and stayed on this screen for 5/6 minutes before completly shutdown. After reboot HAOS spin up all services, but I noticed that docker took long time to start, and HAOS took about 5/6 minutes to startup all services.
Had the same on HASS OS 12.3 and Core 2024.5.3 on Proxmox 8.1.11. Shutdown was not possible, had to reset. I noticed a strong rise in CPU Load before and during the hang. Ping was still possible. HA URL, Observer URL, samba share were unreachable. I checked home-assistant.log.1 after reset and found many network connection problems including internal network connection to Mosquitto. Last entries were:
2024-05-14 04:06:45.002 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-05-14 04:06:45.119 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2024-05-14 04:06:45.120 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /store request
2024-05-14 04:06:45.121 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-05-14 04:06:45.160 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-05-14 04:06:45.160 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
I’m running 2024.10.2 on a Pi5. I wasn’t able to get into HA, and the observer was down too. I noticed that the fan was spinning fast and the Pi was pretty warm too. Telling me the CPU was quite busy.
Unfortunately I wasn’t able to get anything on the monitor when I plugged it in (I still have to get my remote SSH up) so I had no clue what was happening.
I had no other choice than to restart the pi by holding the power button.
The boot up was pretty fast, so no issues there. When I checked the logs I noticed that the last log message was "systemd-coredump[25776]: Process 1178 (python3) of user 0 terminated abnormally without generating a coredump.
I have rebooted 1.5 hours later, when it was still running hot.
I’m really curious what is happening here, because I believe I had this earlier on 9.x, but then I didn’t have the time to check the logs. So I just went with it…
Full log:
Oct 19 15:29:56 homeassistant hassio_dns[607]: [INFO] 127.0.0.1:49211 - 30355 "PTR IN 248.100.168.192.in-addr.arpa. udp 57 true 2048" NXDOMAIN qr,rd,ra 46 0.018091902s
Oct 19 15:29:56 homeassistant hassio_dns[607]: [INFO] 172.30.32.1:47931 - 29291 "PTR IN 248.100.168.192.in-addr.arpa. udp 46 false 512" NXDOMAIN qr,rd,ra 46 0.033097935s
Oct 19 15:29:56 homeassistant hassio_dns[607]: [INFO] 172.30.32.1:47931 - 22758 "PTR IN 241.100.168.192.in-addr.arpa. udp 46 false 512" NXDOMAIN qr,rd,ra 46 0.033028753s
Oct 19 15:29:56 homeassistant hassio_dns[607]: [INFO] 127.0.0.1:49080 - 60450 "PTR IN 233.100.168.192.in-addr.arpa. udp 57 true 2048" NXDOMAIN qr,rd,ra 46 0.016155714s
Oct 19 15:29:56 homeassistant hassio_dns[607]: [INFO] 172.30.32.1:47931 - 16572 "PTR IN 233.100.168.192.in-addr.arpa. udp 46 false 512" NXDOMAIN qr,rd,ra 46 0.035078051s
Oct 19 15:30:07 homeassistant hassio_supervisor[607]: 2024-10-19 17:30:07.639 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
Oct 19 15:30:16 homeassistant homeassistant[607]: 2024-10-19 17:30:16.932 ERROR (MainThread) [custom_components.xsense.mqtt] Error while re-connecting to XSense MQTT: WebSocket handshake error, connection not upgraded
Oct 19 15:30:17 homeassistant hassio_supervisor[607]: 2024-10-19 17:30:17.160 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
Oct 19 15:33:54 homeassistant hassio_supervisor[607]: 2024-10-19 17:33:54.644 INFO (MainThread) [supervisor.api.middleware.security] /backups access from de91e161_hassio_onedrive_backup
