They do not. I’m sure that is the issue. None of the sensors give the correct information on developers tools. Not sure why this was changed?
I can get most of the information other ways, just does not display as well.
I spoke to soon. I believe most of the sensors do still work, just not in the markdown card. Hacs sensor changed but not sure why this would stop the card?
I’m not sure how to test the whole card in Del tools? When I paste the card there I get TypeError: ‘NoneType’ object is not iterable.
The bottom from | current below works in dev tools.
this is somewhat cryptic…
any jinja template that works in dev tools, works in Markdown.
if you have borked command_line sensors, no template based on that will work.
as you stated, most if this info can be had from the core integrations now. You can still template those nicely, or have them show via other means, no issue there.
it would save you some (maybe most) tailor made sensors, who using the built-in supervisor sensors, so why not give that a try? It would release the system just that extra bit
Guys you are really spamming this thread, what about opening a new one for your issue.
sure, guess you’re right.
otoh, you started posting thing like this yourself System Monitoring - How does your look? - #1049 by alanmilinovic
Yea but my scripts and configuration is working.
Sorry for this. Mine just stopped working with the only change on my part being updating to 2023.4x. I have found the issue (hacs sensor change) and will post a fix once / if I figure it out.
For all those that are interested or helped, my issue was caused by changing Hacs to experimental mode. I did this after 2023.4.2 was released to use the new import macro function.This made the sensor.hacs unavailable.
I know its too old , but how to get the news section ? can you share some tips ? @elRadix if you happened to achieve it , can you share ? thank you!
use the feedreader as detailed here: Feedreader - Home Assistant
but my goodness you are right, that is old… here is the latest
OMG, that looks wonderful, mind sharing the code ?
sure, herewith, this will however obviously not work as you need to configure the sensors and images and store these in the appropriate sections
- theme: Backend-selected
title: Control
path: control
icon: mdi:gauge-low
background: center / cover no-repeat url("/local/img/control.jpg") fixed
visible:
- user: [REDACTED]
- user: [REDACTED]
badges: []
cards:
- cards:
- image: /local/img/synology_logo.png
tap_action:
action: url
url_path: https://[REDACTED].[REDACTED].[REDACTED]
type: picture
- entities:
- entity: binary_sensor.[REDACTED]_security_status
type: entities
- cards:
- color_thresholds:
- color: '#B20000'
value: 99
- color: '#FF7F00'
value: 50
- color: '#008C23'
value: 1
entities:
- entity: sensor.[REDACTED]_cpu_utilization_total
icon: mdi:chip
points_per_hour: 60
type: custom:mini-graph-card
- color_thresholds:
- color: '#B20000'
value: 99
- color: '#FF7F00'
value: 50
- color: '#008C23'
value: 1
entities:
- entity: sensor.[REDACTED]_memory_usage_real
icon: mdi:chip
points_per_hour: 60
type: custom:vertical-stack-in-card
horizontal: true
- cards:
- entities:
- entity: sensor.[REDACTED]_upload_throughput
icon: mdi:arrow-up
points_per_hour: 60
- entities:
- entity: sensor.[REDACTED]_download_throughput
icon: mdi:arrow-down
points_per_hour: 60
horizontal: true
- cards:
- color_thresholds:
- color: '#B20000'
value: 50
- color: '#FF7F00'
value: 40
- color: '#008C23'
value: 30
entities:
- entity: sensor.[REDACTED]_volume_3_average_disk_temp
icon: mdi:thermometer
points_per_hour: 60
- color_thresholds:
- color: '#B20000'
value: 50
- color: '#FF7F00'
value: 40
- color: '#008C23'
value: 30
entities:
- entity: sensor.[REDACTED]_volume_2_average_disk_temp
points_per_hour: 60
horizontal: true
