Packages are nice in bundling a bunch of things together for a specific task (i.e. weather, system monitor, recycle, and more). It seems everyone likes the lovelace.yaml over the editor. Only issue with editor it puts everything backwards compared to the yaml file. Do you have a github of your HA configs? Love to see what you have as a whole. I am still building so not at the uploading stage yet.
Not yet…
Hello ObiKaiKenobi,
you have an interesting option in your configuration:
Think this is to switch on and off the guest wifiof your Fritz Box?
Can you give me more information about this? How do you do this?
Thanks a lot in advance!
/Ralf
Hi Ralf,
You‘r correct. It is used to enable guest WiFi on FritzBOX.
It is a custom component which can be found here:
You could also use it to reconnect your internet connection and also to switch internet profiles of devices (which i have not testet yet).
Thanks a lot! Didin’t know this component yet…
And thanks for your fast response!
/ Ralf
@Ralf Make sure to use the updated version with a lot of new features: https://github.com/mammuth/ha-fritzbox-tools
please note that you can also use:
{{ states.automation | count }}
shorten the code a bit
about the input_boolean: this also triggers the update when the boolean is turned_off?
Correct, that way when you push the button it just refreshes no matter the state of the bool.
Sweet I’ll mod this when I get home. Thanks for the tip!
Thanks, found the component, many thanks for writing this!
/Ralf
@petro is there a clean way to add a filter to calculate the total number of devices on the network? I currently have a loop that sees if the device tracker is home and is from the router. I’d prefer to have shortened version.
{% for state in states.device_tracker if(state.state == 'home' and state.attributes.source_type == 'router') -%}
{% if loop.last -%}
{{ loop.index }}
{%- endif %}
{%- else %}
0
{%- endfor %}
Found this thread Counting Open Doors & Motion Sensors? (Solved by ranting at myself) and was able to apply it to my needs to get:
#------ Number of devices on WiFi Router
connected_devices:
friendly_name: "Devices on Network"
value_template: "{{ states.device_tracker | selectattr('state', 'eq', 'home') | selectattr('attributes.source_type', 'eq', 'router') | list | count }}"
glad you got it sorted out
LogisticalLux,
Love your system monitor page can you share the lovelace configs?
Hi @gdreelin Of course I can. Now I am in the office, I will share this evening.
Forgot that I can access with Nabu Casa. So here the lovelance config (complete, not only the sysmonitor part). Please note that you need some additional modules!
resources:
- type: js
url: 'https://cdn.jsdelivr.net/npm/rgb-light-card'
- type: module
url: /local/mini-graph-card-bundle.js?v=0.8.1
- type: module
url: /local/card-mod.js
- type: module
url: /local/slider-entity-row.js
- type: module
url: /local/battery-entity.js?v=0.1
- type: js
url: /local/light-entity-card.js
title: LOGLUX HASSIO
- badges: []
cards:
- entities:
- colors:
- brightness_pct: 25
kelvin: 3670
transition: 1
white_value: 10
- brightness: 126
kelvin: 3670
transition: 1
white_value: 10
- brightness: 186
kelvin: 3670
transition: 1
white_value: 10
- brightness_pct: 100
kelvin: 3670
transition: 1
white_value: 10
rgb_color:
- 215
- 150
- 35
transition: 1
- brightness_pct: 50
rgb_color:
- 215
- 150
- 35
transition: 1
- brightness_pct: 75
rgb_color:
- 215
- 150
- 35
transition: 1
rgb_color:
- 215
- 150
- 35
transition: 1
icon_color: '#1450d7'
rgb_color:
- 20
- 80
- 215
transition: 1
rgb_color:
- 20
- 80
- 215
transition: 1
rgb_color:
- 20
- 80
- 215
transition: 1
rgb_color:
- 20
- 80
- 215
transition: 1
entity: light.arbeitszimmer
justify: between
type: 'custom:rgb-light-card'
- light.arbeitszimmer
- binary_sensor.presence_3
- entity: light.arbeitszimmer
full_row: false
hide_when_off: true
type: 'custom:slider-entity-row'
- attribute: color_temp
full_row: false
show_header_toggle: false
style: |
ha-card {
border-radius: 10px;
type: entities
- entities:
- entity: scene.test
- entity: scene.azevening
style: |
ha-card {
type: entities
- entities:
- light.stehlampe
