here is my system monitor code, it was working fine until yesterday. Since then I added fr24 tracking graphs using the code in this at the end of the configuration file. what I am doing wrong? thread FlightRadar24 as an Add-On? - #21 by yousaf465
Ok, you did not even show this code in your original post.
My recommendation is to either use packages, split all sensors into a separate file or put all sensors under a single sensor: header instead of creating multiple sensor xxx: headers.
It’s more structured and let’s you easily find stuff.
this code was linked in my original post (linked to fr24 thread).
I did try once to put all sensors under a single sensor: header, but coding skills are very limited. Still learning the basic indentation in YAML, which is why I try to use Visual studio over samba.
Actually, I have almost completed my HA setup, no more sensors are planned until I upgrade to an SSD setup.
except for the gas meter, which I will install using manual reading.
