System Monitoring - How does yours look?
@johga could you please share the code behind this particular setup?
Hey @AmoebeLabs ,
Can you share your lovelace config for the menu part (Schnelmenu)?
Here’s the YAML for the card and a template using decluttering card. I have some cleanup to do here so disregard any unnecessary code. :slight_smile:
entities:
  - cards:
      - cards:
          - entity: input_boolean.toggle_lovelace_system
            label: System
            show_icon: false
            show_label: true
            show_name: false
            template: bct-header
            type: 'custom:button-card'
        type: horizontal-stack
      - card:
          cards:
            - cards:
                - label: Home Assistant
                  template: bct-topic-horiontal
            - cards:
                - entity: sensor.temperature
                  template: dct-bar-card-up
                  type: 'custom:decluttering-card'
                  variables:
                    - name: Temp
                    - entity: sensor.cpu_temperature
                    - unit: C
                    - icon: 'mdi:thermometer'
                  variables:
                    - name: Minne
                    - entity: sensor.memory_use_percent
                    - unit: '%'
                    - icon: 'mdi:memory'
                  variables:
                    - name: CPU
                    - entity: sensor.processor_use
                    - unit: '%'
                    - icon: 'mdi:cpu-64-bit'
                  variables:
                    - name: Disk
                    - entity: sensor.disk_use_percent_home
                    - unit: '%'
                    - icon: 'mdi:micro-sd'
              style: |
                ha-card {
                  box-shadow: none;
                  margin: 20px
                .card-content {
                  padding: 30px;
                  background: none;
            - cards:
                - entity: sensor.ha_uptime
                  icon: 'mdi:home'
                  template: bct-panel
                - entity: sensor.rpi_uptime
                  template: bct-panel
                - entity: sensor.hass_db_size
                  template: bct-panel
                - entity: sensor.snapshot_backup
                  icon: 'mdi:backup-restore'
                  template: bct-panel
              type: 'custom:hui-horizontal-stack-card'
            - cards:
                - label: Nätverk
            - cards:
                  variables:
                    - name: download
                    - entity: sensor.speedtest_download
                    - unit: Mb/s
                    - icon: 'mdi:download'
                  variables:
                    - name: upload
                    - entity: sensor.speedtest_upload
                    - unit: Mb/s
                    - icon: 'mdi:upload'
                  variables:
                    - name: Ping
                    - entity: sensor.speedtest_ping
                    - unit: '%'
                    - icon: 'mdi:code-tags'
                  variables:
                    - name: Down
                    - entity: sensor.asuswrt_download
                    - unit: '%'
                    - icon: 'mdi:arrow-down-bold-box-outline'
            - cards:
                - label: Miljö
            - cards:
                - entity: sensor.count_automations
                  icon: 'mdi:clipboard-play-outline'
                  template: bct-panel
                - entity: sensor.count_scripts
                  icon: 'mdi:script-text'
                  template: bct-panel
                - entity: sensor.count_sensors
                  icon: 'mdi:scale-balance'
                  template: bct-panel
                - entity: sensor.count_input_booleans
                  icon: 'mdi:toggle-switch-outline'
                  template: bct-panel
            - cards:
                - entity: sensor.count_switches
                  icon: 'mdi:toggle-switch'
                  template: bct-panel
                - entity: sensor.count_device_trackers
                  icon: 'mdi:cellphone-link'
                  template: bct-panel
                - entity: sensor.count_lights
                  icon: 'mdi:lightbulb'
                  template: bct-panel
                - entity: sensor.count_lights_on
                  icon: 'mdi:lightbulb-on'
                  template: bct-panel
          type: 'custom:vertical-stack-in-card'
        conditions:
            state: 'on'
        type: conditional
style: |
  ha-card {
    box-shadow: none;
    background: none;
    margin: 20px
    .card-content {
    padding: 10px;
type: entities
Declutter card template:
  dct-bar-card-up:
    card:
      align: bottom
      animation: 'on'
      bar_style:
        border-radius: 10px
      card_style:
        box-shadow: 0 0
      color: var(--primary-color)
      columns: 1
      decimal: 1
      direction: up
      entity: '[[entity]]'
      height: 100px
      icon: '[[icon]]'
      icon_position: inside
      icon_style:
        color: white
        decoration: none
        height: 30%
        width: 30%
      indicator: 'off'
      indicator_style:
        border-radius: 10px
      padding: 10px 10px 10px 10px
      severity:
        - color: var(--graph-severity-low-color)
          value: 5
        - color: var(--graph-severity-normal-color)
          value: 33
        - color: var(--graph-severity-warning-color)
          value: 66
        - color: var(--graph-severity-critical-color)
          value: 100
      title: '[[name]]'
      title_position: inside
      title_style:
        color: white
        font-size: 12px
        font-weight: normal
        padding: 15px
        text-decoration: none
        text-shadow: 0px 0px 0px black;
        text-transform: lowercase
      type: 'custom:bar-card'
      value_style:
        color: white
        font-size: 12px
        font-weight: normal
      width: 100%
Button Card Template for the Header. The sub-category works the same way with changes to some paramters. The state segement is not used in Settings view, but used in other cards where I display motion detection in some areas. Se picture below (eye icon changes color on motion).
  bct-header:
    hold_action:
      action: more-info
    show_icon: false
    show_label: false
    show_name: false
    show_state: false
    state:
      - styles:
          icon:
            - color: white
            - filter: opacity(20%)
        value: 'off'
      - styles:
          icon:
            - color: white
        value: not_home
      - styles:
          icon:
            - color: white
            - filter: opacity(100%)
        value: 'on'
      - styles:
          icon:
            - color: white
        value: No new messages
    styles:
      card:
        - font-family: 'Raleway,sans-serif'
        - justify-self: start
        - height: 80px
        - background-color: var(--app-header-background-color)
        - border-radius: 0%
        - margin: 0px 0px 0px 0px
      icon:
        - color: white
        - padding-right: 30px
      label:
        - justify-self: center
        - color: white
      state:
        - color: white
        - justify-self: end
        - padding: 15px
@gregtd How did you find these OID`s? Is there a program you used? Could you please explain how you did it?
