Synology integration with Surveillance station/camera issues
The Synology integration in the configuration file setup was deprecated. I have started using the new integration.
This integration has been inconsistent on how it works.
After I setup the integration I verified my cameras work. All seemed well.
My NAS started being slow and I was unable to access the web interface. After much research I found that the connection between HA & Synology caused the CPU on my NAS to spike. I restarted HA and I was able to access the NAS. I have since then made sure I am on a current version of HA.
I am now having an issue where I setup the Synology integration and the cameras work. A few hours later they do not work and I get the entity not available. I have to delete the Synology integration and set it up again for the cameras to work. They only work for a short period before the same thing happens again.
What could be causing the issue?
Any help?
I setup the Synology configuration again, this time I unchecked the SSL & did not specify a port number.
The camera worked in HA for a while but after a few hours HA stopped responding and my Synology NAS CPU spiked and also is unresponsive.
