Hi there!
I’ve tried my luck already on finding a solution to my problem on facebook and the discord. But… no response! Having good hope for the forum, else i see no other solution that to start my HA install from scratch.
So:
After i’ve updated to 1.4 i can’t install any updates anymore. It’s showing me 1.7 now, but install won’t start because my system seems to be unhealthy.
I’ve had this problem once before, but then i was able to restore to a backup. In this case, i can find the backup, click on the “restore” button… but nothing happens. The popup disappears and… well… nothing. No error… Nothing.
So… back to the “not being able to update”. I’ve checked the log, and as soon as the update is started the logs shows this error:
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy - setup
2023-01-02 19:13:46.582 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547042968240] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy - setup
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 303, in async_install
await async_update_core(self.hass, version=version, backup=backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 51, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: 'HomeAssistantCore.update' blocked from execution, system is not healthy - setup
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1755, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1792, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 678, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 958, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 715, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 154, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 413, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 305, in async_install
raise HomeAssistantError(
And well… i can’t really make anything of it. Hoping someone can point me in the right direction!
For clarity: i’m running on a PI in HA OS.