Oct 19 15:33:55 homeassistant hassio_supervisor[607]: 2024-10-19 17:33:55.146 INFO (MainThread) [supervisor.api.middleware.security] /backups access from de91e161_hassio_onedrive_backup
Oct 19 15:35:17 homeassistant homeassistant[607]: 2024-10-19 17:35:17.026 ERROR (MainThread) [custom_components.xsense.mqtt] Error while re-connecting to XSense MQTT: WebSocket handshake error, connection not upgraded
Oct 19 15:38:55 homeassistant hassio_supervisor[607]: 2024-10-19 17:38:55.043 INFO (MainThread) [supervisor.api.middleware.security] /backups access from de91e161_hassio_onedrive_backup
Oct 19 15:38:55 homeassistant hassio_supervisor[607]: 2024-10-19 17:38:55.532 INFO (MainThread) [supervisor.api.middleware.security] /backups access from de91e161_hassio_onedrive_backup
Oct 19 15:40:17 homeassistant homeassistant[607]: 2024-10-19 17:40:17.121 ERROR (MainThread) [custom_components.xsense.mqtt] Error while re-connecting to XSense MQTT: WebSocket handshake error, connection not upgraded
Oct 19 15:43:55 homeassistant hassio_supervisor[607]: 2024-10-19 17:43:55.434 INFO (MainThread) [supervisor.api.middleware.security] /backups access from de91e161_hassio_onedrive_backup
Oct 19 15:43:55 homeassistant hassio_supervisor[607]: 2024-10-19 17:43:55.873 INFO (MainThread) [supervisor.api.middleware.security] /backups access from de91e161_hassio_onedrive_backup
Oct 19 15:45:17 homeassistant homeassistant[607]: 2024-10-19 17:45:17.218 ERROR (MainThread) [custom_components.xsense.mqtt] Error while re-connecting to XSense MQTT: WebSocket handshake error, connection not upgraded
Oct 19 15:48:55 homeassistant hassio_supervisor[607]: 2024-10-19 17:48:55.818 INFO (MainThread) [supervisor.api.middleware.security] /backups access from de91e161_hassio_onedrive_backup
Oct 19 15:48:56 homeassistant hassio_supervisor[607]: 2024-10-19 17:48:56.197 INFO (MainThread) [supervisor.api.middleware.security] /backups access from de91e161_hassio_onedrive_backup
Oct 19 15:50:12 homeassistant hassio_supervisor[607]: 2024-10-19 17:50:12.899 INFO (MainThread) [supervisor.host.info] Updating local host information
Oct 19 15:50:12 homeassistant audit: BPF prog-id=233 op=LOAD
Oct 19 15:50:12 homeassistant audit: BPF prog-id=234 op=LOAD
Oct 19 15:50:12 homeassistant audit: BPF prog-id=235 op=LOAD
Oct 19 15:50:12 homeassistant kernel: audit: type=1334 audit(1729353012.904:589): prog-id=233 op=LOAD
Oct 19 15:50:12 homeassistant kernel: audit: type=1334 audit(1729353012.904:590): prog-id=234 op=LOAD
Oct 19 15:50:12 homeassistant kernel: audit: type=1334 audit(1729353012.904:591): prog-id=235 op=LOAD
Oct 19 15:50:12 homeassistant systemd[1]: Starting Hostname Service...
Oct 19 15:50:13 homeassistant systemd[1]: Started Hostname Service.
Oct 19 15:50:13 homeassistant audit: BPF prog-id=236 op=LOAD
Oct 19 15:50:13 homeassistant audit: BPF prog-id=237 op=LOAD
Oct 19 15:50:13 homeassistant audit: BPF prog-id=238 op=LOAD
Oct 19 15:50:13 homeassistant kernel: audit: type=1334 audit(1729353013.052:592): prog-id=236 op=LOAD
Oct 19 15:50:13 homeassistant kernel: audit: type=1334 audit(1729353013.052:593): prog-id=237 op=LOAD
Oct 19 15:50:13 homeassistant kernel: audit: type=1334 audit(1729353013.052:594): prog-id=238 op=LOAD
Oct 19 15:50:13 homeassistant systemd[1]: Starting Time & Date Service...
Oct 19 15:50:13 homeassistant systemd[1]: Started Time & Date Service.
Oct 19 15:50:13 homeassistant rauc[25750]: tryboot get-state A
Oct 19 15:50:13 homeassistant rauc[25750]: returning good
Oct 19 15:50:13 homeassistant rauc[25752]: tryboot get-state B
Oct 19 15:50:13 homeassistant rauc[25752]: returning bad
Oct 19 15:50:13 homeassistant hassio_supervisor[607]: 2024-10-19 17:50:13.189 INFO (MainThread) [supervisor.host.services] Updating service information
Oct 19 15:50:13 homeassistant hassio_supervisor[607]: 2024-10-19 17:50:13.195 INFO (MainThread) [supervisor.host.network] Updating local network information
Oct 19 15:50:13 homeassistant hassio_supervisor[607]: 2024-10-19 17:50:13.277 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
Oct 19 15:50:13 homeassistant hassio_supervisor[607]: 2024-10-19 17:50:13.281 INFO (MainThread) [supervisor.host.manager] Host information reload completed
Oct 19 15:50:17 homeassistant homeassistant[607]: 2024-10-19 17:50:17.306 ERROR (MainThread) [custom_components.xsense.mqtt] Error while re-connecting to XSense MQTT: WebSocket handshake error, connection not upgraded
Oct 19 15:50:43 homeassistant systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Oct 19 15:50:43 homeassistant audit: BPF prog-id=235 op=UNLOAD
Oct 19 15:50:43 homeassistant audit: BPF prog-id=234 op=UNLOAD
Oct 19 15:50:43 homeassistant audit: BPF prog-id=233 op=UNLOAD
Oct 19 15:50:43 homeassistant kernel: audit: type=1334 audit(1729353043.164:595): prog-id=235 op=UNLOAD
Oct 19 15:50:43 homeassistant kernel: audit: type=1334 audit(1729353043.164:596): prog-id=234 op=UNLOAD
Oct 19 15:50:43 homeassistant kernel: audit: type=1334 audit(1729353043.164:597): prog-id=233 op=UNLOAD
Oct 19 15:50:43 homeassistant systemd[1]: systemd-timedated.service: Deactivated successfully.
Oct 19 15:50:43 homeassistant audit: BPF prog-id=238 op=UNLOAD
Oct 19 15:50:43 homeassistant audit: BPF prog-id=237 op=UNLOAD
Oct 19 15:50:43 homeassistant audit: BPF prog-id=236 op=UNLOAD
Oct 19 15:50:43 homeassistant kernel: audit: type=1334 audit(1729353043.228:598): prog-id=238 op=UNLOAD
Oct 19 15:50:43 homeassistant kernel: audit: type=1334 audit(1729353043.228:599): prog-id=237 op=UNLOAD
Oct 19 15:50:43 homeassistant kernel: audit: type=1334 audit(1729353043.228:600): prog-id=236 op=UNLOAD
Oct 19 15:53:56 homeassistant audit[1178]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 subj=unconfined pid=1178 comm="python3" exe="/usr/local/bin/python3.12" sig=4 res=1
Oct 19 15:53:56 homeassistant kernel: audit: type=1701 audit(1729353236.192:601): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=unconfined pid=1178 comm="python3" exe="/usr/local/bin/python3.12" sig=4 res=1
Oct 19 15:53:56 homeassistant kernel: audit: type=1334 audit(1729353236.204:602): prog-id=239 op=LOAD
Oct 19 15:53:56 homeassistant kernel: audit: type=1334 audit(1729353236.204:603): prog-id=240 op=LOAD
Oct 19 15:53:56 homeassistant kernel: audit: type=1334 audit(1729353236.204:604): prog-id=241 op=LOAD
Oct 19 15:53:56 homeassistant audit: BPF prog-id=239 op=LOAD
Oct 19 15:53:56 homeassistant audit: BPF prog-id=240 op=LOAD
Oct 19 15:53:56 homeassistant audit: BPF prog-id=241 op=LOAD
Oct 19 15:53:56 homeassistant systemd[1]: Created slice Slice /system/systemd-coredump.
Oct 19 15:53:56 homeassistant systemd[1]: Started Process Core Dump (PID 25775/UID 0).
Oct 19 15:53:56 homeassistant systemd-coredump[25776]: Process 1178 (python3) of user 0 terminated abnormally without generating a coredump.
I still have this issue on 2025.11.1. If anyone has any guidance it will be greatly appreciated, seems to be related to proxmox, the big issue I have is not having time stamps to link issues together.
