Can anyone give me the examples for config of vsr300/500 i cant for the life of me figure out
Should everything be in configuration.yaml or splitted up in sensor.yaml switches.yaml etc.
I try to use this instead of node red i always get a error in my config, has the configyration.yaml changed the last year on how it should be set up?
@Ontrackx
If i understand you correct you are using the modbus integration in Home assistant and not Node red.
I havenât used the modbus integration in HA after switching to Node red (2021), so i donât have any sensor examples in yaml for you, but i see others have some examples in earlier posts. If you follow the examples in the HA modbus section, it should be quite straight forward. There have been a few breaking changes regarding the modus intergration in HA, if you havenât adapted the config accordingly, maybe thatâs the cause in your case?
You must not split up your config, my opinion is that splitting up the config gives better structure if you have lots of sensors, switches etc.
There is lots of threads in the forum of how to split up the config if uncertain of the approach.
Not much of help but hopefully some.
Hi!
I got it working after some tries, and Iâve been uploading my backup to Github as a personal backup/sharing spot. You can take a look at my files at https://github.com/Ztaeyn/HomeAssistant-VTR-Modbus. Itâs still work in progress but fully functional, but I hope it will get you to the next step.
Iâve split it up into separate files to keep configuration.yaml tidy.
I used the incomplete files from @Tempo_Trevis from the start of the thread and Iâm trying to add in the missing parts myself to get know modbus better.
I hope itâs ok I borrowed your files @Tempo_Trevis .takker sĂĽ mye for innsatsen du har gjort.
Bare fint andre fĂĽr glede av info
Let me know if there is any sensors you are missing, and i can share the modbus addresses being used in my Node red config in a list or text file.
I just found this thread today after spending the day putting together my own config. Hereâs what I have for a VSR 500.
Everything except the REG_OUTPUT_Y1_ANALOG (Heater A0 state) seems to work fine. That one just never shows anything other than 0, even when the heater is on.
-David
Modbus config for a SystemAir SAVE VSR 500 with sensors, switches, and binary_sensors:
- type: tcp
host: 192.168.1.13
port: 8899
delay: 4
timeout: 4
sensors:
- name: "FTX Outdoor Temperature"
unique_id: ftx_outdoor_temperature
address: 12101
slave: 1
data_type: int16
scan_interval: 10
unit_of_measurement: °C
device_class: temperature
state_class: measurement
scale: 0.1
precision: 1
- name: "FTX Supply Temperature"
unique_id: ftx_supply_temperature
address: 12102
slave: 1
data_type: int16
scan_interval: 10
scale: 0.1
precision: 1
- name: "FTX Extract Temperature"
unique_id: ftx_extract_temperature
address: 12543 #This is PDM Input 1 not 12104
slave: 1
data_type: int16
scan_interval: 10
scale: 0.1
precision: 1
- name: "FTX Over Heat Temperature"
unique_id: ftx_over_heat_temperature
address: 12107
slave: 1
data_type: int16
scan_interval: 100
scale: 0.1
precision: 1
- name: "FTX Humidity"
unique_id: ftx_humidity
address: 12135 #This is PDM Input 2 not 12108
slave: 1
data_type: uint16
scan_interval: 10
unit_of_measurement: '%'
device_class: humidity
- name: "FTX Extract Fan Speed RPM"
unique_id: ftx_extract_fan_speed_rpm
address: 12401
slave: 1
data_type: uint16
scan_interval: 10
unit_of_measurement: RPM
- name: "FTX Supply Fan Speed RPM"
