a separate vm
Can you share your Pi-Hole card code, and how you can toggle it on/off? Thanks!
I’m interested in the card code as well and how does it actually work - do you relay all your internet traffic through that device (pointing your devices to use it as DNS) before it goes to your ISP equipment?
- Yes, my Primary DNS Server is the pi-hole, i configured it in my router.
- as for turn off/on the block state, please follow the guide below:
Pi-Hole switch - lovelace code:
- type: entities
show_header_toggle: false
title: Pi-Hole
entities:
- entity: switch.pi_hole
icon: mdi:server-network
name: Pi-Hole Server - Ubuntu 18.04.2 LTS
- entity: switch.pihole_switch
icon: mdi:pi-hole
name: Pi-Hole Ads Block State
# - type: divider
- type: custom:bar-card
title: Ads Blocked Today
title_position: inside
entity: sensor.pi_hole_ads_blocked_today
decimal: 0
max: 10000
title: DNS Queries
entity: sensor.pi_hole_dns_queries_today
decimal: 0
max: 100000
title: Pi-Hole DNS Unique Clients
entity: sensor.pi_hole_dns_unique_clients
decimal: 0
# max: 25
Thank you !!!
And you pie hole then points to your ISPs DNS or Google DNS or?
no problem, ISP
Well, I finally decided to release my card!
I have added 12 examples in the repository, so you can see how a card is ‘created’.
Have fun with it
The pull request for HACS is done, so it should end up there too.
And it is merged!
Some new experiments…
The cockpit view:
and some other view with more partial segmented arcs and horizontal bars.
In its very early stages, but fully configurable using yaml.
The simple barcharts for history/trends are still a mock-up btw. They show fake data.
Update:
After hours of debugging and not understanding some weird Javascript things, I managed to get real data into the bar charts
That “cockpit view” is awesome! Keep up the nice work!
Thanx. I’ll keep experimenting…
The next example shows shows 7x temperatures and 7x humidity, but I also plan to use this for my server which has multiple hdd’s in a cage, including their temperatures. So the humidity becomes the % used.
In case you didn’t notice, It is the same card as the cockpit display…
Will you share your template used in your decluttering cards?
Yes, I will update my repository with the decluttering templates I use.
Could you share your lovelace yaml? I’m very interested in the cpu/disk/memory section, very clear/slim design!
Sure, This is the updated version
code:
- title: Server
icon: mdi:server
cards:
- type: vertical-stack
cards:
cards:
- type: entities
title: System Monitor - Hassio
entities:
- entity: switch.hassio
icon: mdi:ubuntu
- entity: sensor.current_version
icon: mdi:home-assistant
- sensor.potential_breaking_changes
- entity: sensor.hacs
- entity: sensor.processor_use
icon: mdi:memory
- entity: sensor.memory_use_percent
name: Memory Use Percentage
- entity: sensor.memory_free
- entity: sensor.swap_use_percent
name: Swap Use Percent
- entity: sensor.disk_use_percent_home
name: Disk Use Percentage
- entity: sensor.disk_use_home
- entity: sensor.disk_free_home
- entity: sensor.home_assistant_v2_db
icon: mdi:database
- entity: sensor.last_boot
name: Hassio Last Boot
- entity: sensor.ipv4_address_enp0s3
# - sensor.last_successful_authentication
cards:
cards:
# - type: entities
# show_header_toggle: false
# title: Pi-Hole
# entities:
# - entity: switch.pi_hole
# icon: mdi:pi-hole
# name: Pi-Hole - Ubuntu 18.04.2 LTS
- type: entities
title: Hassio
entities:
- type: call-service
action_name: Restart
service: homeassistant.restart
