Synology's two step verification problem
Hello everyone,
I am having problems to get the components for the Synology working, this is in my opinion caused by the two step verification requirement I setup for all admin users.
Does anyone have an idea if this can be build in/bypassed?
Thanks in advance,
André
Only way is to create a user that doesnt have 2 factor authentication enabled im afraid…
Hi, ever found a solution?
Seems for Synology sensor, you need an admin account, and you can’t disable 2 step on admin accounts… Seems it’s not possible to have some kind of service account… Or app password doesn’t exist :frowning:
Yeah, i also made the mistake to open 2FA on Syno. HA doesnot work with this. So i unchecked 2FA on User-Advanced but that doesn’t helped. Later i read on Syno website somewhere you have to reset your syno network and admin settings for that.
Luckily i found that under User-Select your user-Edit, there is a ‘Reset 2FA’ button. That rescued me and now 2FA is disabled again…
next time, when you enable 2FA, always note that long number :slight_smile: and store it somewhere safe
also enable smtp , so you can send a rescue mail :slight_smile:
I honestly don’t remember seeing any long number whatsoever :smiley: Was using Microsoft Authenticator successfully but the only problem i had was about this HA connection. so that’s why i had to disable it.
It’s the barcode you scan with the app, keep that barcode on a safe place :wink:
