System Monitoring - How does yours look?
Edit: small update
Excellent DrTube
Please, how do you get information and manage Proxmox (CPU/Ram/CPu temp / VM) ?
And could you share your card config
For Proxmox info I have installed Glances on Proxmox itself. The VMs are from the HA integration, just sensors so no control.
Otherwise: some code for you:
cards:
  - image: /local/proxmox.png
    type: picture
  - entities:
      - decimal: 0
        entity: sensor.glances_cpu_used
        entity_row: true
        height: 25
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 50
          - color: '#F4B400'
            to: 80
          - color: '#DB4437'
            to: 100
        type: 'custom:bar-card'
      - decimal: 0
        entity: sensor.glances_ram_used
        entity_row: true
        height: 25
        max: 32000
        min: 0
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 20000
          - color: '#F4B400'
            to: 26000
          - color: '#DB4437'
            to: 32000
        unit_of_measurement: MB
      - entity: sensor.glances_package_id_0_temp
        entity_row: true
        height: 25
        max: 100
        min: 0
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 70
          - color: '#F4B400'
            to: 85
          - color: '#DB4437'
            to: 100
      - entities:
          - entity: binary_sensor.proxmox_homeassistant_running
          - entity: binary_sensor.proxmox_openmediavault_running
          - entity: binary_sensor.proxmox_windows10_running
        entity: binary_sensor.proxmox_tuya_convert_running
        icon: 'mdi:server-network'
        state_header: Tuya
        type: 'custom:multiple-entity-row'
    type: entities
  - image: /local/speedtest2.png
    type: picture
  - aggregate_func: max
    align_state: center
    animate: true
    decimals: 0
    entities:
      - entity: sensor.speedtest_download
        index: 0
      - entity: sensor.speedtest_upload
        index: 1
    font_size: 100
    font_size_header: 14
    group_by: interval
    height: 150
    hour24: true
    hours_to_show: 6
    lower_bound: 0
    points_per_hour: 2
    show:
      graph: line
      icon: false
      labels: true
      legend: false
      points: true
      state: true
    smoothing: false
    tap_action:
      action: call-service
      service: speedtestdotnet.speedtest
    type: 'custom:mini-graph-card'
title: false
type: 'custom:vertical-stack-in-card'
cards:
  - image: /local/HA5.png
    type: picture
  - entities:
      - decimal: 0
        entity: sensor.processor_use
        entity_row: true
        height: 25
        icon: 'mdi:cpu-64-bit'
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 50
          - color: '#F4B400'
            to: 80
          - color: '#DB4437'
            to: 100
      - decimal: 0
        entity: sensor.memory_use
        entity_row: true
        height: 25
        max: 4096
        min: 0
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 3072
          - color: '#F4B400'
            to: 3600
          - color: '#DB4437'
            to: 4096
      - decimal: 0
        entity: sensor.disk_use
        entity_row: true
        height: 25
        max: 29
        min: 0
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 20
          - color: '#F4B400'
            to: 25
          - color: '#DB4437'
            to: 29
        unit_of_measurement: GB
      - decimal: 0
        entity: sensor.hass_db_size
        entity_row: true
        height: 25
        icon: 'mdi:database'
        max: 1024
        min: 0
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 700
          - color: '#F4B400'
            to: 900
          - color: '#DB4437'
            to: 1024
      - entity: sensor.uptime
      - entity: sensor.last_boot
      - entities:
          - entity: sensor.latest_available_version
            style: |
              :host {
                {% if states(config.entity).split('.')[1] != states('sensor.latest_available_version').split('.')[1] %}
                  color: rgb(255, 165, 0);
                  --paper-item-icon-color: rgb(255, 165, 0);
                {% endif %};
        entity: sensor.current_version
        icon: 'mdi:home-assistant'
        state_header: Current
      - entity: sensor.supervisor_updates
        icon: 'mdi:cart-plus'
        style: |
          :host {
            {% if states(config.entity) != '0' %}
            {% endif %};
        tap_action:
          action: navigate
          navigation_path: /hassio/dashboard
      - action: navigate
        entity: sensor.hacs
        navigation_path: /hacs/installed
        style: |
          :host {
            {% endif %};
        tap_action: null
      - entity: sensor.snapshot_backup
    type: entities
  - image: /local/Adguard.png
    type: picture
  - entities:
      - entities:
          - entity: sensor.adguard_dns_queries
          - entity: sensor.adguard_dns_queries_blocked_ratio
        entity: switch.adguard_protection
        icon: 'mdi:shield-check'
        state_header: Adguard
    type: entities
title: false
cards:
  - image: /local/omv3.png
    type: picture
  - entities:
      - decimal: 0
        entity: sensor.omv_cpu_load
        entity_row: true
        height: 25
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 50
          - color: '#F4B400'
            to: 80
          - color: '#DB4437'
            to: 100
      - decimal: 0
        entity: sensor.omv_memory
        entity_row: true
        height: 25
        max: 100
        min: 0
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 70
          - color: '#F4B400'
            to: 90
          - color: '#DB4437'
            to: 100
      - entity: sensor.omv_data
        entity_row: true
        height: 25
        icon: 'mdi:harddisk'
        max: 100
        min: 0
        name: OMV SSD Data
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 70
          - color: '#F4B400'
            to: 90
          - color: '#DB4437'
            to: 100