action_name: Reload Automation
service: automation.reload
- type: divider
title: HA CPU
max: 100
severity:
- value: 30
color: '#40bf60'
- value: 60
color: '#ffa500'
- value: 100
color: '#e60000'
title: HA Memory
icon: mdi:database
#title_position: inside
max: 100
severity:
- value: 30
color: '#40bf60'
- value: 60
color: '#ffa500'
- value: 90
color: '#e60000'
title: HA Storage
severity:
- value: 33
color: '#40bf60'
- value: 50
color: '#ffa500'
- value: 75
color: '#e60000'
title: Swap Use Percent
severity:
- value: 33
color: '#40bf60'
- value: 50
color: '#ffa500'
- value: 75
color: '#e60000'
title: HA Database
icon: mdi:database
max: 500
severity:
- value: 150
color: '#40bf60'
- value: 200
color: '#ffa500'
- value: 250
color: '#e60000'
- type: entities
title: Pi-Hole
entities:
icon: mdi:pi-hole
decimal: 0
max: 10000
title: DNS Queries
decimal: 0
max: 100000
decimal: 0
cards:
cards:
- type: custom:vertical-stack-in-card
cards:
- type: entities
title: System Monitor - Mini PC
entities:
- entity: switch.mini_pc
name: MiniPC - Windows 10 Pro
icon: mdi:windows
- entity: sensor.desktop_emnn779_intel_core_i5_3317u_load_cpu_total
icon: mdi:chip
type: custom:multiple-entity-row
hide_state: true
name: Intel Core i5 3317U
primary:
secondary:
entity: sensor.desktop_emnn779_intel_core_i5_3317u_temperatures_cpu_package
- entity: sensor.desktop_emnn779_samsung_ssd_850_evo_250gb_load_used_space
icon: mdi:harddisk
hide_state: true
name: Samsung Evo 850
primary:
secondary:
entity: sensor.desktop_emnn779_samsung_ssd_850_evo_250gb_temperatures_temperature
- entity: sensor.desktop_emnn779_generic_memory_load_memory
name: Samsung 8GB DDR-3
icon: mdi:memory
hide_state: true
primary:
entity: sensor.desktop_emnn779_generic_memory_data_used_memory
secondary:
entity: sensor.desktop_emnn779_generic_memory_data_available_memory
- type: divider
- type: custom:mini-graph-card
entities:
- entity: sensor.desktop_emnn779_intel_core_i5_3317u_temperatures_cpu_package
name: CPU Temperature
show:
labels: true
extrema: true
color_thresholds:
- value: 43
color: "#f39c12"
- value: 46
color: "#d35400"
- value: 49
color: "#c0392b"
- type: divider
- type: entities
title: Network
entities:
- entity: sensor.archerc7v4_kbyte_sec_received
icon: mdi:router-wireless
hide_state: true
primary:
name: Kbyte Sec Received
secondary:
entity: sensor.archerc7v4_kbyte_sec_sent
name: Kbyte Sec Sent
title: Download
entity: sensor.speedtest_download
max: 200
severity:
- value: 50
color: '#e60000'
- value: 150
color: '#ffa500'
- value: 200
color: '#40bf60'
title: Upload
entity: sensor.speedtest_upload
max: 6
severity:
- value: 1
color: '#e60000'
- value: 3
color: '#ffa500'
- value: 6
color: '#40bf60'
title: Ping
entity: sensor.speedtest_ping
icon: mdi:database
max: 200
severity:
- value: 40
color: '#40bf60'
- value: 80
color: '#ffa500'
- value: 200
color: '#e60000'
What did you use for getting NextCloud info?
I made a script which reads the RSS feed coming from nextcloud.
hi,
how do you monitor cpu temp and usage?
thanks
You can get Processor use from the System Monitor…
And for CPU temp… it depends on what machine you’re running on. For example, my i3 NUC required me to use a command line sensor, like this:
# CPU temp command line sensor
- platform: command_line
command: "cat /sys/class/thermal/thermal_zone3/temp"
# If errors occur, remove degree symbol below
unit_of_measurement: "°C"
value_template: '{{ value | multiply(0.001) | round(1) }}'
Cerb, do you mind sharing your yaml for this page?
