Syntax question for Loop to find "Unavailable" or "Unknown"
I need this toi determine which sensors have an issue to see if it is always the same ones. I am having Yolink stability issues - so, I have this for a couple of sensors in my configuration.yaml:
template:
  - binary_sensor:
      - name: "Any Yolink Unavailable"
        state: "{{ integration_entities('yolink') | select('is_state', 'unavailable') | list | count > 0 }}"
        unique_id: any_yolink_unavailable
  - binary_sensor:
      - name: "Any Yolink Unknown"
        state: "{{ integration_entities('yolink') | select('is_state', 'unknown') | list | count > 0 }}"
        unique_id: any_yolink_unknown
This will of course return the correct values in the Developer Tools → Templates area as well - but in the same template tools section how do I (using a for loop or the like) to make it just show the unavailable or unknown sensors (their names)?
The integration_entities() function returns the entity ID, so you just need to remove the comparison and count, i.e.
{{ integration_entities('yolink') | select('is_state', 'unavailable') | list }}
Adding it as an attribute will maintain it as a list.
template:
  - binary_sensor:
        attributes:
          entity_id: "{{ integration_entities('yolink') | select('is_state', 'unavailable') | list }}"
        attributes:
          entity_id: "{{ integration_entities('yolink') | select('is_state', 'unknown') | list }}"
Depending on what you want, it is also possible to sort them by any attribute of the individual entities.
Thank you @Didgeridrew
