Everytime i try to either do an update or install an addon i get the same error
2023-03-05 14:48:13.485 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [548079550032] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy - setup
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 303, in async_install
await async_update_core(self.hass, version=version, backup=backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 51, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: 'HomeAssistantCore.update' blocked from execution, system is not healthy - setup
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1787, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1824, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 680, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 968, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 720, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 154, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 413, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 305, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy - setup
Ive heard it has something to do with the supervisor and I can use the terminal to simply ignore the error but unfortunatly i dont have the terminal&ssh addon installed.
HA is running on a raspberry pi 3 b+ and i do have backups available but it doesnt seem to be able to restore from the backups
