System Monitoring - How does yours look?
Thanks again for the reply. But i’m afraid I will need some hand holding with this.
Can you advise how to do this?
Thank you all for the inspiration, finally took care off it and made a system monitoring dashboard and this is what i decided on
how to make a graph like this?
interposes the elements shown above and below
I use for similar chart Apex Charts card:
Here is slightly modified code Iuse to show column chart:
  - type: custom:apexcharts-card
    update_interval: 5s
    graph_span: 5m
    show:
      loading: false
    apex_config:
      chart:
        height: 250px
      grid:
        show: true
        strokeDashArray: 0
        borderColor: '#444444'
        position: back
        xaxis:
          lines:
            show: true
        yaxis:
          lines:
            show: true
      yaxis:
        forceNiceScale: true
      xaxis:
        type: datetime
        axisTicks:
          show: true
        tickAmount: 6
        labels:
          format: HH:mm
        lines:
          show: true
      fill:
        type: gradient
        gradient:
          type: vertical
          shade: dark
          stops:
            - 0
            - 90
          opacityFrom:
            - 1
            - 0.2
          opacityTo:
            - 0.2
            - 1
    series:
      - entity: sensor.lan_speed_ap_f_in
        type: column
        color: var(--lightblue1)
      - entity: sensor.lan_speed_ap_f_out
        type: column
        color: var(--lightblue3)
        invert: true # here axis inversion goes
      - entity: input_number.zero_value
    all_series_config:
      stroke_width: 1.5
      type: area
It is not perfect, But for sure you can play with some configuration parameters to get better results.
thanks this works well
Screenshot 2024-05-30 at 11.47.30
For those interested i figured out how to make the date / time format as displayed above.
Here is the code for those that are interested for this card.
type: custom:button-card
entity: binary_sensor.rpi_power_status
aspect_ratio: 1/1
styles:
  card:
    - border-radius: 10%
    - padding: 7%
    - font-size: 13px
    - text-transform: capitalize
  grid:
    - grid-template-areas: '"i n" "temp temp" "ip ip" "boot boot"'
    - grid-template-columns: 1fr 1fr
    - grid-template-rows: 1fr min-content min-content min-content
  name:
    - font-weight: null
    - font-size: 14px
    - color: '#00000'
    - text-align: left
    - margin-top: 5px
    - justify-self: start
    - padding-bottom: 4px
  img_cell:
    - justify-content: start
    - align-items: start
    - margin: none
  icon:
    - align-self: start
    - color: ''
    - width: 80%
    - overflow: visible
    - margin-top: 0%
  custom_fields:
    temp:
      - padding-bottom: 2px
      - align-self: middle
    boot:
    ip:
custom_fields:
  ip: |
       return `<ha-icon
                icon="mdi:ip"
                style="width: 20px; height: 20px; color: #00000;">
                </ha-icon><span>  &nbsp  <span style="color: var(--text-color-sensor);">${states['sensor.system_monitor_ipv4_address_eth0'].state}</span></span>`
  boot: |
       const date = new Date(states['sensor.system_monitor_last_boot'].state);
       const formattedDate = `${date.getDate()} ${date.toLocaleString('default', { month: 'short' })} ${date.getFullYear()} :  ${date.toLocaleTimeString([], {hour: '2-digit', minute:'2-digit'})}`;
       return `<ha-icon
                icon="mdi:clock"
                </ha-icon><span> &nbsp <span style="color: var(--text-color-sensor);">${formattedDate}</span></span>`
  temp: |
       return `<ha-icon
                icon="mdi:temperature-celsius"
                </ha-icon><span>  &nbsp <span style="color: var(--text-color-sensor);">${states['sensor.system_monitor_processor_temperature'].state}</span></span>`
This is the code for the date / time format :
boot: |
       return `<ha-icon
                icon="mdi:clock"
Nice monitor
Can you share code Raspberry Pi card @Kabala
@fraintt … Really nice dashboard. Thanks for sharing
Hi. Can I ask how to enable having a sensor.processor_use or sensor.disk_use_percent_home? These do not exist in my installation of HA. Thank you.
@gdreelin Would be able to share your Ubiquiti card config?
Any idea what the difference is between the system monitor processor and command line cpu temp sensors on a raspberry pi?, they both provide different readings.
Work in progress, but coming along. Mostly using custom button card and default cards
Hello, nice dashboard voor the synology can you share the code?