You can look up a bunch of them here: http://www.oid-info.com/
Late to the party, but here’s mine after some inspiration from this thread.
Work in progress…
Nice! Would you mind sharing the config? thanks
Fixed, had to edit the canvas-gauge-card.js file :slight_smile:
Hello
I love the way you have set up the gauges and I am trying the same. Card Mod is working on other cards, but I cannot get it to be transparent on the gauge or any colour to be honest. Any ideas please? I basically used your code and put in my sensor but no joy
      - type: 'custom:canvas-gauge-card'
        style: |
          ha-card {
            background-color: transparent; border: none; box-shadow: none;
        entity: sensor.rennas_system_temperature
        card_height: 210
        shadow_height: 12%
        font_size: 1em
        gauge:
          type: radial-gauge
          title: WAN Inn
          width: 200
          height: 200
          minValue: 0
          maxValue: 100
          startAngle: 40
          ticksAngle: 280
          valueBox: true
          units: Mb/s
          majorTicks:
            - '0'
            - '10'
            - '20'
            - '30'
            - '40'
            - '50'
            - '60'
            - '70'
            - '80'
            - '90'
            - '100'
          minorTicks: 2
          strokeTicks: true
          highlights:
              to: 100
              color: 'rgba(200, 50, 50, .5)'
          borders: false
          colorPlate: transparent
          colorNeedle: blue
          colorNeedleEnd: blue
          colorBorderOuter: blue
          colorBorderInner: blue
          colorNeedleCircleOuter: blue
          colorNeedleCircleOuterEnd: blue
          colorNeedleCircleInner: blue
          colorNeedleCircleInnerEnd: blue
          needleType: arrow
          needleShadow: false
          needleWidth: 2
          needleCircleSize: 7
          needleCircleOuter: false
          needleCircleInner: true
@MarkR is the same problem for me with the card
replacing line 70 in canvas-gauge-card.js: and deleting the canvas-gauge-card.js.gz
background-color: white !important;
with
background-color: var( --ha-card-background, var(--paper-card-background-color, white) ); !important;
I tried your code and wifi signal shows no values for me. Is there any additional documentation for iwconfig? Does this work in Hassio?
Here’s mine, i gather code and guidance from this forum mostly. Still work in progress though…
@MarkR
Hi bud, I had to edit the card itself, as it has a style of ‘background-color: white !important;’
So I changed it like this (but a bad idea as an update of the card will reverse this):
            <style>
                :host {
                    box-shadow: 0 2px 2px 0 rgba(0, 0, 0, 0.0), 0 1px 5px 0 rgba(0, 0, 0, 0.0), 0 3px 1px -2px rgba(0, 0, 0, 0.0);
                    display: block !important;
                    border-radius: 2px !important;
                    transition: all 0.30s ease-out !important;
                    background-color: transparent !important;
Normally, I would assume card-mod should handle this using
                style |
                  :host {
But for some reason me neither can get it to work.
Perhaps @thomasloven who’s the genius behind card-mod could give us a helping hand…
Thomas; if you read this, it is about the ‘canvas-gauge-card’
Could you please share the code for the RPi system monitor?
Could you please share the code for your bars, would like to monitor my nas the same way
I used this https://github.com/Sennevds/system_sensors
sure
cards:
  - cards:
      - entities:
          - sensor.rpi3cpuusage
        hours_to_show: 24
        line_color: '#2980b9'
        line_width: 2
        type: 'custom:mini-graph-card'
      - entities:
          - sensor.rpi3temperature
        hours_to_show: 24
        line_width: 2
  - align: split
    entity: sensor.rpi3diskuse
    max: 22
    severity:
      - color: '#ff0000'
        value: 5
      - color: '#00ba6a'
        value: 15
    show_icon: true
    title: HDD
  - align: split
    entity: sensor.rpi3extmedia_use
    max: 489
    severity:
      - color: '#ff0000'
        value: 15
      - color: '#ff8000'
        value: 40
    show_icon: true
    title: ExtHDD1
  - align: split
    entity: sensor.rpi3extdata_use
    max: 444
    severity:
      - color: '#ff8000'
        value: 40
      - color: '#40bf40'
        value: 60
    show_icon: true
    title: ExtHDD2
  - align: split
    entity: sensor.rpi3memoryuse
    show_icon: true
    title: RAM
  - entities:
      - sensor.rpi3lastboot
      - sensor.rpi3powerstatus
    type: entities
title: RPI3 System Monitor
@poudenes Would you mind sharing how you get the information for TP-Link Deco M5? As far as I can tell these routers do not support SNMP…
It discovered my tp link :slight_smile:
