System unrespensive after upgrade from HA core 2021.1.4 to 2021.1.5
tried to update my installatiion HASS.I0 on rpi 4 with 64 bit OS. The upgrade is ok but the system hangs. After power off power on it works. When i update an add-on it fails. It gets unresponsive.
. I installed a complete new image hassos_rpi4-64-5.10.img.xz and everthing works. When i upgrade this to HA core 2021.1.5 the system again in unresponsive. tried this with SD card and SSD disk. Still the same issue.
also got issues with non accessible host
Use SSH to access your installation and check the log files for errors using this command:
ha core logs
PS: Hassio has not been a thing for a year now. You should call it Home Assistant OS.
