I’m almost fade up with my current setup with Synology NAS (DS1513+) , Sonoff Zigbee 3.0 dongle and HA as docker (VM not supported on my NAS).
I am running my HA for more than 6 months, but the issue with Sonoff Zigbee 3.0 dongle driver never end.
Every day and another, and even on the same day for multiple times , the NAS is not able to access the USB folder and I forced to re-estate the driver again as per below:
But once the driver is installed , what is the root cause to get Docker container Zigbee2MQTT to stop unexpectedly??
I am certain the driver is the issue, and I know that upon any restart I need do the same process manually or at least automate it.
My point , if Synology NAS is running what impacting the driver to be inaccessible ?
This is to report that the frequent shutdown of Zigbee2MQTT’s docker is still occur from time to another.
The docker is configured to auto restart , but it may fail to start at sometime without re-install the driver again.
