System log error: Connection refused, but I'm not using that private network range
Hi all
Apologies I’m not sure when this started as I don’t look at my System log as often as maybe I should.
I have about half a dozen errors that look like this…
20-03-09 01:56:46 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_appdaemon
20-03-09 01:56:46 ERROR (MainThread) [supervisor.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
20-03-09 01:56:49 INFO (MainThread) [supervisor.auth] Auth request from core_mosquitto for mqttuser
20-03-09 01:56:49 ERROR (MainThread) [supervisor.homeassistant] Error on call http://172.30.32.1:8123/api/: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
Each error is always preceeded by either the appdaemon call or mosquitto’s. Nothing seems to be wrong with the way AppDaemon or my MQTT host is running.
I suppose what has me scratching my head is why the host is referred to here as being on a 172. private network range? My installation is on the 192.168. range.
Any ideas why that discrepency?
Hass.io is using Docker container(s). 172.30.x.x are “internal” IPs for the different containers. They are assigned from Docker. :slight_smile:
Check the documentation here: https://docs.docker.com/engine/reference/commandline/network_connect/
Ah, I see. Thanks @paddy0174
My system’s reverse-proxy is handled “outside” of my home assistant installation. Could that be contributing to the errors? I wonder if I can just ignore them, as I am very happy with how my system is running.
In my case, I do ignore them, because normally these are just refused connections, because something isn’t ready at that point. :slight_smile:
For example, the app_daemon message, I do always get, when I restart HA. As I do restart the HA container, the AppDaemon container can not connect, same for the mqtt container (from your example).
I’d look for any errors, that take place outside a restart or something like that for the main HA container. :slight_smile:
EDIT:
This is what it looks like, when I restart HA.
That gives me some piece of mind - thanks