unique_id: ftx_supply_fan_speed_rpm
address: 12400
slave: 1
data_type: uint16
scan_interval: 10
- name: "FTX Supply Fan Speed Percent"
unique_id: ftx_supply_fan_speed_percent
address: 14000
slave: 1
data_type: uint16
scan_interval: 10
- name: "FTX Extract Fan Speed Percent"
unique_id: ftx_extract_fan_speed_percent
address: 14001
slave: 1
data_type: uint16
scan_interval: 10
- name: "FTX Supply Setpoint Temperature"
unique_id: ftx_supply_setpoint_temperature
address: 2000
slave: 1
data_type: int16
scan_interval: 20
scale: 0.1
precision: 1
- name: "FTX Supply Setpoint Temperature SATC"
unique_id: ftx_supply_setpoint_temperature_satc
address: 2053
slave: 1
data_type: int16
scan_interval: 100
scale: 0.1
precision: 1
- name: "FTX Heat Exchanger Active"
unique_id: ftx_heat_exchanger_active
address: 14102
data_type: uint16
slave: 1
scan_interval: 5
- name: "FTX Heater Active"
unique_id: ftx_heater_active
address: 14100
data_type: uint16
slave: 1
scan_interval: 5
- name: "FTX Active User Mode"
unique_id: ftx_active_user_mode
address: 1160
data_type: uint16
slave: 1
scan_interval: 10
- name: "FTX Fan Control Mode"
unique_id: ftx_fan_control_mode
address: 1273
data_type: uint16
slave: 1
scan_interval: 100
- name: "FTX Temperature Control Mode"
unique_id: ftx_temperature_control_mode
address: 2030
data_type: uint16
slave: 1
scan_interval: 100
- name: "FTX Supply Fan Manual Override Percent"
unique_id: ftx_supply_fan_manual_override_percent
address: 13800
slave: 1
data_type: uint16
scan_interval: 100
- name: "FTX Extract Fan Manual Override Percent"
unique_id: ftx_extract_fan_manual_override_percent
address: 13801
slave: 1
data_type: uint16
scan_interval: 100
- name: "FTX Eco Mode Temperature Offset"
unique_id: ftx_eco_mode_temperature_offset
address: 2503
slave: 1
data_type: int16
input_type: holding
scale: 0.1
precision: 1
scan_interval: 100
- name: "FTX Schedule Active Temperature Offset"
unique_id: ftx_schedule_active_temperature_offset
address: 5000
slave: 1
data_type: int16
input_type: holding
scale: 0.1
precision: 1
scan_interval: 100
- name: "FTX Schedule Active Fan Level"
unique_id: ftx_schedule_active_fan_level
address: 5059
data_type: uint16
slave: 1
scan_interval: 100
- name: "FTX Schedule Inactive Temperature Offset"
unique_id: ftx_schedule_inactive_temperature_offset
address: 5001
slave: 1
data_type: int16
input_type: holding
scale: 0.1
precision: 1
scan_interval: 100
- name: "FTX Schedule Inactive Fan Level"
unique_id: ftx_schedule_inactive_fan_level
address: 5060
data_type: uint16
slave: 1
scan_interval: 100
- name: "FTX Filter Months Remaining"
unique_id: ftx_filter_months_remaining
address: 7004
data_type: uint32
swap: word
count: 2
slave: 1
scale: 0.000000379477838 # From seconds to months
precision: 1
device_class: duration
unit_of_measurement: months
scan_interval: 100
- name: "FTX Filter Alarm"
unique_id: ftx_filter_alarm
address: 15141
data_type: uint16
slave: 1
scan_interval: 100
switches:
- name: "FTX Supply Fan Manual Override Enable"
unique_id: ftx_supply_fan_manual_override_enable
address: 13600
slave: 1
scan_interval: 100
verify:
- name: "FTX Extract Fan Manual Override Enable"
unique_id: ftx_extract_fan_manual_override_enable
address: 13601
slave: 1
scan_interval: 100
verify:
- name: "FTX Eco Mode Enabled"
unique_id: ftx_eco_mode_enabled
address: 2504
slave: 1
scan_interval: 100
verify:
- name: "FTX Free Cooling Mode Enabled"
unique_id: ftx_free_cooling_mode_enabled
address: 4100
slave: 1
scan_interval: 100
verify:
- name: "FTX Heater Enabled"
unique_id: ftx_heater_enabled
address: 13200
slave: 1
scan_interval: 100
verify:
- name: "FTX Allow Manual Fan Stop"
unique_id: ftx_allow_manual_fan_stop
address: 1352
slave: 1
scan_interval: 100
verify:
binary_sensors:
- name: "FTX Fans Running"
unique_id: ftx_fans_running
address: 1350
slave: 1
input_type: input
scan_interval: 10
- name: "FTX Heater Control"
unique_id: ftx_heater_control
address: 14380
slave: 1
input_type: input
scan_interval: 5
- name: "FTX Eco Mode Active"
unique_id: ftx_eco_mode_active
address: 2505
slave: 1
input_type: input
scan_interval: 10
- name: "FTX Free Cooling Mode Active"
unique_id: ftx_free_cooling_mode_active
address: 4110
slave: 1
input_type: input
scan_interval: 100
- name: "FTX Refresh Mode Input"
unique_id: ftx_refresh_mode_input
address: 12021
slave: 1
input_type: input
scan_interval: 5
- name: "FTX Cooking Mode Input"
unique_id: ftx_cooking_mode_input
address: 12022
slave: 1
input_type: input
scan_interval: 5
- name: "FTX Alarm"
unique_id: ftx_alarm
address: 14002
slave: 1
input_type: input
scan_interval: 10
Here are some automations to allow you to use human-readable input_numbers and input_selects for setting the modes. Youâll have to recreate them yourself as I added them with the GUI and I donât have code for them. But they are pretty obvious from the scripts below.
- alias: FTX set Temperature Setpoint from UI
- platform: state
entity_id: input_number.ftx_temperature_setpoint
- service: modbus.write_register
address: 2000
slave: 1
value: >
{{ states('input_number.ftx_temperature_setpoint')|int(1)*10 }}
hub: "FTX Modbus"
- delay: "00:00:02"
- service: homeassistant.update_entity
entity_id: sensor.ftx_supply_setpoint_temperature
- alias: FTX update Temperature Setpoint UI
- platform: state
condition:
- condition: template
value_template: >
{{ states('input_number.ftx_temperature_setpoint')|int(1) != states('sensor.ftx_supply_setpoint_temperature')|int(1) }}
- service: input_number.set_value
value: >
{{ states('sensor.ftx_supply_setpoint_temperature')|int(1) }}
- alias: FTX set Manual Fan Speed Level from UI and Manual Mode
description: 'When switched out of Auto, set the speed and switch to manual mode'
platform: state
entity_id: input_select.ftx_manual_fan_speed
not_to: "Auto"
- service: input_select.select_option
entity_id: input_select.ftx_active_user_mode
option: 'Manual'
- delay: "00:00:02"
address: 1130
slave: 1
value: >
{% set mapper =
'Off':'0',
'Low':'2',
'Normal':'3',
'High':'4'
{{ mapper[states('input_select.ftx_manual_fan_speed')] }}
hub: "FTX Modbus"
- alias: FTX unset Manual Fan Speed Level from UI and set Auto
description: 'When switched to Auto, set the mode to auto'
platform: state
to: "Auto"
option: 'Auto'
# Note: Stove is tricky. You can't choose it, but it can be activated!
- alias: FTX set Active User Mode from UI
platform: state
address: 1161
slave: 1
value: >
{% set mapper =
'Auto':'1',
'Manual':'2',
'Crowded':'3',
'Refresh':'4',
'Fireplace':'5',
'Away':'6',
'Holiday':'7',
'Stove':'0'
{{ mapper[states('input_select.ftx_active_user_mode')] }}
hub: "FTX Modbus"
entity_id: sensor.ftx_active_user_mode
# - alias: FTX turn on Stove Mode via external input
# id: ftx_turn_on_stove_mode_via_external_input
# trigger:
# platform: state
# entity_id: input_select.ftx_active_user_mode
# condition:
# - condition: state
# state: Stove
- alias: FTX set UI from Active User Mode
description: 'If the FTX has changed modes, then check if the UI is in-sync, and, if not, fix it.'
platform: state
condition:
value_template: >
{% set mapper =
'Auto':'0',
'Manual':'1',
'Crowded':'2',
'Refresh':'3',
'Fireplace':'4',
'Away':'5',
'Holiday':'6',
'Stove':'7'
{{ mapper[states('input_select.ftx_active_user_mode')] != states('sensor.ftx_active_user_mode')|int(1) }}
option: >
{% set mapper =
'0':'Auto',
'1':'Manual',
'2':'Crowded',
'3':'Refresh',
'4':'Fireplace',
'5':'Away',
'6':'Holiday',
'7':'Stove'
{{ mapper[states('sensor.ftx_active_user_mode')] }}
- alias: FTX set Temperature Control from UI
platform: state
entity_id: input_select.ftx_temperature_control_mode
- if:
- condition: state
state: Supply
then:
address: 2030
slave: 1
value: 0
hub: "FTX Modbus"
else:
address: 2030
slave: 1
value: 2
hub: "FTX Modbus"
entity_id: sensor.ftx_temperature_control_mode
- alias: FTX set Supply Fan Manual Override from UI
description: 'Update the FTX Supply Fan Manual Override from the UI controller'
- platform: state
entity_id: input_number.ftx_supply_fan_manual_override_percent
address: 13800
slave: 1
value: >
{{ states('input_number.ftx_supply_fan_manual_override_percent')|int(1) }}
hub: "FTX Modbus"
entity_id: sensor.ftx_supply_fan_manual_override_percent
- alias: FTX set Extract Fan Manual Override from UI
description: 'Update the FTX Extract Fan Manual Override from the UI controller'
- platform: state
entity_id: input_number.ftx_extract_fan_manual_override_percent
address: 13801
slave: 1
value: >
{{ states('input_number.ftx_extract_fan_manual_override_percent')|int(1) }}
hub: "FTX Modbus"
entity_id: sensor.ftx_extract_fan_manual_override_percent
- alias: FTX set ECO Mode Offset from UI
description: 'Update the FTX ECO Mode Offset from the UI controller.'
- platform: state
entity_id: input_number.ftx_eco_mode_temperature_offset
address: 2503
slave: 1
value: >
{{ states('input_number.ftx_eco_mode_temperature_offset')|int(1)*10 }}
hub: "FTX Modbus"
- delay: "00:00:02"
entity_id: sensor.ftx_eco_mode_temperature_offset
- alias: FTX update ECO Mode Offset UI
description: 'Update the UI controller for the ECO mode if the value on the FTX changes and it is not the same.'
- platform: state
condition:
value_template: >
{{ states('input_number.ftx_eco_mode_temperature_offset')|int(1) != states('sensor.ftx_eco_mode_temperature_offset')|int(1) }}
value: >
{{ states('sensor.ftx_eco_mode_temperature_offset')|int(1) }}
Enjoy!
@Tempo_Trevis I just took a look at your NodeRed repository and was curious about your energy calculations. I donât use NodeRed myself, so I was wondering if you could let me know how you calculated the saved energy. I can see doing the air volume times the temperature differences between the intake and output (I donât have an output sensor, but I can add one easily enough). Is that how you approach it? Or do you have an estimate of the heater as well? I have a power meter on the whole system, so I can get that part.
Thanks!
-David
Im not sure but i believe the âHeater A0 stateâ is for an external heater regulator output, which are more commonly used on bigger industrial ventilation units. If the modbus addresses on your unit are the same as mine you can read the el. heater output command at modbus adr. 2148 (0-100% output).
Iâm using a formula estimating the sensible heat in kW produced by the ventilation unit, it looks as shown below in Node red. This is only an estimate and will not be 100% accurate as there are parameters like air density that changes with the temperature, moisture (only using a fixed value for this as best guess), the air volume are only being estimated as i donât have any sensor for that as well. But i believe it will give an good indication of what the unit produce in kW further accumulated to energy.
From there i accumulate the sensible heat each 10s to get estimated produced energy in kWt (could use the âRiemann sum integralâ but i wasnât aware of that option when i integrated the ventilation unit).
To get the âtrue produced energyâ i simply subtracted the âestimated produced(delivered) power - power consumptionâ and did as mentioned above (accumulated the result each 10s to get estimated true produced energy). In that way the el.heater consumption is also being subtracted as it is being measured in the consumption.
In this example you only need the following sensors which you probably already have in your system:
- Measured supply temp.
