Syolony, Pycrypto installation failed, help
In the development of pycrypto syology problems, resulting in unable to find Broadlink, ask for help, English bad Please forgive me, thank you
[details=Summary] root@Jony-Cloud:/volume2/@appstore/py3k/usr/local/bin# ./python3 -m pip install pycrypto
Collecting pycrypto
Using cached pycrypto-2.6.1.tar.gz
Installing collected packages: pycrypto
Running setup.py install for pycrypto … error
Complete output from command /volume2/@appstore/py3k/usr/local/bin/python3 -u -c “import setuptools, tokenize;file=’/tmp/pip-build-pk03ujy_/pycrypto/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-txk2ucuq-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.5
creating build/lib.linux-x86_64-3.5/Crypto
copying lib/Crypto/pct_warnings.py -> build/lib.linux-x86_64-3.5/Crypto
copying lib/Crypto/init.py -> build/lib.linux-x86_64-3.5/Crypto
creating build/lib.linux-x86_64-3.5/Crypto/Hash
copying lib/Crypto/Hash/MD5.py -> build/lib.linux-x86_64-3.5/Crypto/Hash
copying lib/Crypto/Hash/SHA256.py -> build/lib.linux-x86_64-3.5/Crypto/Hash
copying lib/Crypto/Hash/hashalgo.py -> build/lib.linux-x86_64-3.5/Crypto/Hash
copying lib/Crypto/Hash/SHA512.py -> build/lib.linux-x86_64-3.5/Crypto/Hash
copying lib/Crypto/Hash/HMAC.py -> build/lib.linux-x86_64-3.5/Crypto/Hash
copying lib/Crypto/Hash/MD2.py -> build/lib.linux-x86_64-3.5/Crypto/Hash
copying lib/Crypto/Hash/RIPEMD.py -> build/lib.linux-x86_64-3.5/Crypto/Hash
copying lib/Crypto/Hash/MD4.py -> build/lib.linux-x86_64-3.5/Crypto/Hash
copying lib/Crypto/Hash/SHA.py -> build/lib.linux-x86_64-3.5/Crypto/Hash
copying lib/Crypto/Hash/SHA384.py -> build/lib.linux-x86_64-3.5/Crypto/Hash
copying lib/Crypto/Hash/SHA224.py -> build/lib.linux-x86_64-3.5/Crypto/Hash
copying lib/Crypto/Hash/init.py -> build/lib.linux-x86_64-3.5/Crypto/Hash
creating build/lib.linux-x86_64-3.5/Crypto/Cipher
copying lib/Crypto/Cipher/Blowfish.py -> build/lib.linux-x86_64-3.5/Crypto/Cipher
copying lib/Crypto/Cipher/DES3.py -> build/lib.linux-x86_64-3.5/Crypto/Cipher
copying lib/Crypto/Cipher/ARC2.py -> build/lib.linux-x86_64-3.5/Crypto/Cipher
copying lib/Crypto/Cipher/AES.py -> build/lib.linux-x86_64-3.5/Crypto/Cipher
copying lib/Crypto/Cipher/blockalgo.py -> build/lib.linux-x86_64-3.5/Crypto/Cipher
copying lib/Crypto/Cipher/PKCS1_v1_5.py -> build/lib.linux-x86_64-3.5/Crypto/Cipher
copying lib/Crypto/Cipher/CAST.py -> build/lib.linux-x86_64-3.5/Crypto/Cipher
copying lib/Crypto/Cipher/XOR.py -> build/lib.linux-x86_64-3.5/Crypto/Cipher
copying lib/Crypto/Cipher/ARC4.py -> build/lib.linux-x86_64-3.5/Crypto/Cipher
copying lib/Crypto/Cipher/DES.py -> build/lib.linux-x86_64-3.5/Crypto/Cipher
copying lib/Crypto/Cipher/init.py -> build/lib.linux-x86_64-3.5/Crypto/Cipher
copying lib/Crypto/Cipher/PKCS1_OAEP.py -> build/lib.linux-x86_64-3.5/Crypto/Cipher
creating build/lib.linux-x86_64-3.5/Crypto/Util
copying lib/Crypto/Util/number.py -> build/lib.linux-x86_64-3.5/Crypto/Util
copying lib/Crypto/Util/py3compat.py -> build/lib.linux-x86_64-3.5/Crypto/Util
copying lib/Crypto/Util/randpool.py -> build/lib.linux-x86_64-3.5/Crypto/Util
copying lib/Crypto/Util/RFC1751.py -> build/lib.linux-x86_64-3.5/Crypto/Util
copying lib/Crypto/Util/Counter.py -> build/lib.linux-x86_64-3.5/Crypto/Util
copying lib/Crypto/Util/winrandom.py -> build/lib.linux-x86_64-3.5/Crypto/Util
copying lib/Crypto/Util/_number_new.py -> build/lib.linux-x86_64-3.5/Crypto/Util
copying lib/Crypto/Util/init.py -> build/lib.linux-x86_64-3.5/Crypto/Util
copying lib/Crypto/Util/asn1.py -> build/lib.linux-x86_64-3.5/Crypto/Util
creating build/lib.linux-x86_64-3.5/Crypto/Random
copying lib/Crypto/Random/random.py -> build/lib.linux-x86_64-3.5/Crypto/Random
copying lib/Crypto/Random/_UserFriendlyRNG.py -> build/lib.linux-x86_64-3.5/Crypto/Random
copying lib/Crypto/Random/init.py -> build/lib.linux-x86_64-3.5/Crypto/Random
creating build/lib.linux-x86_64-3.5/Crypto/Random/Fortuna
copying lib/Crypto/Random/Fortuna/FortunaAccumulator.py -> build/lib.linux-x86_64-3.5/Crypto/Random/Fortuna
copying lib/Crypto/Random/Fortuna/FortunaGenerator.py -> build/lib.linux-x86_64-3.5/Crypto/Random/Fortuna
copying lib/Crypto/Random/Fortuna/SHAd256.py -> build/lib.linux-x86_64-3.5/Crypto/Random/Fortuna
copying lib/Crypto/Random/Fortuna/init.py -> build/lib.linux-x86_64-3.5/Crypto/Random/Fortuna
creating build/lib.linux-x86_64-3.5/Crypto/Random/OSRNG
copying lib/Crypto/Random/OSRNG/rng_base.py -> build/lib.linux-x86_64-3.5/Crypto/Random/OSRNG
copying lib/Crypto/Random/OSRNG/fallback.py -> build/lib.linux-x86_64-3.5/Crypto/Random/OSRNG