- bar_style:
padding-left: 2px
text-align: left
entity: sensor.[REDACTED]_volume_3_volume_used
height: 40px
max: 100
min: 0
severity:
- color: '#00D936'
to: 50
- color: '#FFBF00'
to: 75
- color: '#B20000'
to: 100
icon: mdi:harddisk
name_position: inside
type: custom:bar-card
- entities:
- entity: sensor.[REDACTED]_volume_3_used_space
- entity: sensor.[REDACTED]_volume_3_status
type: glance
- bar_style:
padding-left: 2px
text-align: left
entity: sensor.[REDACTED]_volume_2_volume_used
height: 40px
max: 100
min: 0
severity:
- color: '#00D936'
to: 50
- color: '#FFBF00'
to: 75
- color: '#B20000'
to: 100
icon: mdi:harddisk
- entities:
- entity: sensor.[REDACTED]_volume_2_used_space
- entity: sensor.[REDACTED]_volume_2_status
type: glance
- type: custom:vertical-stack-in-card
cards:
- type: picture
image: /local/img/ubiquiti-networks-logo.png
tap_action:
action: none
hold_action:
action: none
- cards:
- color_thresholds:
- color: '#B20000'
value: 70
- color: '#FF7F00'
value: 25
- color: '#008C23'
value: 5
entities:
- entity: sensor.unifi_status_wan_cpu
points_per_hour: 60
hours_to_show: 168
- color_thresholds:
- color: '#B20000'
value: 70
- color: '#FF7F00'
value: 25
- color: '#008C23'
value: 5
entities:
- entity: sensor.unifi_status_wan_mem
points_per_hour: 60
hours_to_show: 168
type: custom:stack-in-card
mode: horizontal
- cards:
- entities:
- entity: sensor.gateway_www_down
- entity: sensor.gateway_www_up
icon: mdi:arrow-up
points_per_hour: 60
- entities:
- entity: sensor.internet_latency
icon: mdi:clock
points_per_hour: 60
horizontal: true
- entities:
- entity: sensor.unifi_status_wan_ip
name: WAN IP Address
type: entities
- type: glance
entities:
- entity: sensor.unifi_gateway_wan
- entity: sensor.unifi_gateway_wlan
- entity: sensor.unifi_gateway_www
- entity: sensor.gateway_www_down_count
- entity: sensor.gateway_www_up_count
- entity: sensor.unifi_status_lan_num_user
- entity: sensor.wifi_clients
- entity: sensor.wifi_guests
- entity: sensor.unifi_gateway_alerts
- entity: sensor.gateway_ap
- entity: sensor.ap_disabled
- entity: sensor.ap_disconnected
name: AP Disconnected
- entity: sensor.wlan_down_count
- entity: sensor.wlan_up_count
- entity: sensor.unifi_gateway_firmware_upgradable
- cards:
- image: /local/img/ha-logo.png
type: picture
- cards:
- color_thresholds:
- color: '#B20000'
value: 70
- color: '#FF7F00'
value: 25
- color: '#008C23'
value: 5
entities:
- entity: sensor.processor_use
points_per_hour: 60
hours_to_show: 168
- color_thresholds:
- color: '#B20000'
value: 70
- color: '#FF7F00'
value: 25
- color: '#008C23'
value: 5
entities:
- entity: sensor.memory_use_percent
points_per_hour: 60
hours_to_show: 168
mode: horizontal
- bar_style:
padding-left: 2px
text-align: left
entity: sensor.disk_use_percent_home
height: 40px
max: 100
min: 0
severity:
- color: '#00D936'
to: 50
- color: '#FFBF00'
to: 75
- color: '#B20000'
to: 100
title: Disk
- entities:
- sensor.last_boot
- sensor.database_size
- sensor.hacs
type: glance
- type: markdown
title: null
content: Devices & Sernsors
- type: custom:apexcharts-card
chart_type: donut
apex_config:
fill:
type: gradient
gradient:
shade: dark
shadeIntensity: 0.1
opacityFrom: 0.9
opacityTo: 0.85
stops:
- 0
- 90
- 100
legend:
position: right
fontSize: 13px
fontWeight: 300
markers:
width: 16
height: 25
customHTML:
EVAL:() => {
return `<ha-icon icon="hass:robot" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:radiobox-blank" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:account" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:camera" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:lightbulb" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:flower" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:flash" style="--mdc-icon-size: 14px;"></ha-icon>`
EVAL:() => {
