Syntax: Where to put MinMax Sensor?
I am struggling with the logic of the yaml files.
I am trying to add a “MinMaxHelper”. But not through GUI (I have to add 24 sensors to it so I prefer yaml).
Now I figured out the syntax and according to the above documentation I put the following in my configuration.yaml:
  - platform: min_max
    entity_ids:
      - sensor.wetter_vorhersage_01h_temp
      - sensor.wetter_vorhersage_02h_temp
      - sensor.wetter_vorhersage_03h_temp
    type: min
    round_digits: 1
    unique_id: minmax.tief24
I do not get any errors and I can reload configuration without warnings. But I do not see the created sensor anywhere. :expressionless:
Not in the configuration part for helpers and not on the default dashboard.
Where did it go? Or: why is it not visible? I can not even find it when trying to include it in an automation or so…
Where do I have to put the above code sniplet in my configuration files?
Thanks!
/KNEBB
Have you restarted HA (full restart, not reload)? Often need to do that for the first use of a new integration.
Did you look in the logs?
Oh man!
Yes, a restart was needed.
Thanks a lot!
