Hi all,
For those who care, I made “a little PyScript’s script” to enable / disable camera(s) in Surveillance Station via automations (and detection…).
It’s based on the Surveillance Station API and works on DSM 6 / SS 9 versions.
Based on that, you can add Snapshots functions, record, PTZ… whatever…
import json
import requests
# Based on Synology Surveillance Station API Specs
# https://global.download.synology.com/download/Document/Software/DeveloperGuide/Package/SurveillanceStation/All/enu/Surveillance_Station_Web_API.pdf
# list of camera(s) to activate/desactivate, must be the name in Surveillance Station
synology_cameras_to_work_with = ['cam1', 'cam3', 'camx']
# Synology account name, must be "administrator" in surveillance station
synology_surveillance_account_name = "account_name"
# Password
synology_surveillance_account_password = "account_password"
# URL / Ip Address of the Synology Target, end with /
synology_main_url = "https://X.X.X.X/"
# DSM Version
synology_dsm_version = 6
# Surveillance Station version
synology_surveillance_version = 9
# to store the session id
synology_session_sid = ""
# Login Url
synology_auth_login_url = f"{synology_main_url}webapi/auth.cgi?api=SYNO.API.Auth&method=login&version={synology_dsm_version}&account={synology_surveillance_account_name}&passwd={synology_surveillance_account_password}&session=SurveillanceStation&format=sid"
# Logout Url
synology_auth_logout_url =f"{synology_main_url}webapi/auth.cgi?api=SYNO.API.Auth&method=logout&version={synology_dsm_version}&session=SurveillanceStation&_sid=XXSIDXX"
# Cameras list Url
synology_cameras_list_url = f"{synology_main_url}webapi/entry.cgi?version={synology_surveillance_version}&api=SYNO.SurveillanceStation.Camera&method=List&_sid=XXSIDXX"
# Camera enable Url
synology_camera_enable_url = f"{synology_main_url}webapi/entry.cgi?api=SYNO.SurveillanceStation.Camera&method=Enable&version={synology_surveillance_version}&idList=XXLISTXX&_sid=XXSIDXX"
# Camera disable Url
synology_camera_disable_url = f"{synology_main_url}webapi/entry.cgi?api=SYNO.SurveillanceStation.Camera&method=Disable&version={synology_surveillance_version}&idList=XXLISTXX&_sid=XXSIDXX"
# To store camera(s) id to work with
synology_cameras_ids_to_work_with = ""
@service
def synology_enable_cameras():
#log.warning('Synology enable cameras start')
# Login
#log.warning(f"Call avec {synology_auth_login_url}")
try:
response_auth = task.executor(requests.get,synology_auth_login_url)
#log.warning(f"response : {response_auth.status_code} headers: {response_auth.headers}")
#log.warning(f"reponse.json : {response_auth.json()}")
data = response_auth.json()
synology_session_sid = data['data']['sid']
#log.warning(f"recu SID={synology_session_sid}")
except:
log.error('An exception occurs during Synology Cameras Enable - Login phase')
raise
else:
# End Login, next
# List cameras
camera_list_url = synology_cameras_list_url.replace("XXSIDXX", synology_session_sid)
#log.warning(f"Cameras list call avec {camera_list_url}")
try:
response_listcam = task.executor(requests.get,camera_list_url)
#log.warning(f"response : {response_listcam.status_code} headers: {response_listcam.headers}")
#log.warning(f"reponse.json : {response_listcam.json()}")
data = response_listcam.json()
except:
log.error('An exception occurs during Synology Cameras Enable - List all cameras phase')
raise
else:
# End List Cams - Next
# Enable Cams
# ['data'][list_camera[i]]['id'] - ['status'] - ['model'] - ['new_name'] - ['status']
for camera in data['data']['cameras']:
#log.warning(f"Camera id={camera['id']} , model={camera['model']} , name={camera['newName']} , status={camera['status']}")
# Check if camera is in list
for cam_to_work_with in synology_cameras_to_work_with:
if cam_to_work_with == camera['newName']:
# Find a camera, add to list to enable
#log.warning(f"Find this one : {cam_to_work_with} => ID={camera['id']}")
if synology_cameras_ids_to_work_with.strip() == "":
synology_cameras_ids_to_work_with = str(camera['id'])
else:
synology_cameras_ids_to_work_with = synology_cameras_ids_to_work_with + "," + str(camera['id'])
# End for
# If not empty, enable list of cameras
if synology_cameras_ids_to_work_with.strip() =="":
log.warning("No camera to disable...")
else:
#log.warning(f"List of cams to enable:{synology_cameras_ids_to_work_with}")
camera_enable_url = synology_camera_enable_url.replace("XXLISTXX", synology_cameras_ids_to_work_with)
camera_enable_url = camera_enable_url.replace("XXSIDXX", synology_session_sid)
#log.warning(f"Call enable with {camera_enable_url}")
try:
#log.warning("Logout...")
response_cams_enable = task.executor(requests.get, camera_enable_url)
#log.warning(f"response : {response_cams_enable.status_code} headers: {response_cams_enable.headers}")
#log.warning(f"response : {response_cams_enable.json()}")
#log.warning("Cams enable End")
except:
log.error('An exception occurs during Synology Cameras Enable - Enabling phase')
raise
#else:
#log.warning('End of Enable Cameras ;) ')
# End Enable Cams
# Logout
logout_url = synology_auth_logout_url.replace("XXSIDXX", synology_session_sid)
try:
response_logout = task.executor(requests.get, logout_url)
#log.warning(f"response : {response_logout.status_code} headers: {response_logout.headers}")
#log.warning(f"response : {response_logout.json()}")
#log.warning("Logout End")
except:
log.error('An exception occurs during Synology Cameras Enable - Logout phase')
raise
#else:
# End Logout
@service
def synology_disable_cameras():
#log.warning('synology disable cameras start')
# Login
try:
except:
log.error('An exception occurs during Synology Cameras Disable - Login phase')
raise
else:
# End Login, next
# List cameras
try:
except:
log.error('An exception occurs during Synology Cameras Disable - List all cameras phase')
raise
else:
# Enable Cams
else:
# End for
log.warning("No camera to enable...")
else:
camera_disable_url = synology_camera_disable_url.replace("XXLISTXX", synology_cameras_ids_to_work_with)
camera_disable_url = camera_disable_url.replace("XXSIDXX", synology_session_sid)
try:
response_cams_enable = task.executor(requests.get, camera_disable_url)
except:
log.error('An exception occurs during Synology Cameras Disable - Disabling phase')
raise
#else:
#log.warning('End of Disable Cameras ;) ')
# End Enable Cams
# Logout
try:
except:
log.error('An exception occurs during Synology Cameras Disable - Logout phase')
raise
#else:
# End Logout
Log lines are here if you want to see how the script works / what the SS returns are.
Regards,
Goldorak92
