running what?
if you really want it, load it as a custom component
i’m still running py_synology-0.2.0.
do have any clue how can this be updated to 0.3.0 in HASSIO?
As a custom component
Thanks! now it’s ok was missing “init.py”
how can i call now the function to enable and disable home mode?
thanks @pergola.fabio
If I remember correctly, it was an Boolean to set, not sure anymore, check your state page , you will see there a home mode
i just updated to the 8.2.3-5289 version hoping that this would solve my issues adding cameras. but it still not setting up at all.
Error when initializing SurveillanceStation
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/synology/camera.py", line 53, in async_setup_platform
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/synology/surveillance_station.py", line 12, in __init__
self._api = Api(url, username, password, timeout, verify_ssl)
File "/usr/local/lib/python3.7/site-packages/synology/api.py", line 59, in __init__
self._initialize_api_info()
File "/usr/local/lib/python3.7/site-packages/synology/api.py", line 70, in _initialize_api_info
payload)
File "/usr/local/lib/python3.7/site-packages/synology/api.py", line 192, in _get_json_with_retry
return self._get_json(url, payload)
File "/usr/local/lib/python3.7/site-packages/synology/api.py", line 198, in _get_json
response = self._get(url, payload)
File "/usr/local/lib/python3.7/site-packages/synology/api.py", line 185, in _get
verify=self._verify_ssl)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 519, in request
prep = self.prepare_request(req)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 462, in prepare_request
hooks=merge_hooks(request.hooks, self.hooks),
File "/usr/local/lib/python3.7/site-packages/requests/models.py", line 313, in prepare
self.prepare_url(url, params)
File "/usr/local/lib/python3.7/site-packages/requests/models.py", line 387, in prepare_url
raise MissingSchema(error)
requests.exceptions.MissingSchema: Invalid URL '192.168.1.211/webapi/query.cgi': No schema supplied. Perhaps you meant http://192.168.1.211/webapi/query.cgi?
- platform: synology
url: 192.168.1.211
username: !secret synology_usr
password: !secret synology_pass
verify_ssl: false
Add the port 5000 or 5001 to your url
url: https://192.168.1.211:5001
verify_ssl: false
edit: 5001 for https, thnx @pergola.fabio
For https use 5001
Component is working ok now (status = streaming) but the picture in the frontend is broken. Any ideas ?
broken or slow update?
im connected thanks! now just to figure out how to trigger home and away mode. and snapshot for picure card
Home and away mode is possible in new PR, you can launch it as custom already
im looking at that but have never done that… ive added custom components but idk what this pr stuff is
Then you need to read some stuff, or just wait untill new component update gets merged
Have a link or what to read?
Depends, maybe start how custom component work…
I thought someone already made the PR that works and i just needed to implement it?