return `<ha-icon icon="hass:home-assistant" style="--mdc-icon-size: 14px;"></ha-icon>`
fillColors:
- none
- none
- none
- none
- none
- none
- none
- none
stroke:
show: true
width: 0.4
dataLabels:
enabled: false
style:
fontSize: 14px
fontWeight: 700
dropShadow:
enabled: true
top: 0
left: 0
blur: 3
color: black
opacity: 0.1
plotOptions:
pie:
startAngle: 0
endAngle: 360
expandOnClick: true
offsetX: 0
offsetY: 0
customScale: 1
dataLabels:
offset: 0
minAngleToShowLabel: 10
donut:
background: transparent
labels:
show: true
value:
fontSize: 42px
fontWeight: 700
offsetY: 16
total:
show: true
label: Entities
fontSize: 15px
fontWeight: 800
color: '#ffffff50'
series:
- entity: sensor.count_automations
- entity: sensor.count_binary_sensors
- entity: sensor.count_device_trackers
- entity: sensor.count_cameras
- entity: sensor.count_lights
- entity: sensor.count_plants
- entity: sensor.count_sensors
- entity: sensor.count_switches
- entity: sensor.count_zones
- entity: sensor.count_scripts
- entity: sensor.count_zwave
- entity: sensor.count_lock
- entity: sensor.count_vacuum
- entity: sensor.count_media_players
cards:
- type: picture
image: local/img/chirpstack_logo.png
- type: custom:uptime-card
icon: mdi:router-wireless
ok: ONLINE
ko: OFFLINE
ko_icon: mdi:router-wireless-off
hours_to_show: 168
status_adaptive_color: true
bar:
spacing: 4
height: 10
round: 10
color:
icon: grey
show:
icon: true
status: false
timeline: true
average: true
title_adaptive_color: true
title: Gateway Uptime
bar:
spacing: 4
height: 10
round: 10
ok: ONLINE
ko: OFFLINE
hours_to_show: 168
color:
icon: grey
show:
icon: true
status: false
timeline: true
average: true
ok: ONLINE
ko: OFFLINE
hours_to_show: 168
bar:
spacing: 4
height: 10
round: 10
color:
icon: grey
show:
icon: true
status: false
timeline: true
average: true
ok: ONLINE
ko: OFFLINE
hours_to_show: 168
bar:
spacing: 4
height: 10
round: 10
color:
icon: grey
show:
icon: true
status: false
timeline: true
average: true
ok: ONLINE
ko: OFFLINE
hours_to_show: 168
bar:
spacing: 4
height: 10
round: 10
color:
icon: grey
show:
icon: true
status: false
timeline: true
average: true
ok: ONLINE
ko: OFFLINE
hours_to_show: 168
bar:
spacing: 4
height: 10
round: 10
color:
icon: grey
show:
icon: true
status: false
timeline: true
average: true
ok: ONLINE
ko: OFFLINE
hours_to_show: 168
bar:
spacing: 4
height: 10
round: 10
color:
icon: grey
show:
icon: true
status: false
timeline: true
average: true
ok: ONLINE
ko: OFFLINE
hours_to_show: 168
bar:
spacing: 4
height: 10
round: 10
color:
icon: grey
show:
icon: true
status: false
timeline: true
average: true
ok: ONLINE
ko: OFFLINE
hours_to_show: 168
bar:
spacing: 4
height: 10
round: 10
color:
icon: grey
show:
icon: true
status: false
timeline: true
average: true
ok: ONLINE
ko: OFFLINE
hours_to_show: 168
bar:
spacing: 4
height: 10
round: 10
color:
icon: grey
show:
icon: true
status: false
timeline: true
average: true
cards:
- type: picture
image: /local/img/uptime-robot.png
tap_action:
action: url
url_path: https://uptimerobot.com
hold_action:
action: none
- type: entities
entities:
- entity: binary_sensor.[REDACTED]_home_assistant
- entity: binary_sensor.[REDACTED]_plex
- entity: binary_sensor.[REDACTED]_tld
- entity: binary_sensor.[REDACTED]_3cx
- entity: binary_sensor.[REDACTED]_chirpstack
- entity: binary_sensor.[REDACTED]_odoo
- entity: binary_sensor.[REDACTED]_tracker
- entity: binary_sensor.[REDACTED]_website
- card:
show_header_toggle: false
title: Low Battery Devices
type: entities
state_color: true
header:
type: picture
image: local/img/battery_low.png
tap_action:
action: none
hold_action:
action: none
filter:
exclude:
- entity_id: '*Schenzhen*'
- entity_id: '*last_updated*'
- entity_id: '*plant*'
- entity_id: sensor.finn_s_owlet_heart_rate
- entity_id: sensor.finn_s_owlet_oxygen_level
