but not sure why it’s communicating properly, like it seems that it is receiving some messages but no transmitting anything… it is just weird… I also checked the firewall just in case but it seems to be ok… and I would see anyways some packages transmitted from the interface…
Also I realised that maybe some option has to be activate in the VSR300… so on Monday it seems that I will have access to the other remove and I will be able to set it up… I will try and post the results here
EDIT: As I was expecting was the configuration of the VSR300 so finally I am getting finally data from it, still I will need to have a look to the modbus guide, but it looks much better now
Hi! I have the same problem as you describe with the same RS485 to Ethernet device from USR IOT. I have the VSR500, but I guess it might be the same config as yours. Can you please explain what configuration you need to set on the VSR to get data from it? Best regards from Oystein.
Well about the humidity transfer I realized it is happening whenever in the room where the machine is, there is higher humidity than the one set in Set Point in the section Moisture transfer control, so I guess it’s just trying to compensate the humidity somehow…
For the second question I have no idea, I am also trying to understand how this works
Ah, nice. I only have a «light display» type where it is only possible to change the power. And in my region they can’t deliver the save touch panel. Thanks anyhow for the answer!
Ohh I feel you, I waited 1.5 months for it! but in the meantime maybe you can ask the installers to activate this option for you, and you won’t need at all the other remote controller
I’m trying to communicate with the VSR 300 by modbus/RTU, but with your configuration i am not getting the response.
Slave address 0 is reserved to broadcast (only write without response).
Are you getting a response with this setting?
My guess is that the overheat sensor is ON or very near the heater element.
So if the heater is on, then this temp will be higher then the supplied air.
If its off, it should be the same temp.
Can anyone give me the examples for config of vsr300/500 i cant for the life of me figure out
Should everything be in configuration.yaml or splitted up in sensor.yaml switches.yaml etc.
@Ontrackx
If i understand you correct you are using the modbus integration in Home assistant and not Node red.
I haven’t used the modbus integration in HA after switching to Node red (2021), so i don’t have any sensor examples in yaml for you, but i see others have some examples in earlier posts. If you follow the examples in the HA modbus section, it should be quite straight forward. There have been a few breaking changes regarding the modus intergration in HA, if you haven’t adapted the config accordingly, maybe that’s the cause in your case?
You must not split up your config, my opinion is that splitting up the config gives better structure if you have lots of sensors, switches etc.
There is lots of threads in the forum of how to split up the config if uncertain of the approach.
