I am running HAOS. Today I had upgrade notices for the core, OS, and supervisor. I tried to upgrade the OS first but was told I needed to upgrade the supervisor. When I did this, I got this warning:
" Unsupported system - Systemd-Resolved issues
System is unsupported because Systemd Resolved is missing, inactive or misconfigured. Use the link to learn more and how to fix this."
I’ve never seen this before.
Any suggestions on what I should do? I have been tempted to restart HA but I’m afraid that this might not be the best idea. HA seems to still be working.
I didn’t restart because I wasn’t sure if I should or not. If the consensus is that I need to restart, I could certainly do that. I just didn’t want to make things worse.
If it goes wrong, then you just end up at the same place.
And just to clarify.
Unsupported means that something is not up to the requirements the HA team sets to provide support and help for the system. The forums will still help you. This is more of a harmless warning.
Unhealthy means something is wrong with the system! This might be serious, but this is not your case here.
After replying, I realized that maybe I ought to reboot my rpi since the warning was talking about something outside of HA. Well, sure enough, after rebooting, the warning went away.
Yeah, I asked you to restart the host, which is different from just HA.
The host is the entire system.
I were in hurry, so I did not have time to specify that earlier, which I normally always do, but you figries it out.
HA is a container and when you restart HA it is only that container that gets rebooted.
Supervisor and all the addons are containers too, but they just continue running when the HA container is restarted.
Addons can be restarted from their info page in the HA settings menu.
There probably also is somewhere to restart the supervisor, but I do not know where.