- entity_id: sensor.neo_coolcam_battery_powered_pir_sensor_v2_alarm_level
- entity_id: sensor.neo_coolcam_battery_powered_pir_sensor_v2_alarm_type
- entity_id: sensor.neo_coolcam_battery_powered_pir_sensor_v2_burglar
- entity_id: sensor.neo_coolcam_battery_powered_pir_sensor_v2_sourcenodeid
- entity_id: sensor.neo_coolcam_battery_powered_pir_sensor_v2_alarm_level_2
- entity_id: sensor.neo_coolcam_battery_powered_pir_sensor_v2_alarm_type_2
- entity_id: sensor.neo_coolcam_battery_powered_pir_sensor_v2_burglar_2
- entity_id: sensor.neo_coolcam_battery_powered_pir_sensor_v2_sourcenodeid_2
include:
- entity_id: '*battery*'
state: < 5%
- attributes:
battery: < 5%
- attributes:
battery_level: < 5
show_empty: true
type: custom:auto-entities
sort:
method: friendly_name
- type: entities
entities:
- entity: binary_sensor.fridge
- entity: sensor.fridge_battery
- entity: sensor.fridge_signal
- entity: sensor.fridgex_snr
- entity: sensor.fridge_battery_percentage
- entity: sensor.fridge_gateway
title: Fridge
cards:
- type: picture
image: /local/img/canon_printer_logo.png
tap_action:
action: url
url_path: http://REDACTED/portal_top.html
hold_action:
action: none
- type: entities
entities:
- entity: sensor.printer
- cards:
- bar_style:
padding-left: 2px
text-align: left
entity: sensor.printer_black_toner
height: 175px
direction: up
max: 100
min: 0
color: black
- bar_style:
padding-left: 2px
text-align: left
entity: sensor.printer_yellow_toner
height: 175px
direction: up
max: 100
min: 0
color: yellow
- bar_style:
padding-left: 2px
text-align: left
entity: sensor.printer_magenta_toner
height: 175px
direction: up
max: 100
min: 0
color: magenta
- bar_style:
padding-left: 2px
text-align: left
entity: sensor.printer_cyan_toner
icon: mdi:water
icon_color: '#000000'
height: 175px
direction: up
max: 100
min: 0
color: cyan
type: grid
columns: 4
square: false
horizontal: true
- type: entities
entities:
- entity: switch.kettle
- entity: switch.kettle_keep_warm
- entity: sensor.kettle_temperature
- entity: sensor.kettle_setpoint
- entity: sensor.kettle_state
- entity: sensor.kettle_volume
you should however just be able to dump the above into your RAW configuration editor and then configure in the UI from there…
Thanks… it works perfectly… Just one think, the sensors used in the ubiquity, mind sharing the yaml file for that. I have most working, but can figure out how you pull the latency avarge…
you will need to check that add-on’s supporting pages and forums as it will all depend on a number of variables, like usg vs udm vs udmpro vs cloud key etc etc etc
I got that part working, it’s just the logic in getting the data for that value. (latency avarge)
Not working
unifi_status_wan_latency_average:
friendly_name: 'latency average'
value_template: '{{ states.sensor.unifi_status_wan.attributes.latency_average }}'
working
unifi_status_wan_ip:
friendly_name: 'WAN IP'
value_template: '{{ states.sensor.unifi_status_wan.attributes.wan_ip }}'
this?
internet_latency:
friendly_name: 'Internet Latency'
value_template: '{{ states.sensor.unifi_gateway_www.attributes.latency }}'
unit_of_measurement: ms
unique_id: internet_latency
You’d want to use state_attr()
in your value template.
Spot on… I’m learning new things every day… THANKS
yes, you would want to do it this way… I still use the old ways as I have not had time to go back and change all my sensors to use the new way…
If the sensor is not available at startup, you will get error messages in the logs with this.
internet_latency:
You should try to avoid states.xxx
, it’s better to use states('xxx')
. Or in your case, as it is about attributes, you should use state_attr
as mentioned by @firstof9.
That would look like this:
internet_latency:
value_template: "{{ state_attr('sensor.unifi_gateway_www', 'latency') }}"
