System gets unresponsive every day
Since the last 2 month I cannot connect to Home Assistant after about 1 day.
After I cut the power and restart the system will run for a day before getting unresponsive again.
Unfortunately after the restart all logs are empty, so can’t figure out where the problem is.
During normal operation the logs are not showing any problem.
HA running on Raspberry Pi 3 with always latest versions installed
What can be the problem?!
A second log is copied and saved before it is cleared on restarting. Look for:
/config/home-assistant.log.1
Thanks for the hint.
The log shows that there is a problem with the network access.
Seems to be related to this:
The strange thing is that after a probable LAN Powersafe a wakeup happens that my router assigns the fixed IP again and I can access the Observer on port 4357 but the HA website on port 8123 is not responding
