I have been struggling for 3 days trying to install appdaemon3 on synology nas with docker. I am using below to create the image:
sudo docker run --name=dash -itd -p 5050:5050 --restart=always -e HA_URL=“https://home.domain.com:8123” -e HA_KEY=“SECRET_KEY” -e DASH_URL=“https://home.domain.com:5050” --mount type=bind,source=/volume1/docker/dash/config,target=/conf --mount type=bind,source=/volume1/docker/hass/config/ssl,target=/certs -e EXTRA_CMD="-D DEBUG" acockburn/appdaemon:latest
I have enabled the debug and below is the log
cp: cannot stat ‘/usr/src/app/conf/apps.yaml.example’: No such file or directory
2018-04-06 06:37:39.563510 INFO AppDaemon Version 3.0.0 starting
2018-04-06 06:37:39.563804 INFO Configuration read from: /conf/appdaemon.yaml
2018-04-06 06:37:39.563941 DEBUG AppDaemon Section: None
2018-04-06 06:37:39.564062 DEBUG HADashboard Section: None
2018-04-06 06:37:39.564880 INFO AppDaemon: Starting Apps
2018-04-06 06:37:39.565236 DEBUG AppDaemon: Creating worker threads …
2018-04-06 06:37:39.568088 DEBUG AppDaemon: Done
2018-04-06 06:37:39.568608 DEBUG AppDaemon: Entering run()
2018-04-06 06:37:39.569041 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2018-04-06 06:37:39.697350 INFO AppDaemon: HASS: HASS Plugin Initializing
2018-04-06 06:37:39.697900 INFO AppDaemon: HASS: HASS Plugin initialization complete
2018-04-06 06:37:39.698227 DEBUG AppDaemon: Starting utility loop
2018-04-06 06:37:39.698459 INFO Starting Dashboards
2018-04-06 06:37:39.706318 INFO API is disabled
2018-04-06 06:37:39.706639 DEBUG Start Loop
2018-04-06 06:37:40.083677 DEBUG AppDaemon: Event type:ha_disconnected:
2018-04-06 06:37:40.083981 DEBUG AppDaemon: {}
2018-04-06 06:37:40.084288 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-04-06 06:37:40.084426 WARNING AppDaemon: HASS: ------------------------------------------------------------
2018-04-06 06:37:40.084538 WARNING AppDaemon: HASS: Unexpected error:
2018-04-06 06:37:40.084683 WARNING AppDaemon: HASS: ------------------------------------------------------------
2018-04-06 06:37:40.169178 WARNING AppDaemon: HASS: Traceback (most recent call last):
File “/usr/local/lib/python3.6/site-packages/appdaemon/plugins/hass/hassplugin.py”, line 189, in get_updates
“{}/api/websocket”.format(url), sslopt=sslopt
File “/usr/local/lib/python3.6/site-packages/websocket/_core.py”, line 494, in create_connection
websock.connect(url, **options)
File “/usr/local/lib/python3.6/site-packages/websocket/_core.py”, line 217, in connect
options.pop(‘socket’, None))
File “/usr/local/lib/python3.6/site-packages/websocket/_http.py”, line 76, in connect
sock = _ssl_socket(sock, options.sslopt, hostname)
File “/usr/local/lib/python3.6/site-packages/websocket/_http.py”, line 191, in _ssl_socket
sock = _wrap_sni_socket(sock, sslopt, hostname, check_hostname)
File “/usr/local/lib/python3.6/site-packages/websocket/_http.py”, line 168, in _wrap_sni_socket
server_hostname=hostname,
File “/usr/local/lib/python3.6/ssl.py”, line 407, in wrap_socket
_context=self, _session=session)
File “/usr/local/lib/python3.6/ssl.py”, line 814, in init
self.do_handshake()
File “/usr/local/lib/python3.6/ssl.py”, line 1068, in do_handshake
self._sslobj.do_handshake()
File “/usr/local/lib/python3.6/ssl.py”, line 689, in do_handshake
ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:777)
2018-04-06 06:37:40.169467 WARNING AppDaemon: HASS: ------------------------------------------------------------
2018-04-06 06:37:45.210214 DEBUG AppDaemon: Event type:ha_disconnected:
Really appreciate any inputs. Thanks.