copying lib/Crypto/Random/OSRNG/init.py -> build/lib.linux-x86_64-3.5/Crypto/Random/OSRNG
copying lib/Crypto/Random/OSRNG/posix.py -> build/lib.linux-x86_64-3.5/Crypto/Random/OSRNG
creating build/lib.linux-x86_64-3.5/Crypto/SelfTest
copying lib/Crypto/SelfTest/init.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest
copying lib/Crypto/SelfTest/st_common.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest
creating build/lib.linux-x86_64-3.5/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_DES3.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_CAST.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_pkcs1_oaep.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/common.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_DES.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_XOR.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_Blowfish.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_ARC2.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_AES.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_ARC4.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_pkcs1_15.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/init.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Cipher
creating build/lib.linux-x86_64-3.5/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_SHA512.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_SHA224.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_MD4.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/common.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_SHA.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_MD5.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_RIPEMD.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_SHA384.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_HMAC.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_MD2.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/init.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_SHA256.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Hash
creating build/lib.linux-x86_64-3.5/Crypto/SelfTest/Protocol
copying lib/Crypto/SelfTest/Protocol/test_AllOrNothing.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Protocol
copying lib/Crypto/SelfTest/Protocol/test_KDF.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Protocol
copying lib/Crypto/SelfTest/Protocol/test_chaffing.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Protocol
copying lib/Crypto/SelfTest/Protocol/test_rfc1751.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Protocol
copying lib/Crypto/SelfTest/Protocol/init.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Protocol
creating build/lib.linux-x86_64-3.5/Crypto/SelfTest/PublicKey
copying lib/Crypto/SelfTest/PublicKey/test_importKey.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/PublicKey
copying lib/Crypto/SelfTest/PublicKey/test_RSA.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/PublicKey
copying lib/Crypto/SelfTest/PublicKey/test_DSA.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/PublicKey
copying lib/Crypto/SelfTest/PublicKey/init.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/PublicKey
copying lib/Crypto/SelfTest/PublicKey/test_ElGamal.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/PublicKey
creating build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random
copying lib/Crypto/SelfTest/Random/test__UserFriendlyRNG.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random
copying lib/Crypto/SelfTest/Random/test_rpoolcompat.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random
copying lib/Crypto/SelfTest/Random/test_random.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random
copying lib/Crypto/SelfTest/Random/init.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random
creating build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random/Fortuna
copying lib/Crypto/SelfTest/Random/Fortuna/test_SHAd256.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random/Fortuna
copying lib/Crypto/SelfTest/Random/Fortuna/test_FortunaGenerator.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random/Fortuna
copying lib/Crypto/SelfTest/Random/Fortuna/test_FortunaAccumulator.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random/Fortuna
copying lib/Crypto/SelfTest/Random/Fortuna/init.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random/Fortuna
creating build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random/OSRNG
copying lib/Crypto/SelfTest/Random/OSRNG/test_posix.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random/OSRNG
copying lib/Crypto/SelfTest/Random/OSRNG/test_winrandom.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random/OSRNG