      - entity: sensor.omv_downloads
        entity_row: true
        height: 25
        max: 100
        min: 0
        name: OMV SSD Downloads
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 70
          - color: '#F4B400'
            to: 90
          - color: '#DB4437'
            to: 100
      - entity: sensor.omv_movies
        entity_row: true
        height: 25
        max: 100
        min: 0
        name: OMV HDD Movies
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 70
          - color: '#F4B400'
            to: 90
          - color: '#DB4437'
            to: 100
      - entity: sensor.omv_movies2
        entity_row: true
        height: 25
        max: 100
        min: 0
        name: OMV HDD Movies2
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 70
          - color: '#F4B400'
            to: 90
          - color: '#DB4437'
            to: 100
      - entity: sensor.omv_movies3
        entity_row: true
        height: 25
        max: 100
        min: 0
        name: OMV HDD Movies3
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 70
          - color: '#F4B400'
            to: 90
          - color: '#DB4437'
            to: 100
      - entity: sensor.omv_series
        entity_row: true
        height: 25
        max: 100
        min: 0
        name: OMV HDD Series
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 70
          - color: '#F4B400'
            to: 90
          - color: '#DB4437'
            to: 100
      - entities:
          - entity: sensor.omv_uptime
        entity: binary_sensor.omv_update_available
        icon: 'mdi:nas'
        state_header: Update
    type: entities
  - image: /local/portainer.png
    type: picture
  - type: entities
    entities:
      - decimal: 0
        entity: sensor.docker_omv_cpu
        entity_row: true
        height: 25
        name: OMV Docker CPU%
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 50
          - color: '#F4B400'
            to: 80
          - color: '#DB4437'
            to: 100
      - decimal: 0
        entity: sensor.docker_omv_memory
        entity_row: true
        height: 25
        max: 8192
        min: 0
        name: OMV Docker RAM%
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 6000
          - color: '#F4B400'
            to: 7000
          - color: '#DB4437'
            to: 8192
      - entities:
          - entity: sensor.docker_omv_containers_running
            style: |
              :host {
                {% endif %};
        entity: sensor.docker_omv_containers_total
        icon: 'mdi:docker'
        name: OMV Docker Containers
        state_header: Total
      - entities:
          - entity: sensor.sabnzbd_queue_count
        entity: sensor.sabnzbd_speed
        icon: 'mdi:download'
        state_header: Speed
title: false
cards:
  - image: /local/synology2.jpg
    type: picture
  - entities:
      - entity: sensor.synology_cpu_load_total
        entity_row: true
        height: 25
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 50
          - color: '#F4B400'
            to: 80
          - color: '#DB4437'
            to: 100
      - entity: sensor.synology_memory_usage_real
        entity_row: true
        height: 25
        max: 100
        min: 0
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 70
          - color: '#F4B400'
            to: 90
          - color: '#DB4437'
            to: 100
      - entity: sensor.synology_used_space_volume_1
        entity_row: true
        height: 25
        max: 3.58
        min: 0
        positions:
          icon: inside
        severity:
          - color: '#0F9D58'
            to: 2.5
          - color: '#F4B400'
            to: 3
          - color: '#DB4437'
            to: 3.58
    type: entities
  - entities:
      - entity: sensor.synology_network_up
    entity: sensor.synology_network_down
    icon: 'mdi:speedometer'
    state_header: Download
title: false
I use this guide to monitor Proxmox and used MQTT to share it with HA: https://kleypot.com/proxmox-home-assistant-host-system-hardware-monitoring/
It’s not that heavy as glances.
Thanks for your answer.
I prefer MQTT also
i have installed that and added to the configuration how can i add the temp etc to the lovelace?
How do you use these horizontal “load” bars? I think they’re a nice alternative instead of the standard gauge card :slight_smile:
These standard gauges take up way too much space.
I have my battery tab posted on my repo:
Can you share your sensors and config ? :smiley:
Almost none of that is still current I’m afraid. A lot has changed in 18 months!
I don’t use that clock anymore (but you will find it elsewhere on the forum I think)
I don’t use a Raspberry Pi anymore
HaveIBeenPwned is no longer available
And the updates predate HACS
Sorry I couldn’t help…
You don’t use anymore “Component Count” card and “Updates” card, and “System” card ?
I’m looking ti find how to declare all this sensor and cards :slight_smile:
I don’t use the Updates card because it is obsolete now that I use HACS.
My System card was made up of sensors that were based on an RPi but I don’t use an RPi anymore.
And component counts I don’t use anymore like that but you can use this (adjust it for whatever components you want a count of)
      count_automations:
        entity_id: sensor.date
        value_template: "{{ states.automation | count }}"
So this is currently my monitoring tab. It’s still a work in progress, as I don’t have that many smart home devices yet. But it’s becoming more and more :grin:
What icons are those?
Those are just images from google. I use them with Entity_picture in my customize.yaml
Oh i thought you had downloaded them in a pack or something
Nope. They don’t work in the mini graph card either. Or I just can’t figure out how :sweat_smile:
Just the graphs, ma’am. Config link in my profile.
looks really nice!
can you share your code?
can you explain how did you create the header in the same card?
Thanks.,
For the header, I just “made” some logos for this purpose…
