It’ the same here, so likely you could find out the one to use by browsing the logs. Search for ’ eth0’ (I had several tens of occurrances) and see the one that differs from those multiple entries veth… I had this line
e1000e 0000:00:1f.6 eno1: renamed from eth0
. Tried ‘eno1’ and it works.
I tried a search but didn’t get any hits other than the ‘vethxxxx’ type stuff
Have you tried just hassio for interface name? I was struggling for ages to find interface name in my VM running on ESXi and found this trick somewhere in the forum… Funny is that it is not listed by any system command as valid interface name… But it is working for me
I’ll give it a shot and report back. Thanks.
Seems that both work in my HA OS setup. This is just after the server restart:
Odd that they are different values though…
How did you add all the graphs into one container?
I found an easy way to determine the ethernet interface, SSH into HA and it’s listed straight away. Mine ended up being eno1.
Thanks for the pointers
How is the networking done in HASSIO docker container? By default docker uses bridges to provide networking - thus is eno1 the real network port and hassio is the docker bridge to it?
Hi Bill , it does not work with HASSIO
Hello, I can’t install a python on the Raspberry with HomematicMatic. someone an idea how I can represent the sensors of the Raspberry with the image
hey bigstation,
very nice and clean dashboard.
Do you mind to share how you count the connected clients on wifi?
thanks
@Djal what did you use for the horizontal Bar graphs? Do you mind sharing your YAML? it looks great!
Hi, it is just a custom bar-card and mini-graph-card both in horizontal-stack card, and all of that inside a vertical stack-in card.
Here is the yaml:
type: 'custom:vertical-stack-in-card'
cards:
- type: horizontal-stack
title: Monitor
cards:
- type: 'custom:mini-graph-card'
hours_to_show: 12
points_per_hour: 2
animate: true
hour24: true
height: 150
entities:
- sensor.pi1_cpu_usage
state_adaptive_color: true
show_state: true
line_color: '#28A95D'
line_width: 7
color_thresholds:
- value: 20
color: '#28A95D'
- value: 40
color: '#179FE7'
- value: 60
color: '#E5DF26'
- value: 80
color: '#E58B26'
- value: 90
color: '#EF302A'
show:
extrema: true
name_adaptive_color: true
icon_adaptive_color: true
hours_to_show: 12
points_per_hour: 2
height: 150
animate: true
hour24: true
entities:
- sensor.pi1_temperature
line_width: 7
color_thresholds:
- value: 20
color: '#28A95D'
- value: 40
color: '#179FE7'
- value: 60
color: '#E5DF26'
- value: 80
color: '#E58B26'
- value: 90
color: '#EF302A'
show:
extrema: true
cards:
- type: 'custom:bar-card'
entity: sensor.pi1_disk_use_drive1
decimal: 0
height: 40
show_icon: true
icon: 'mdi:harddisk'
color: '#00ba6a'
severity:
- color: '#28A95D'
to: 20
- color: '#179FE7'
to: 40
- color: '#EDCC26'
to: 60
- color: '#E58B26'
to: 80
- color: '#EF302A'
to: 100
entity: sensor.pi1_memory_use
height: 40
icon: 'mdi:memory'
show_icon: true
severity:
- color: '#28A95D'
to: 20
- color: '#179FE7'
to: 40
- color: '#DDD44B'
to: 60
- color: '#EDCC26'
to: 80
- color: '#EF302A'
to: 100
cards:
- type: entities
entities:
- entity: sensor.pi1_last_message
- type: entities
entities:
- entity: sensor.pi1_last_boot
@Djal, The double nested card layout… I know it well. I use the mini-graph card a ton, but didn’t recognize the bar-card. So Thanks for sharing!!
Hi Tom,
Could you share your YAML for the automations screen?
Here is my updates dashboard. Its highly inspired by some of the things posted here. And its split up in categories.
Homepage:
HomeAssistant page:
Network page:
Network page with drives extended:
Devicetracker page:
Devices page:
Power monitoring page:
Not for a couple of weeks. I’m at sea with no access to my Home Assistant at the moment.
Very very cool setup you got there.