- Measured inlet temp.
- Supply fan output ( to estimate airflow [m3/s]
- your factor for air density
I hope this answered your questions, there might be better ways of approaching this.
True estimated energy so far (since 2020/21):
Consumption so far (since 2020/21):
// hs := cp*Ď*q*dt
// Eks.= (1.006 kJ/kg°C) (1.202 kg/m3) (1 m3/s) ((20°C) - (0°C))
//hs := sensible heat (kW)
//cp := specific heat of air (1.006 kJ/kg°C)
//p := density of air (1.202 kg/m3) or "press/(Rspecific*t)"
//q := air volume flow (m3/s)
//dt := delta temperature delta [°C]
//press := absolute pressure (Pa)
//t := absolute temperature (kelvin)
//Rspecific := specific gas constant for dry air (J/(kg'K)) [Rspec]
var q_pv = flow.get ("vtr300_tilluftsvifte_pv","default");
var t_supply = flow.get ("vtr300_tillufts_temperatur","default");
var t_inlet = flow.get ("vtr300_inntak_temp","default");
var press = 101325;
var t = t_inlet + 273.15;
var Rspec = 287;
// Sjekker for "isNotNumber, ved "isNan" (ved Modbus kom./feil ell. av sensor data) tidlig "exit" (prøv igjen).
if (isNaN(q_pv) || isNaN(t_supply) || isNaN(t_inlet) || isNaN(t)) {
return;
var cp = 1.006;
//var p = 1.202;
var p = press/(Rspec*t);
var q = (q_pv * 3)/3600;
var dt = t_supply - t_inlet;
var hs = cp*p*q*dt;
// Lagrer watt og kW til memory for videreberegning av faktisk levert estimert effekt
flow.set("vtr300_tilfort_Watt", hs*1000,"default"); // Lagrer tilført kW til "memory/default"
flow.set("vtr300_tilfort_kWatt", hs,"default"); // Lagrer tilført kW til "memory/default"
// Estimert levert effekt & energi total
var watt = {payload:(hs*1000).toFixed(0)};
var kW = {payload:(hs).toFixed(2)};
var kW_10s = {payload:(hs/360)}; // kW/10s
// Tilpasser desimaler for attribute visning i HA
flow.set("vtr300_tilfort_Watt_formated", (hs*1000).toFixed(0) +' Watt',"default"); // Lagrer tilført kW til "memory/default"
flow.set("vtr300_tilfort_kWatt_formated", (hs).toFixed(2) +' kW',"default"); // Lagrer tilført kW til "memory/default"
return [watt,kW,kW_10s];
Thanks! Now I understand what you are doing: youâre not explicitly trying to calculate the energy recovered from the indoor heat, but rather the total energy delivered, and then subtracting off what the whole unit consumed. Iâll take a look!
-David
@Tempo_Trevis I came up with another way of estimating the energy content of the air heating. If you see any problems with this do let me know! (I ran it by my 14 year-old and she thought it made sense, at least
I ran the FTX for 20 minutes without the heater on (eco mode) and then 20 minutes with it on. I measured the difference in average power during those times and the difference in temperature delta.
This gave me that adding 403W of additional energy translated into an additional 5C of temperature increase. So I concluded that for my volume of airflow, it takes 81W per °C temperature increase. From this I can work out that I recover 14.8° of temperature via the exchanger, or 1.2kW equivalent heating.
I donât know the volume of air, but as long as the electrical heater is essentially 100% efficient (it should be) this should be pretty accurate.
The part that isnât quite perfect is that the heat exchanger was on slightly more (98% vs. 95%) for the non-heat added version.
-David
An interesting approach, if i compare the sensible heat equation with your findings for my VTR300 in normal speed, fan speed reduction is approx 20% (due to cold outdoor temp.), the inlet temp. is -9.0°C and the supply temp is 14,2°C. The sensible heat gives me estimated true power to be 1184 watts (power consumption is subtracted). In this situation the heat exchanger output in that case is 59,3%. Compared to your finding this would give me (14,2-(-9))*81= 1871 Watts
Since your VTR500 provide more airvolume than my smaler VTR300 (609mÂł/h vs 351mÂł/h according to system air), that could cause the main difference in estimated power delivered.
