System and Frigate log errors, when trying to display the logs
  1. When going to Frigate > Settings > System logs, logs are visible
  2. When going to Settings > Add-ons > Frigate (Full Access) > Log, I get the following error message “Failed to get ccab4aaf_frigate-fa logs, e.callApiRaw is not a function”
  3. When going to Settings > System > Logs, choosing " Frigate (Full Access)" logs, I see the logs.
  4. Under System Info, no logs are being displayed, and error “Failed to get multicast logs, e.callApiRaw is not a function” is generated .
Even when I change the “Log providers” from Supervisor, to Core to, to Host, to DNS, to audio, and to Multicast! I see error ErrorOn the System info page is “Failed to get multicast logs, e.callApiRaw is not a function”
Otherwise everything else in Frigate and HA’s environment seems to be working,.
What is happening?
FYI existing versions:
  • Core: 2024.10.4
  • Supervisor: 2024.11.2
  • Operating System: 13.2
  • Frontend: 20241002.4
  • Frigate (Full Access): 0.14.1
UPDATE: Installing Core Version: core-2024.11.1 solved the problem. :slightly_smiling_face:
