I just rebooted with a monitor and keyboard and also got my logs from the frontend. Here’s my logs…
2021-11-18 21:57:35 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-11-18 21:57:36 WARNING (MainThread) [homeassistant.components.http] The 'base_url' option near /config/configuration.yaml:5 is deprecated, please remove it from your configuration
2021-11-18 21:57:36 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=50 from 2021-11-15 06:27:29)
2021-11-18 21:57:40 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [548290500208] Received invalid command: energy/get_prefs
2021-11-18 21:57:51 ERROR (MainThread) [homeassistant.components.automation] Blueprint Door Sensor-activated Light generated invalid automation with inputs OrderedDict([('doorsensor_entity', 'binary_sensor.z_wave_door_window_sensor_access_control_window_door_is_open'), ('light_target', OrderedDict([('entity_id', 'mirror')]))]): not a valid value for dictionary value @ data['action'][0]['target']['entity_id']. Got None
2021-11-18 21:57:56 WARNING (MainThread) [homeassistant.components.songpal.media_player] [sony cd(http://192.168.50.72:10000/sony)] Unable to connect
2021-11-18 21:57:57 WARNING (MainThread) [homeassistant.components.media_player] Platform songpal not ready yet: Unable to do POST request: Cannot connect to host 192.168.50.72:10000 ssl:default [Connect call failed ('192.168.50.72', 10000)]: None; Retrying in background in 30 seconds
2021-11-18 21:57:58 WARNING (MainThread) [homeassistant.components.heos] 192.168.50.108 is not logged in to a HEOS account and will be unable to retrieve HEOS favorites: Use the 'heos.sign_in' service to sign-in to a HEOS account
2021-11-18 21:58:08 WARNING (MainThread) [homeassistant.components.songpal.media_player] [sony cd(http://192.168.50.72:10000/sony)] Unable to connect
2021-11-18 21:59:11 WARNING (MainThread) [homeassistant.components.songpal.media_player] [sony cd(http://192.168.50.72:10000/sony)] Unable to connect
2021-11-18 22:00:00 WARNING (MainThread) [homeassistant.components.automation.cast_to_google_hub] Cast to Google Hub: Already running
2021-11-18 22:00:02 ERROR (MainThread) [homeassistant.components.automation.cast_to_google_hub] Cast to Google Hub: Choose at step 1: choice 1: Error executing script. Error for call_service at pos 5:
2021-11-18 22:00:02 ERROR (MainThread) [homeassistant.components.automation.cast_to_google_hub] Cast to Google Hub: Error executing script. Error for choose at pos 1:
2021-11-18 22:00:02 ERROR (MainThread) [homeassistant.components.automation.cast_to_google_hub] Error while executing automation automation.cast_to_google_hub:
2021-11-18 22:00:03 ERROR (Thread-22) [pychromecast.controllers.media] Exception thrown when calling media status callback
File "/usr/local/lib/python3.9/site-packages/pychromecast/controllers/media.py", line 488, in _fire_status_changed
listener.new_media_status(self.status)
File "/usr/src/homeassistant/homeassistant/components/cast/helpers.py", line 155, in new_media_status
self._cast_device.new_media_status(media_status)
File "/usr/src/homeassistant/homeassistant/components/cast/media_player.py", line 317, in new_media_status
tts_base_url = self.hass.components.tts.get_base_url(self.hass)
File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 649, in get_base_url
return hass.data[BASE_URL_KEY] or get_url(hass)
File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 83, in get_url
request_host = _get_request_host()
File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 122, in _get_request_host
raise NoURLAvailableError
homeassistant.helpers.network.NoURLAvailableError
2021-11-18 22:00:44 WARNING (MainThread) [homeassistant.components.songpal.media_player] [sony cd(http://192.168.50.72:10000/sony)] Unable to connect
2021-11-18 22:01:52 WARNING (MainThread) [homeassistant.components.http] The 'base_url' option near /config/configuration.yaml:5 is deprecated, please remove it from your configuration
2021-11-18 22:02:47 WARNING (MainThread) [homeassistant.components.songpal.media_player] [sony cd(http://192.168.50.72:10000/sony)] Unable to connect