- entity: light.stehlampe
full_row: false
hide_when_off: true
full_row: false
style: |
ha-card {
type: entities
- entities:
- light.kuchenschrank
- binary_sensor.bewegungsmelder_kueche
- entity: light.kuchenschrank
full_row: false
hide_when_off: true
full_row: false
style: |
ha-card {
type: entities
- entities:
- light.tischlampe
- entity: light.tischlampe
full_row: false
hide_when_off: true
full_row: false
style: |
ha-card {
type: entities
- entities:
- light.kuche
full_row: false
hide_when_off: true
entity: light.kuche
full_row: false
style: |
ha-card {
type: entities
- entities:
- light.innr_terasse
- entity: light.innr_terasse
full_row: false
hide_when_off: true
full_row: false
style: |
ha-card {
type: entities
- entities:
- light.schlafzimmer
- entity: light.schlafzimmer
full_row: false
hide_when_off: 'off'
full_row: false
style: |
ha-card {
type: entities
icon: 'mdi:brightness-6'
panel: false
path: default_view
theme: Backend-selected
title: Home
- badges: []
cards:
- entities:
- entity: sensor.processor_use
hours_to_show: 48
icon: 'mdi:cpu-64-bit'
name: CPU Hassio in %
points_per_hour: 1
show:
graph: bar
style: |
ha-card {
type: 'custom:mini-graph-card'
- entities:
- entity: sensor.rpi_cpu_temperature
hours_to_show: 48
name: CPU Temperature
points_per_hour: 1
show:
graph: bar
style: |
ha-card {
- entities:
- entity: sensor.load_15m
- entity: sensor.load_5m
- entity: sensor.load_1m
height: 65
hours_to_show: 12
icon: 'mdi:download-network'
name: Load last 15/5/1 Minutes
points_per_hour: 1
show:
graph: bar
style: |
ha-card {
- entities:
- entity: binary_sensor.remote_ui
icon: 'mdi:remote-desktop'
secondary_info: last-changed
- entity: sensor.ipv4_address_eth0
icon: 'mdi:ip'
- entity: sensor.last_boot
- entity: sensor.system_id
- entity: sensor.network_throughput_in_eth0
- entity: sensor.network_throughput_out_eth0
- entity: sensor.packets_in_eth0
- entity: sensor.packets_out_eth0
- entity: sensor.swap_free
- entity: sensor.swap_use
- entity: sensor.swap_use_percent
- entity: sensor.disk_free_home
- entity: sensor.disk_use_home
- entity: sensor.snapshot_backup
icon: 'mdi:cloud-upload'
style: |
ha-card {
title: IP / UPTIME / HDD
type: entities
- entities:
- sensor.memory_use_percent
hours_to_show: 48
icon: 'mdi:memory'
line_color: '#ccff00'
name: Mem use in %
points_per_hour: 1
show:
fill: true
graph: bar
style: |
ha-card {
- entities:
- sensor.memory_free
hours_to_show: 48
icon: 'mdi:memory'
points_per_hour: 1
show:
fill: true
graph: bar
style: |
ha-card {
- entities:
- sensor.memory_use
hours_to_show: 48
icon: 'mdi:memory'
points_per_hour: 1
show:
fill: true
graph: bar
style: |
ha-card {
- entities:
- entity: sensor.disk_use_percent_home
hours_to_show: 48
icon: 'mdi:harddisk'
line_color: '#0099ff'
name: Disk use in %
points_per_hour: 1
show:
graph: bar
style: |
ha-card {
- entities:
hours_to_show: 48
name: Disk free in GB
points_per_hour: 1
show:
graph: bar
style: |
ha-card {
- entities:
hours_to_show: 48
name: Disk used in GB
points_per_hour: 1
show:
graph: bar
style: |
ha-card {
- entities:
hours_to_show: 48
icon: 'mdi:server'
line_color: '#c20f3e'
name: Network Throughput IN
points_per_hour: 1
show:
graph: bar
style: |
ha-card {
- entities:
- entity: sensor.network_in_eth0
hours_to_show: 48
icon: 'mdi:upload-network'
name: Net Bandwith IN
points_per_hour: 1
show:
graph: bar
style: |
ha-card {
- entities:
hours_to_show: 48
icon: 'mdi:server'
name: Network Throughput OUT
points_per_hour: 1
show:
graph: bar
style: |
ha-card {
- entities:
- entity: sensor.network_out_eth0
hours_to_show: 48
name: Net Bandwith OUT
points_per_hour: 1
show:
graph: bar
style: |
ha-card {
icon: 'mdi:server'
path: netzwerk
title: SYSTEM
- badges: []
cards:
- cards:
- entities:
- entity: sensor.temperature_18
height: 100
hours_to_show: 24
line_color: '#306080'
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
style: |
ha-card {
- entities:
- entity: sensor.humidity_19
height: 100
hours_to_show: 24
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
style: |
ha-card {
title: Arbeitszimmer
type: horizontal-stack
- cards:
- entities:
- entity: sensor.temperature_20
height: 100
