System Monitoring - How does yours look?
Indeed. I was discussing this a while ago with @philhawthorne who created HA Dockermon. It is a very interesting feature, which I think many users would like to have.
The problem is that it seems that it does not work with all the images. In my limited testing I couldn’t get it to work for deconz and ozwdaemon for example. But could as well be that I did something wrong. I’ll open an issue on the monitor docker repo and see if I can discuss it with the dev.
Edit: Opened an issue here
First of all, @Burningstone, ty for your post with the script, it inspired me to do the same.
I tried to set this up, started with the unifi-controller as is runs outside my supervised install.
Couldn´t get it to work though, ends up with a error payload to mqtt.
Would you mind taking a look?
Sure I can take a look at it later today/during the weekend
Try changing your docker_check_list.txt to
unifi,ryansch/unifi-rpi,ryansch/unifi-rpi
The thrid parameter is the field image: in your docker-compose file minus the :latest, which is ryansch/unifi-rpi not unifi.
Yeah, that did it, that was the culprit. Ty!
Are you running all those docker containers in your example outside of HA supervisor?
I’m on a supervised install and supervisor is controlling them for me, I can’t really get information about versions with the script for those containers, right?
I just have a few that I manage with docker-compose myself, unifi and portainer.
Any ty for your great exemple, you don’t happen to have the code that system view up on github or so?
I don’t run Supervised, I run Home Assistant Container.
I’m currently checking this on a test instance that runs Supervised, will see if I get it to work.
My repo is here, however, I haven’t uploaded the system monitoring, need to write the guide on how to get the sensors etc. first, but should be there in the next 2-3 weeks.
Would you mind sharing your lovelace place?
See the post above with the link to my repo, I’ll upload the system monitoring lovelace config and guide soon.
My monitoring page, work in progress :slight_smile:
@Tseven @dinth
I uploaded the configu including documentation to my Github Repo. The lovelace config is here.
You’ve put more time and effort into your Git repo than I have on my Lovelace config! Nice. That VLAN info should help me out a fair bit as that is what I’m sorting out at the moment.
Yeah VLAN took me a while as well to get it sorted out. I plan to write a guide on this as well at one point, but first finish the HA setup guide/docu :sweat_smile: :rofl: Haven’t really digged into Lovelace yet, so there’s a whole lot stuff coming at me.
Great, what a 5 star write up!
Now I got I plenty of inspiration for spending more time with HA :computer::see_no_evil: :smiley:
Lets see if I can figure out how you got the USG and AP-info into sensors :smiley:
Some more progress on my side.
Network View (PiHole enabled):
Network View (PiHole disabled + Details expanded)
Device Tracker View:
What do you guys think?
That looks awesome!
Indeed it does…
Time to redo mine I think, it looks so 2019.
And I plan to read it if that is any incentive to make ‘at one point’ any sooner :wink:
It’s here in my “KanBan” board now :rofl:
Baby steps…
:slight_smile:
