I’m running on RPI4 - hassio, latest versions. I just moved everything (5 days ago) to a SSD boot hoping this would solve my problem. I have a substantial system with 100+ entities. I use a Conbee II with Deconz. My issue started after an update in mid december (I sadly didn’t note which one…)
The system slows down, supervisor becomes unavailable until everything stops. I just witnessed it while working on it and was able to pick the logs as it happened. But I don’t know where to look further from those logs. The below starts when “no there’s no problem” and when it starts (we can see it by the frequent entry logs happening)
Has anybody some lights for me on how to solve this?
2021-01-15 11:26:21 WARNING (MainThread) [homeassistant.config_entries] Config entry for upnp not ready yet. Retrying in 80 seconds
2021-01-15 11:27:51 WARNING (MainThread) [homeassistant.components.upnp] Wanted UPnP/IGD device with UDN/ST "uuid:70d5b96d-4bf8-49be-b15d-96fbd6e415f4"/"urn:schemas-upnp-org:device:InternetGatewayDevice:2" not found, aborting
2021-01-15 11:27:51 WARNING (MainThread) [homeassistant.config_entries] Config entry for upnp not ready yet. Retrying in 80 seconds
2021-01-15 11:29:21 WARNING (MainThread) [homeassistant.components.upnp] Wanted UPnP/IGD device with UDN/ST "uuid:70d5b96d-4bf8-49be-b15d-96fbd6e415f4"/"urn:schemas-upnp-org:device:InternetGatewayDevice:2" not found, aborting
2021-01-15 11:29:21 WARNING (MainThread) [homeassistant.config_entries] Config entry for upnp not ready yet. Retrying in 80 seconds
2021-01-15 11:29:37 ERROR (MainThread) [homeassistant.config] Invalid config for [sensor]: required key not provided @ data['platform']. Got None. (See /config/sensors.yaml, line 1). Please check the docs at https://www.home-assistant.io/integrations/sensor
2021-01-15 11:30:40 ERROR (MainThread) [homeassistant.components.sensor] Entity id already exists - ignoring: sensor.badge_hall
2021-01-15 11:30:51 WARNING (MainThread) [homeassistant.components.upnp] Wanted UPnP/IGD device with UDN/ST "uuid:70d5b96d-4bf8-49be-b15d-96fbd6e415f4"/"urn:schemas-upnp-org:device:InternetGatewayDevice:2" not found, aborting
2021-01-15 11:30:51 WARNING (MainThread) [homeassistant.config_entries] Config entry for upnp not ready yet. Retrying in 80 seconds
2021-01-15 11:31:54 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2021-01-15 11:32:17 WARNING (MainThread) [homeassistant.components.light] Updating tuya light took longer than the scheduled update interval 0:00:15
2021-01-15 11:32:17 WARNING (MainThread) [homeassistant.components.switch] Updating tuya switch took longer than the scheduled update interval 0:00:15
2021-01-15 11:32:17 WARNING (MainThread) [homeassistant.components.cover] Updating tuya cover took longer than the scheduled update interval 0:00:15
2021-01-15 11:32:29 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2021-01-15 11:32:45 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2021-01-15 11:32:45 WARNING (MainThread) [homeassistant.components.light] Updating tuya light took longer than the scheduled update interval 0:00:15
2021-01-15 11:32:45 WARNING (MainThread) [homeassistant.components.switch] Updating tuya switch took longer than the scheduled update interval 0:00:15
2021-01-15 11:32:45 WARNING (MainThread) [homeassistant.components.cover] Updating tuya cover took longer than the scheduled update interval 0:00:15
2021-01-15 11:33:18 WARNING (MainThread) [homeassistant.config_entries] Config entry for upnp not ready yet. Retrying in 80 seconds
2021-01-15 11:33:18 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating workday binary_sensor took longer than the scheduled update interval 0:00:30
2021-01-15 11:33:18 WARNING (MainThread) [homeassistant.components.switch] Updating wake_on_lan switch took longer than the scheduled update interval 0:00:30
2021-01-15 11:33:18 WARNING (MainThread) [homeassistant.components.light] Updating twinkly light took longer than the scheduled update interval 0:00:30
2021-01-15 11:33:18 WARNING (MainThread) [homeassistant.components.media_player] Updating spotify media_player took longer than the scheduled update interval 0:00:30
2021-01-15 11:33:18 WARNING (MainThread) [homeassistant.components.light] Updating tuya light took longer than the scheduled update interval 0:00:15
2021-01-15 11:33:18 WARNING (MainThread) [homeassistant.components.switch] Updating tuya switch took longer than the scheduled update interval 0:00:15
2021-01-15 11:33:38 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2021-01-15 11:33:38 WARNING (MainThread) [homeassistant.components.light] Updating tuya light took longer than the scheduled update interval 0:00:15
2021-01-15 11:33:38 WARNING (MainThread) [homeassistant.components.switch] Updating tuya switch took longer than the scheduled update interval 0:00:15
2021-01-15 11:33:38 WARNING (MainThread) [homeassistant.components.cover] Updating tuya cover took longer than the scheduled update interval 0:00:15
2021-01-15 11:33:53 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for binary_sensor.remote_ui (<class 'homeassistant.components.cloud.binary_sensor.CloudRemoteBinary'>) took 2.019 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+cloud%22
2021-01-15 11:33:58 WARNING (MainThread) [homeassistant.components.switch] Setup of switch platform command_line is taking over 10 seconds.