hours_to_show: 24
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
- entities:
- entity: sensor.humidity_21
height: 100
hours_to_show: 24
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
title: Bad
- cards:
- entities:
- entity: sensor.temperature_22
font_size: 100
height: 100
hours_to_show: 24
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
- entities:
- entity: sensor.humidity_23
font_size: 100
height: 100
hours_to_show: 24
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
title: Küche
- cards:
- entities:
- entity: sensor.temperature_16
height: 100
hours_to_show: 24
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
- entities:
- entity: sensor.humidity_17
height: 100
hours_to_show: 24
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
title: Schlafzimmer
- cards:
- entities:
- entity: sensor.temperature_12
font_size: 100
height: 100
hours_to_show: 24
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
- entities:
- entity: sensor.humidity_13
font_size: 100
height: 100
hours_to_show: 24
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
title: Storage
- cards:
- entities:
- entity: sensor.temperature_14
font_size: 100
hours_to_show: 24
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
- entities:
- entity: sensor.humidity_15
height: 100
hours_to_show: 24
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
title: Wohnzimmer
- cards:
- entities:
- entity: sensor.owm_temperature
font_size: 100
height: 100
hours_to_show: 24
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
- entities:
- entity: sensor.owm_humidity
font_size: 100
height: 100
hours_to_show: 24
line_width: 2
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
title: OWM Weather
- cards:
- entities:
- entity: sensor.owm_wind_speed
font_size: 100
height: 50
hours_to_show: 24
icon: 'mdi:weather-windy'
line_width: 2
name: Wind Speed in m/s
points_per_hour: 1
refresh_interval: 0
show:
graph: bar
title: Wind Speed
- entity: weather.openweathermap
type: weather-forecast
- aspect_ratio: 75%
type: iframe
url: >-
https://embed.windy.com/embed2.html?lat=48.878&lon=8.343&zoom=11&level=surface&overlay=temp&menu=&message=true&marker=true&calendar=now&pressure=true&type=map&location=coordinates&detail=true&detailLat=48.878&detailLon=8.343&metricWind=km%2Fh&metricTemp=%C2%B0C&radarRange=-1
icon: 'mdi:home-thermometer'
path: klima-intern
title: Klima Intern
- badges: []
cards:
- entities:
- entity: device_tracker.huawei_mate_20_pro_b964c1_fritz_box
icon: 'mdi:cellphone-android'
name: Mate 20 Pro (NAT)
track: true
- entity: device_tracker.zteaxon7_fritz_box
name: Axon 7 (MIC)
track: true
- entity: device_tracker.huawei_mediapad_m5_lite_1_fritz_box
icon: 'mdi:tablet'
name: Huawei Media Pad Lite
track: true
- entity: device_tracker.raspberrypi_fritz_box_2
icon: 'mdi:server-network'
- entity: device_tracker.fritz_box
icon: 'mdi:router'
- entity: device_tracker.amazon_1f41ee492_fritz_box
icon: 'mdi:remote-tv'
- entity: device_tracker.philips_hue_fritz_box
icon: 'mdi:lamp'
- entity: device_tracker.tv08c40ca0802d_fritz_box
icon: 'mdi:television'
- entity: device_tracker.loglux_pc_fritz_box
icon: 'mdi:monitor-multiple'
- entity: device_tracker.loglux_htpc_fritz_box
title: Netzwerk Devices
type: entities
icon: 'mdi:network'
path: network
title: NETWORK
- badges: []
cards:
- entities:
- entity: binary_sensor.openclose_10
- entity: binary_sensor.openclose_11
title: Türsensoren
type: entities
- entities:
- entity: binary_sensor.presence_3
- entity: automation.bewegung_arbeitszimmer
title: Arbeitszimmer Bewegung
type: entities
- entities:
- entity: binary_sensor.presence_25
- entity: automation.bewegung_schlafzimmer
title: Schlafzimmer Bewegung
type: entities
- entities:
- entity: binary_sensor.bewegungsmelder_kueche
- entity: automation.bewegung_kuche
title: Küche Bewegung
type: entities
- entities:
- entity: automation.bewegung_arbeitszimmer_2_minuten_aus
- entity: automation.bewegung_kuche_2_minuten_aus
- entity: automation.haustur_geoffnet
- entity: automation.terassentur_auf_licht
- entity: automation.terasse_licht_aus
- entity: automation.set_theme_on_start
- entity: automation.delta_trap