copying lib/Crypto/SelfTest/Random/OSRNG/test_fallback.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random/OSRNG
copying lib/Crypto/SelfTest/Random/OSRNG/test_nt.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random/OSRNG
copying lib/Crypto/SelfTest/Random/OSRNG/test_generic.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random/OSRNG
copying lib/Crypto/SelfTest/Random/OSRNG/init.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Random/OSRNG
creating build/lib.linux-x86_64-3.5/Crypto/SelfTest/Util
copying lib/Crypto/SelfTest/Util/test_Counter.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Util
copying lib/Crypto/SelfTest/Util/test_winrandom.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Util
copying lib/Crypto/SelfTest/Util/test_number.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Util
copying lib/Crypto/SelfTest/Util/test_asn1.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Util
copying lib/Crypto/SelfTest/Util/init.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Util
creating build/lib.linux-x86_64-3.5/Crypto/SelfTest/Signature
copying lib/Crypto/SelfTest/Signature/test_pkcs1_pss.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Signature
copying lib/Crypto/SelfTest/Signature/test_pkcs1_15.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Signature
copying lib/Crypto/SelfTest/Signature/init.py -> build/lib.linux-x86_64-3.5/Crypto/SelfTest/Signature
creating build/lib.linux-x86_64-3.5/Crypto/Protocol
copying lib/Crypto/Protocol/AllOrNothing.py -> build/lib.linux-x86_64-3.5/Crypto/Protocol
copying lib/Crypto/Protocol/Chaffing.py -> build/lib.linux-x86_64-3.5/Crypto/Protocol
copying lib/Crypto/Protocol/KDF.py -> build/lib.linux-x86_64-3.5/Crypto/Protocol
copying lib/Crypto/Protocol/init.py -> build/lib.linux-x86_64-3.5/Crypto/Protocol
creating build/lib.linux-x86_64-3.5/Crypto/PublicKey
copying lib/Crypto/PublicKey/slowmath.py -> build/lib.linux-x86_64-3.5/Crypto/PublicKey
copying lib/Crypto/PublicKey/pubkey.py -> build/lib.linux-x86_64-3.5/Crypto/PublicKey
copying lib/Crypto/PublicKey/RSA.py -> build/lib.linux-x86_64-3.5/Crypto/PublicKey
copying lib/Crypto/PublicKey/DSA.py -> build/lib.linux-x86_64-3.5/Crypto/PublicKey
copying lib/Crypto/PublicKey/ElGamal.py -> build/lib.linux-x86_64-3.5/Crypto/PublicKey
copying lib/Crypto/PublicKey/init.py -> build/lib.linux-x86_64-3.5/Crypto/PublicKey
creating build/lib.linux-x86_64-3.5/Crypto/Signature
copying lib/Crypto/Signature/PKCS1_PSS.py -> build/lib.linux-x86_64-3.5/Crypto/Signature
copying lib/Crypto/Signature/PKCS1_v1_5.py -> build/lib.linux-x86_64-3.5/Crypto/Signature
copying lib/Crypto/Signature/init.py -> build/lib.linux-x86_64-3.5/Crypto/Signature
Skipping optional fixer: buffer
Skipping optional fixer: idioms
Skipping optional fixer: set_literal
Skipping optional fixer: ws_comma
running build_ext
running build_configure
checking for gcc… gcc
checking whether the C compiler works… no
configure: error: in /tmp/pip-build-pk03ujy_/pycrypto': configure: error: C compiler cannot create executables See config.log’ for more details
File “”, line 1, in
File "/tmp/pip-build-pk03ujy
/pycrypto/setup.py", line 456, in
core.setup(**kw)
File “/volume2/@appstore/py3k/usr/local/lib/python3.5/distutils/core.py”, line 148, in setup
dist.run_commands()
File “/volume2/@appstore/py3k/usr/local/lib/python3.5/distutils/dist.py”, line 955, in run_commands
self.run_command(cmd)
File “/volume2/@appstore/py3k/usr/local/lib/python3.5/distutils/dist.py”, line 974, in run_command
cmd_obj.run()
File “/volume2/@appstore/py3k/usr/local/lib/python3.5/site-packages/setuptools/command/install.py”, line 61, in run
return orig.install.run(self)
File “/volume2/@appstore/py3k/usr/local/lib/python3.5/distutils/command/install.py”, line 539, in run
self.run_command(‘build’)
File “/volume2/@appstore/py3k/usr/local/lib/python3.5/distutils/cmd.py”, line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File “/volume2/@appstore/py3k/usr/local/lib/python3.5/distutils/command/build.py”, line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
/pycrypto/setup.py", line 251, in run
cmd_obj.run()
/pycrypto/setup.py", line 278, in run
raise RuntimeError(“autoconf error”)
RuntimeError: autoconf error
Command "/volume2/@appstore/py3k/usr/local/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-pk03ujy_/pycrypto/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-txk2ucuq-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-pk03ujy_/pycrypto/
root@Jony-Cloud:/volume2/@appstore/py3k/usr/local/bin#`[/details]
thank you very much
