Synology Surveillance Station with Google Assistant
I’ve tried to use the RTSP function of surveillance station to stream the feed to google assistant as an ffmpeg camera, and when I do that i get the following error message:
“error: unable to connect to the home assistant websocket api”
Then I’ve tried to expose the camera entities to google assistant from surveillance station, except google assistant still doesn’t see it.
So at the moment I have no clue why it isn’t streaming to my nest hub max at the moment, and if anyone has any pointers or ideas, it’ll be greatly appreciated.
Thanks!