title: Automatisierung
type: entities
icon: 'mdi:motion-sensor'
path: movement
title: Movement
- badges: []
cards:
- entities:
- entity: sensor.bewegungsmelder_battery_level
- entity: sensor.bewegungsmelder_kueche_battery_level
- entity: sensor.dimmschalter_battery_level_2
- entity: sensor.thermo_sensor_abstell_battery_level
- entity: sensor.thermo_sensor_arbeitszimmer_battery_level
- entity: sensor.thermo_sensor_schlafzimmer_battery_level
- entity: sensor.thermo_sensor_wohnzimmer_battery_level
- entity: sensor.thermo_sensor_bad_battery_level
name: Thermo Sensor Bad Battery
- entity: sensor.thermo_sensor_kueche_battery_level
name: Thermo Sensor Küche Battery
- entity: sensor.tuerkontaktsensor_az_battery_level
- entity: sensor.tuerkontaktsensor_ht_battery_level
title: Sys Power
type: entities
icon: 'mdi:battery'
path: battery
title: BATTERY
And here the theme for it (put it in themes.yaml):
Navy Blue & Yellow:
### Main Interface Colors ###
primary-color: "#FEB221"
light-primary-color: "#FECA67"
primary-background-color: "#1F2635"
secondary-background-color: var(--primary-background-color)
divider-color: "#2D374D"
### Text ###
primary-text-color: "#FBFBFB"
secondary-text-color: "#FEB221"
text-primary-color: "#FBFBFB"
disabled-text-color: "#4A5E84"
### Sidebar Menu ###
sidebar-icon-color: "#8192B6"
sidebar-text-color: "#FBFBFB"
sidebar-selected-background-color: var(--primary-background-color)
sidebar-selected-icon-color: "#FEB221"
sidebar-selected-text-color: var(--sidebar-selected-icon-color)
### States and Badges ###
state-icon-color: "#FEAA0A"
state-icon-active-color: "#FEF5D8"
state-icon-unavailable-color: var(--disabled-text-color)
### Sliders ###
paper-slider-knob-color: "#FEB221"
paper-slider-knob-start-color: var(--paper-slider-knob-color)
paper-slider-pin-color: var(--paper-slider-knob-color)
paper-slider-active-color: var(--paper-slider-knob-color)
paper-slider-secondary-color: var(--light-primary-color)
### Labels ###
label-badge-background-color: "#3E4C6C"
label-badge-text-color: "#FBFBFB"
label-badge-red: "#252D40"
### Cards ###
paper-card-background-color: "#252D40"
paper-listbox-background-color: var(--primary-background-color)
### Toggles ###
paper-toggle-button-checked-button-color: "#FEB221"
paper-toggle-button-checked-bar-color: "#FECA67"
paper-toggle-button-unchecked-button-color: "#6E81AA"
paper-toggle-button-unchecked-bar-color: "#3E4C6C"
### Table row ###
table-row-background-color: var(--primary-background-color)
table-row-alternative-background-color: var(--secondary-background-color)
Thank for the post.
What do you use to monitor if things are broken/disconnected as in your previous screencap?
I have a entity filter card setup and the filtering condition is setup to look for those that are unavailable or unknown. I mainly use it for my battery powered sensors, switches, etc.
Here’s a sample of how I setup that lovelace card:
- card:
type: entities
entities:
- entity: switch.backyard
- entity: switch.sink
- entity: binary_sensor.back_door
- entity: binary_sensor.front_door
show_empty: false
state_filter:
- 'on'
type: entity-filter
show_empty: false
state_filter:
- 'unavailable'
- 'unknown'
type: entity-filter
Today I added some sensors to my Hassio install on a Intel NUC (3455) with docker. If you guys want to read the temperature of the cores and the speed (in kHz) than you should try this:
# COMMANDLine
- platform: command_line
name: NUC CPU Temperature Core Zone 0
command: "cat /sys/devices/virtual/thermal/thermal_zone0/temp"
value_template: '{{ value | multiply(0.001) | round(2) }}'
name: NUC CPU Temperature Core Zone 2
command: "cat /sys/devices/virtual/thermal/thermal_zone2/temp"
name: NUC CPU Frequency 0
command: "cat /sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq"
name: NUC CPU Frequency 1
command: "cat /sys/devices/system/cpu/cpufreq/policy1/scaling_cur_freq"
My NUC (NUC6CAYH Intel Celeron J3455) shows only 2 CPU core temperatures and speeds (don’t know why).
The system speed is what the Kernel gets from the system in kHz.
But maybe you can work with this information and you will find it useful…have fun!
