: AppArmor: /usr/sbin/dmidecode() [0x401835]