Im not an expert in this area, but including the airvolume as done i the sensible heat equation, you donât have to repeat your power test for the different speed the ventilation unit is changing between during its operation time.
You mention that you donât know the air volume, in my case i simply find the actual estimated volume by multiplying the supplyfan output [%] with qv_max (351mÂł/h in my case).
Does qv_max vary much with the system pressure drop? E.g., I donât know the resistance in my ducts, and I saw in the manual that the flow volume goes down with increased resistance. Of course Iâm not sure how big a deal that is since SystemAir recommend just using a default value on their web tool if you donât know. -David
Sorry, this is way out of my knowledge, Iâve only integrated ventilation units to SCADA systems.
This is a question for the ventilation system designers/engineers.
If all the dampers (supply and extract air valves in the roof/wall) are properly adjusted, the system pressure should be as optimal as possible.
Thank you for the lovley writeup, i got everyting working. But how do i add a switch/entity in gui to control temp/fan speeds etc, do you have an example?
Hereâs what I did.
For temperature, I have an input_number named ftx_temperature_setpoint.
I then have two automations: one that updates the FTX when I change the input_number and one that updates the input_number when the FTX has a temperature change. (The second one is only needed if you want changes on the FTX control panel to show up in HA.)
- platform: state
address: 2000
slave: 1
value: >
hub: "modbus_hub"
- delay: "00:00:02"
- platform: state
condition:
value_template: >
value: >
For changing the fan speed I have an input_select with four options and I use a mapping in the automation to convert it to the number to send:
platform: state
not_to: "Auto"
option: 'Manual'
- delay: "00:00:02"
address: 1130
slave: 1
value: >
{% set mapper =
'Off':'0',
'Low':'2',
'Normal':'3',
'High':'4'
And here is what I have for the mode:
platform: state
address: 1161
slave: 1
value: >
{% set mapper =
'Auto':'1',
'Manual':'2',
'Crowded':'3',
'Refresh':'4',
'Fireplace':'5',
'Away':'6',
'Holiday':'7',
'Stove':'0'
hub: "modbus_hub"
platform: state
condition:
value_template: >
{% set mapper =
'Auto':'0',
'Manual':'1',
'Crowded':'2',
'Refresh':'3',
'Fireplace':'4',
'Away':'5',
'Holiday':'6',
'Stove':'7'
option: >
{% set mapper =
'0':'Auto',
'1':'Manual',
'2':'Crowded',
'3':'Refresh',
'4':'Fireplace',
'5':'Away',
'6':'Holiday',
'7':'Stove'
I hope that is helpful!
-David
Very nice! Thank you. If you list all the helper inputs needed in initial post. others like me (a novice) Would understand that we need helper entitys to get this to work.
Thank you this is exactly what i have been looking for.
This is how it looks with me at the moment, maybe you have a better UI setup. Would you like to share? What i like about this approach is that it is direct from modbus intrigation and not via node-red like i had before.
A modbus Systemair/ventilation intrigation (i would pay someone to make this)
Thatâs really cool. It looks like youâve got them just the way I have them. Hereâs my full automation. Itâs the same as what I posted earlier with a few more details. Some of the input elements were created by the GUI, so I donât have a config files for them.