2021-01-15 11:33:58 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform mqtt is taking over 10 seconds.
2021-01-15 11:34:17 WARNING (MainThread) [homeassistant.components.light] Updating tuya light took longer than the scheduled update interval 0:00:15
2021-01-15 11:34:17 WARNING (MainThread) [homeassistant.components.switch] Updating tuya switch took longer than the scheduled update interval 0:00:15
2021-01-15 11:34:17 WARNING (MainThread) [homeassistant.components.cover] Updating tuya cover took longer than the scheduled update interval 0:00:15
2021-01-15 11:34:18 WARNING (MainThread) [homeassistant.components.binary_sensor] Setup of binary_sensor platform template is taking over 10 seconds.
2021-01-15 11:34:18 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform template is taking over 10 seconds.
2021-01-15 11:34:20 ERROR (MainThread) [homeassistant.components.sensor] Entity id already exists - ignoring: sensor.badge_hall
2021-01-15 11:34:58 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.time (<class 'homeassistant.components.time_date.sensor.TimeDateSensor'>) took 0.473 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+time_date%22
2021-01-15 11:35:08 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform statistics is taking over 10 seconds.
2021-01-15 11:35:08 WARNING (MainThread) [homeassistant.components.binary_sensor] Setup of binary_sensor platform trend is taking over 10 seconds.
2021-01-15 11:35:08 WARNING (MainThread) [homeassistant.components.climate] Setup of climate platform generic_thermostat is taking over 10 seconds.
2021-01-15 11:35:22 WARNING (MainThread) [homeassistant.components.media_player] Updating browser_mod media_player took longer than the scheduled update interval 0:00:10
2021-01-15 11:35:22 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2021-01-15 11:35:22 WARNING (MainThread) [homeassistant.components.light] Updating tuya light took longer than the scheduled update interval 0:00:15
2021-01-15 11:35:22 WARNING (MainThread) [homeassistant.components.switch] Updating tuya switch took longer than the scheduled update interval 0:00:15
2021-01-15 11:35:22 WARNING (MainThread) [homeassistant.components.cover] Updating tuya cover took longer than the scheduled update interval 0:00:15
2021-01-15 11:35:26 WARNING (MainThread) [homeassistant.components.switch] Setup of switch platform template is taking over 10 seconds.
2021-01-15 11:35:43 WARNING (Thread-11) [pychromecast.socket_client] [Bathroom speaker(192.168.86.76):8009] Heartbeat timeout, resetting connection
2021-01-15 11:35:44 WARNING (Thread-13) [pychromecast.socket_client] [House(192.168.86.76):32200] Error communicating with socket, resetting connection
2021-01-15 11:35:44 WARNING (Thread-7) [pychromecast.socket_client] [Chromecast TV(192.168.86.47):8009] Error communicating with socket, resetting connection
2021-01-15 11:35:43 WARNING (Thread-14) [pychromecast.socket_client] [All but not upstairs(192.168.86.76):32198] Heartbeat timeout, resetting connection
2021-01-15 11:35:50 WARNING (Thread-10) [pychromecast.socket_client] [Kitchen Google(192.168.86.54):8009] Error communicating with socket, resetting connection
2021-01-15 11:35:52 ERROR (MainThread) [homeassistant.components.climate] Setup of platform generic_thermostat is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2021-01-15 11:36:01 ERROR (MainThread) [homeassistant.components.climate] Setup of platform generic_thermostat is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2021-01-15 11:36:09 ERROR (MainThread) [homeassistant.components.climate] Setup of platform generic_thermostat is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2021-01-15 11:36:11 WARNING (Thread-7) [pychromecast.socket_client] [Chromecast TV(192.168.86.47):8009] Error communicating with socket, resetting connection
2021-01-15 11:36:14 ERROR (MainThread) [homeassistant.components.climate] Setup of platform generic_thermostat is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2021-01-15 11:36:17 ERROR (MainThread) [homeassistant.components.climate] Setup of platform generic_thermostat is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2021-01-15 11:36:19 ERROR (MainThread) [homeassistant.components.climate] Setup of platform generic_thermostat is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2021-01-15 11:36:20 ERROR (MainThread) [homeassistant.components.climate] Setup of platform generic_thermostat is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2021-01-15 11:36:23 ERROR (MainThread) [homeassistant.components.climate] Setup of platform generic_thermostat is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2021-01-15 11:36:36 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating workday binary_sensor took longer than the scheduled update interval 0:00:30