Sure:
type: vertical-stack
cards:
  - type: custom:button-card
    entity: update.synstor_dsm_update
    icon: mdi:nas
    aspect_ratio: 3/2
    styles:
      card:
        - background-color: "#55555544"
        - background: url(/local/DS920plus.png) round
        - background-position: center top
        - background-repeat: no-repeat
        - background-size: 35%
        - border-radius: 3%
        - padding: 5%
        - color: ivory
        - font-size: 14px
        - text-shadow: 0px 0px 5px black
      grid:
        - grid-template-areas: "\"i up\" \"n n\" \"cpu cpu\" \"temp temp\" \"ip ip\" \"ds ds\""
        - grid-template-rows: 1fr min-content min-content min-content min-content min-content
      name:
        - font-weight: bold
        - font-size: 20px
        - color: white
        - padding-bottom: 14px
      img_cell:
        - margin: none
      icon:
        - color: |-
              if (entity.state == "on") return 'orange';
              else if (states["sensor.synstor_temperature"].state > 60) return 'orange';
              else return 'lime';
        - width: 30%
        - margin-top: "-10%"
      custom_fields:
        up:
          - align-self: start
          - justify-self: end
        cpu:
          - padding-bottom: 8px
          - "--text-color-sensor": >-
              [[[ if (states["sensor.synstor_cpu_utilization_total"].state > 50)
              return "red"; ]]]
        temp:
              [[[ if (states["sensor.synstor_memory_usage_real"].state > 60)
              return "red"; ]]]
        ds:
              [[[ if (states["sensor.synstor_temperature"].state > 60) return
              "red"; ]]]
    custom_fields:
      up: |
          var ustate = (entity.state == 'on') ? 'Update Available' : 'Up-To-Date';
          return `<ha-icon
          icon="mdi:update"
          style="width: 24px; height: 24px; color: deepskyblue;">
           </ha-icon> <span>${ ustate }</span>`
      cpu: |
          return `<ha-icon
          icon="mdi:chip"
          </ha-icon> <span>CPU: <span style="color:var(--text-color-sensor);">${ states['sensor.synstor_cpu_utilization_total'].state }%</span></span>`
      temp: |
          return `<ha-icon
          icon="mdi:memory"
          </ha-icon> <span>RAM: <span style="color: var(--text-color-sensor);">${ states['sensor.synstor_memory_usage_real'].state}% </span></span>`
      ds: |
          return `<ha-icon
          icon="mdi:thermometer"
          </ha-icon> <span>Temperature: <span style="color: var(--text-color-sensor);">${ states['sensor.synstor_temperature'].state }°C&nbsp;&nbsp;&nbsp;&nbsp;</span>`
  - type: custom:bar-card
    max: "5.26"
    unit_of_measurement: / 5.26TB
    entities:
      - entity: sensor.synstor_volume_1_used_space
        icon: mdi:library-shelves
        name: Storage (Volume 1)
    card_mod:
      style: |
        ha-icon {
          color:
            {% if is_state('sensor.synstor_volume_1_status', 'normal') %}
              lime
            {% else %}
              red
            {% endif %}
          --mdc-icon-size: 45px
        bar-card-value {
  - type: horizontal-stack
    cards:
        entity: sensor.synstor_drive_1_temperature
        icon: mdi:harddisk
        aspect_ratio: 1/1.3
        styles:
          card:
            - padding: 10%
            - color: ivory
            - font-size: 8.5px
          grid:
            - grid-template-areas: "\"i n\" \"stat stat\" \"smart smart\" \"graph graph\""
            - grid-template-rows: 1fr min-content min-content 1fr
          name:
            - font-weight: bold
            - font-size: 12px
            - color: white
            - align-self: start
            - justify-self: end
            - margin-top: 13%
          img_cell:
            - margin-left: "-35%"
          icon:
            - width: 80%
            - margin-top: "-20%"
            - margin-left: "-2%"
            - color: |
                  if (entity.state > 50) return "red";
                  if (states['sensor.synstor_drive_1_status'].state != 'normal') {
                    return "red"
                  if (entity.state >= 35) return "orange";
                  else return "lime";
          custom_fields:
            stat:
              - padding-bottom: 1px
              - align-self: end
              - margin-left: "-5%"
            smart:
              - align-self: end
              - margin-bottom: "-15%"
            graph:
              - align-self: bottom
              - margin-left: "-12%"
              - margin-right: "-12%"
              - height: 50%
        custom_fields:
          stat: |
              var nas = states['sensor.synstor_drive_1_status'].state;
              var staticon = 'width: 14px; height: 14px; color: red;'
              if (nas == 'normal') {
                staticon = 'width: 14px; height: 14px; color: lime;';
              if (nas == 'not_use') {
                staticon = 'width: 14px; height: 14px; color: orange;';
                var nas = 'Hot-Spare'
              return `<ha-icon
              icon="mdi:power-standby"
              style="${staticon}">
              </ha-icon> <span style="color: white;">${nas}</span>`
          smart: |
              var nas = states['sensor.synstor_drive_1_status_smart'].state;