- alias: FTX set Night Away Temperature Offset from UI
- platform: state
entity_id: input_number.ftx_night_away_temperature_offset
address: 5001
slave: 1
# Convert to 16-bit 2's complement from the negative number. E.g., 1111 1111 1111 1111 + (neg number) + 1
value: >
{{ 65535+(states('input_number.ftx_night_away_temperature_offset')|int(1)*10)+1 }}
hub: "modbus_hub"
- delay: "00:00:02"
entity_id: sensor.ftx_schedule_inactive_temperature_offset
- alias: FTX set Night Away Fan Mode from UI
- platform: state
entity_id: input_select.ftx_night_away_fan_level
address: 5060
slave: 1
value: >
{% set mapper =
'Low':'2',
'Normal':'3',
'High':'4'
{{ mapper[states('input_select.ftx_night_away_fan_level')] }}
hub: "modbus_hub"
- delay: "00:00:02"
entity_id: sensor.ftx_schedule_inactive_fan_level
- platform: state
address: 2000
slave: 1
value: >
hub: "modbus_hub"
- delay: "00:00:02"
- platform: state
condition:
value_template: >
value: >
platform: state
not_to: "Auto"
option: 'Manual'
- delay: "00:00:02"
address: 1130
slave: 1
value: >
{% set mapper =
'Off':'0',
'Low':'2',
'Normal':'3',
'High':'4'
hub: "modbus_hub"
platform: state
to: "Auto"
option: 'Auto'
platform: state
address: 1161
slave: 1
value: >
{% set mapper =
'Auto':'1',
'Manual':'2',
'Crowded':'3',
'Refresh':'4',
'Fireplace':'5',
'Away':'6',
'Holiday':'7',
'Stove':'0'
hub: "modbus_hub"
platform: state
condition:
value_template: >
{% set mapper =
'Auto':'0',
'Manual':'1',
'Crowded':'2',
'Refresh':'3',
'Fireplace':'4',
'Away':'5',
'Holiday':'6',
'Stove':'7'
option: >
{% set mapper =
'0':'Auto',
'1':'Manual',
'2':'Crowded',
'3':'Refresh',
'4':'Fireplace',
'5':'Away',
'6':'Holiday',
'7':'Stove'
platform: state
- if:
- condition: state
state: Supply
then:
address: 2030
slave: 1
value: 0
hub: "modbus_hub"
else:
address: 2030
slave: 1
value: 2
hub: "modbus_hub"
- alias: FTX set Supply Fan Low from UI
- platform: state
entity_id: input_number.ftx_supply_speed_low
address: 1402
slave: 1
value: >
{{ states('input_number.ftx_supply_speed_low')|int(1) }}
hub: "modbus_hub"
- alias: FTX set Extract Fan Low from UI
- platform: state
entity_id: input_number.ftx_extract_speed_low
address: 1403
slave: 1
value: >
{{ states('input_number.ftx_extract_speed_low')|int(1) }}
hub: "modbus_hub"
- alias: FTX set Supply Fan Normal from UI
- platform: state
entity_id: input_number.ftx_supply_speed_normal
address: 1404
slave: 1
value: >
{{ states('input_number.ftx_supply_speed_normal')|int(1) }}
hub: "modbus_hub"
- alias: FTX set Extract Fan Normal from UI
- platform: state
entity_id: input_number.ftx_extract_speed_normal
address: 1405
slave: 1
value: >
{{ states('input_number.ftx_extract_speed_normal')|int(1) }}
hub: "modbus_hub"
- alias: FTX set Supply Fan High from UI
- platform: state
entity_id: input_number.ftx_supply_speed_high
address: 1406
slave: 1
value: >
{{ states('input_number.ftx_supply_speed_high')|int(1) }}
hub: "modbus_hub"
- alias: FTX set Extract Fan High from UI
- platform: state
entity_id: input_number.ftx_extract_speed_high
address: 1407
slave: 1
value: >
{{ states('input_number.ftx_extract_speed_high')|int(1) }}
hub: "modbus_hub"
- platform: state
address: 13800
slave: 1
value: >
hub: "modbus_hub"
- platform: state
address: 13801
slave: 1
value: >
hub: "modbus_hub"
- platform: state
address: 2503
slave: 1
value: >
hub: "modbus_hub"
- delay: "00:00:02"
- platform: state
condition:
value_template: >
value: >
The GUI I have uses a bunch of PNGs with transparent areas to make the different parts of the system change color when they are active. (E.g., the heater turns yellow when it is on, the different circuits in the heat pump turn colored when they are on, the lines for the FTX get thicker when it is in higher speed fan modes, etc.)
Great work! Could this setup by any chance be applied to the Systemair Topvex units? They are a bit bigger than the VTR with higher capacity. Modbus TCP is supported.
anyone have any experiences writing a co2 value that can be used for the demand control?