2021-01-15 11:36:36 WARNING (MainThread) [homeassistant.components.switch] Updating wake_on_lan switch took longer than the scheduled update interval 0:00:30
2021-01-15 11:36:36 WARNING (MainThread) [homeassistant.components.light] Updating twinkly light took longer than the scheduled update interval 0:00:30
2021-01-15 11:36:36 WARNING (MainThread) [homeassistant.components.media_player] Updating spotify media_player took longer than the scheduled update interval 0:00:30
2021-01-15 11:36:36 ERROR (MainThread) [snitun.multiplexer.core] Ping fails, no response from peer
2021-01-15 11:37:08 ERROR (MainThread) [homeassistant.components.binary_sensor] Setup of platform trend is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2021-01-15 11:37:08 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.twinkly_fa9f05 is taking over 10 seconds
2021-01-15 11:37:08 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.twinkly_facc45 is taking over 10 seconds
2021-01-15 11:37:19 WARNING (Thread-14) [pychromecast.socket_client] [All but not upstairs(192.168.86.76):32198] Heartbeat timeout, resetting connection
2021-01-15 11:37:36 ERROR (MainThread) [custom_components.sonoffOLD2.sonoff_cloud] Coolkit API error: Cannot connect to host eu-api.coolkit.cc:8080 ssl:default [Try again]
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 1005, in _create_direct_connection
hosts = await asyncio.shield(host_resolved)
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 871, in _resolve_host
addrs = await self._resolver.resolve(host, port, family=self._family)
File "/usr/local/lib/python3.8/site-packages/aiohttp/resolver.py", line 31, in resolve
infos = await self._loop.getaddrinfo(
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 825, in getaddrinfo
return await self.run_in_executor(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/socket.py", line 918, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/config/custom_components/sonoffOLD2/sonoff_cloud.py", line 147, in _api
r = await coro
File "/usr/local/lib/python3.8/site-packages/aiohttp/client.py", line 527, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 541, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 898, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 1017, in _create_direct_connection
raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host eu-api.coolkit.cc:8080 ssl:default [Try again]
2021-01-15 11:38:13 ERROR (Thread-11) [pychromecast.socket_client] [Bathroom speaker(192.168.86.76):8009] Error reading from socket.
2021-01-15 11:38:15 WARNING (Thread-11) [pychromecast.socket_client] [Bathroom speaker(192.168.86.76):8009] Error communicating with socket, resetting connection
2021-01-15 11:38:15 WARNING (Thread-12) [pychromecast.socket_client] [Downstairs(192.168.86.76):32154] Heartbeat timeout, resetting connection
2021-01-15 11:38:17 WARNING (Thread-13) [pychromecast.socket_client] [House(192.168.86.76):32200] Heartbeat timeout, resetting connection
2021-01-15 11:38:17 WARNING (Thread-14) [pychromecast.socket_client] [All but not upstairs(192.168.86.76):32198] Error communicating with socket, resetting connection
2021-01-15 11:38:17 WARNING (Thread-7) [pychromecast.socket_client] [Chromecast TV(192.168.86.47):8009] Error communicating with socket, resetting connection
2021-01-15 11:38:17 WARNING (Thread-10) [pychromecast.socket_client] [Kitchen Google(192.168.86.54):8009] Heartbeat timeout, resetting connection
2021-01-15 11:38:34 ERROR (SyncWorker_11) [homeassistant.components.darksky.sensor] Unable to connect to Dark Sky: HTTPSConnectionPool(host='api.darksky.net', port=443): Max retries exceeded with url: /forecast/0bc90967dc25161a497a47a002546064/51.8898802,4.4618576?units=si&lang=nl (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f60deba60>: Failed to establish a new connection: [Errno -3] Try again'))
2021-01-15 11:38:56 WARNING (Thread-13) [pychromecast.socket_client] [House(192.168.86.76):32200] Error communicating with socket, resetting connection
2021-01-15 11:38:53 WARNING (Thread-14) [pychromecast.socket_client] [All but not upstairs(192.168.86.76):32198] Error communicating with socket, resetting connection
2021-01-15 11:39:07 WARNING (Thread-10) [pychromecast.socket_client] [Kitchen Google(192.168.86.54):8009] Heartbeat timeout, resetting connection
2021-01-15 11:39:09 WARNING (Thread-7) [pychromecast.socket_client] [Chromecast TV(192.168.86.47):8009] Heartbeat timeout, resetting connection
2021-01-15 11:39:15 WARNING (Thread-12) [pychromecast.socket_client] [Downstairs(192.168.86.76):32154] Error communicating with socket, resetting connection
2021-01-15 11:39:19 WARNING (Thread-11) [pychromecast.socket_client] [Bathroom speaker(192.168.86.76):8009] Heartbeat timeout, resetting connection
2021-01-15 11:39:39 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
. I added system monitor and seems to be a memory leak.