              return `<ha-icon
              icon="mdi:memory"
              </ha-icon> S.M.A.R.T`
          graph:
            card:
              type: custom:mini-graph-card
              group: true
              font_size: 30
              height: 140
              align_state: right
              lower_bound: 24
              show:
                points: false
                icon: false
              entities:
                - entity: "[[[ return entity.entity_id ]]]"
              style: |
                ha-card {
                  box-shadow: none;
        entity: sensor.synstor_drive_2_temperature
        icon: mdi:harddisk
        aspect_ratio: 1/1.3
        styles:
          card:
            - padding: 10%
            - color: ivory
            - font-size: 8.5px
          grid:
          name:
            - font-weight: bold
            - font-size: 12px
            - color: white
            - align-self: start
            - justify-self: end
            - margin-top: 13%
          img_cell:
          icon:
            - width: 80%
            - color: |
                  else return "lime";
          custom_fields:
            stat:
              - align-self: end
            smart:
              - align-self: end
            graph:
              - height: 50%
        custom_fields:
          stat: |
              var nas = states['sensor.synstor_drive_2_status'].state;
              return `<ha-icon
          smart: |
              var nas = states['sensor.synstor_drive_2_status_smart'].state;
              return `<ha-icon
              icon="mdi:memory"
          graph:
            card:
              group: true
              font_size: 30
              height: 140
              align_state: right
              lower_bound: 24
              show:
                points: false
                icon: false
              entities:
              style: |
                ha-card {
                  box-shadow: none;
        entity: sensor.synstor_drive_3_temperature
        icon: mdi:harddisk
        aspect_ratio: 1/1.3
        styles:
          card:
            - padding: 10%
            - color: ivory
            - font-size: 8.5px
          grid:
          name:
            - font-weight: bold
            - font-size: 12px
            - color: white
            - align-self: start
            - justify-self: end
            - margin-top: 13%
          img_cell:
          icon:
            - width: 80%
            - color: |
                  else return "lime";
          custom_fields:
            stat:
              - align-self: end
            smart:
              - align-self: end
            graph:
              - height: 50%
        custom_fields:
          stat: |
              var nas = states['sensor.synstor_drive_3_status'].state;
              return `<ha-icon
          smart: |
              var nas = states['sensor.synstor_drive_3_status_smart'].state;
              return `<ha-icon
              icon="mdi:memory"
          graph:
            card:
              group: true
              font_size: 30
              height: 140
              align_state: right
              lower_bound: 24
              show:
                points: false
                icon: false
              entities:
              style: |
                ha-card {
                  box-shadow: none;
        entity: sensor.synstor_drive_4_temperature
        icon: mdi:harddisk
        aspect_ratio: 1/1.3
        styles:
          card:
            - padding: 10%
            - color: ivory
            - font-size: 8.5px
          grid:
          name:
            - font-weight: bold
            - font-size: 12px
            - color: white
            - align-self: start
            - justify-self: end
            - margin-top: 13%
          img_cell:
          icon:
            - width: 80%
            - color: |
                  else return "lime";
          custom_fields:
            stat:
              - align-self: end
            smart:
              - align-self: end
            graph:
              - height: 50%
        custom_fields:
          stat: |
              var nas = states['sensor.synstor_drive_4_status'].state;
              return `<ha-icon
          smart: |
              var nas = states['sensor.synstor_drive_4_status_smart'].state;
              return `<ha-icon
              icon="mdi:memory"
          graph:
            card:
              group: true
              font_size: 30
              height: 140
              align_state: right
              lower_bound: 24
              show:
                points: false
                icon: false
              entities:
              style: |
                ha-card {
                  box-shadow: none;
I think this should be enough:
  • It uses Button-Card and Mini-Graph-Card from HACS.
  • .png files need to be transparent
  • Obviously you need the Synology integration installed and amend entities as required
Thank you, the one from synology works fine for me now. Do you also have the esxi for me?
Work in progress, swipe-card used between them (I like the tall vertical panels, works well on mobile).
And yes there are a lot of different colours at the moment lol:
