I’m trying to manage systemd motion service via appdaemon.
I want to stop or start motion.service if I’m at home or not, but I have some stability problem.
Does anyone have already make such a thing ?
Here is my first try :
import appdaemon.appapi as appapi
import paho.mqtt.client as mqtt
import time
from systemd_dbus.manager import Manager
class MotionService(appapi.AppDaemon):
def initialize(self):
self.log("Motion Service Starting...")
self.client = mqtt.Client("appdaemon")
self.client.on_connect = self.mqtt_on_connect
self.client.on_message = self.mqtt_on_message
self.manager = Manager()
self.run()
def run(self):
self.client.connect("127.0.0.1", 1883, 60)
self.client.subscribe("/PI/LivingRoom/motion/Set", 0)
self.client.loop_start()
def terminate(self):
self.client.loop_stop()
def mqtt_on_connect(self, client, userdata, rc,a):
self.log("Connect: {}".format(str(rc)))
def mqtt_on_message(self, client, userdata, msg):
payload = msg.payload.decode("utf-8")
self.log("Topic:{}\n menssage:{}".format(msg.topic,payload))
status = ''
unit = self.manager.get_unit('motion.service')
if unit.properties.ActiveState == 'active':
status = "ON"
else:
status = "OFF"
if str(payload) == "ON" and str(status) == "OFF":
unit.start('fail')
time.sleep(1)
elif str(payload) == "OFF" and str(status) == "ON":
unit.stop('fail')
time.sleep(1)
self.call_service("mqtt/publish", topic = "/PI/LivingRoom/motion", payload = str(payload), qos = "0", retain = "false" )
It works on first start. But sometimes appdaemon reload modules, when home assistant was down, or when wifi was down, and it fails. Here is the log :
Sepp 18 22:04:46 localhost appdaemon[760]: 2017-09-18 22:04:46.754195 INFO motion: Motion Service Starting...
Sep 18 22:04:46 localhost appdaemon[760]: Exception in thread Thread-11:
Sep 18 22:04:46 localhost appdaemon[760]: Traceback (most recent call last):
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/systemd_dbus/exceptions.py", line 42, in wrapper
Sep 18 22:04:46 localhost appdaemon[760]: return func(*args, **kwargs)
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/systemd_dbus/unit.py", line 164, in start
Sep 18 22:04:46 localhost appdaemon[760]: job_path = self.__interface.Start(mode)
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/dbus/proxies.py", line 145, in __call__
Sep 18 22:04:46 localhost appdaemon[760]: **keywords)
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/dbus/connection.py", line 651, in call_blocking
Sep 18 22:04:46 localhost appdaemon[760]: message, timeout)
Sep 18 22:04:46 localhost appdaemon[760]: dbus.exceptions.DBusException: org.freedesktop.systemd1.TransactionIsDestructive: Transaction is destructive.
Sep 18 22:04:46 localhost appdaemon[760]: During handling of the above exception, another exception occurred:
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
Sep 18 22:04:46 localhost appdaemon[760]: self.run()
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/lib/python3.4/threading.py", line 868, in run
Sep 18 22:04:46 localhost appdaemon[760]: self._target(*self._args, **self._kwargs)
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/paho/mqtt/client.py", line 2606, in _thread_main
Sep 18 22:04:46 localhost appdaemon[760]: self.loop_forever(retry_first_connection=True)
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/paho/mqtt/client.py", line 1470, in loop_forever
Sep 18 22:04:46 localhost appdaemon[760]: rc = self.loop(timeout, max_packets)
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/paho/mqtt/client.py", line 995, in loop
Sep 18 22:04:46 localhost appdaemon[760]: rc = self.loop_read(max_packets)
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/paho/mqtt/client.py", line 1273, in loop_read
Sep 18 22:04:46 localhost appdaemon[760]: rc = self._packet_read()
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/paho/mqtt/client.py", line 1838, in _packet_read
Sep 18 22:04:46 localhost appdaemon[760]: rc = self._packet_handle()
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/paho/mqtt/client.py", line 2285, in _packet_handle
Sep 18 22:04:46 localhost appdaemon[760]: return self._handle_publish()
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/paho/mqtt/client.py", line 2456, in _handle_publish
Sep 18 22:04:46 localhost appdaemon[760]: self._handle_on_message(message)
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/paho/mqtt/client.py", line 2603, in _handle_on_message
Sep 18 22:04:46 localhost appdaemon[760]: self.on_message(self, self._userdata, message)
Sep 18 22:04:46 localhost appdaemon[760]: File "/home/pi/github/appdaemon/conf/apps/motion.py", line 39, in mqtt_on_message
Sep 18 22:04:46 localhost appdaemon[760]: unit.start('fail')
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/systemd_dbus/exceptions.py", line 44, in wrapper
Sep 18 22:04:46 localhost appdaemon[760]: raise SystemdError(error)
Sep 18 22:04:46 localhost appdaemon[760]: systemd_dbus.exceptions.SystemdError: TransactionIsDestructive(Transaction is destructive.)
Sep 18 22:04:46 localhost appdaemon[760]: 2017-09-18 22:04:46.779486 WARNING ------------------------------------------------------------
Sep 18 22:04:46 localhost appdaemon[760]: 2017-09-18 22:04:46.780419 WARNING Unexpected error during loading of motion:
Sep 18 22:04:46 localhost appdaemon[760]: 2017-09-18 22:04:46.781053 WARNING ------------------------------------------------------------
Sep 18 22:04:46 localhost appdaemon[760]: 2017-09-18 22:04:46.789305 WARNING Traceback (most recent call last):
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/systemd_dbus/manager.py", line 342, in subscribe
Sep 18 22:04:46 localhost appdaemon[760]: self.__interface.Subscribe()
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/dbus/proxies.py", line 70, in __call__
Sep 18 22:04:46 localhost appdaemon[760]: return self._proxy_method(*args, **keywords)
Sep 18 22:04:46 localhost appdaemon[760]: dbus.exceptions.DBusException: org.freedesktop.systemd1.AlreadySubscribed: Client is already subscribed.
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/appdaemon/appdaemon.py", line 911, in read_app
Sep 18 22:04:46 localhost appdaemon[760]: init_object(name, class_name, module_name, conf.app_config[name])
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/appdaemon/appdaemon.py", line 582, in init_object
Sep 18 22:04:46 localhost appdaemon[760]: conf.objects[name]["object"].initialize()
Sep 18 22:04:46 localhost appdaemon[760]: File "/home/pi/github/appdaemon/conf/apps/motion.py", line 13, in initialize
Sep 18 22:04:46 localhost appdaemon[760]: self.manager = Manager()
Sep 18 22:04:46 localhost appdaemon[760]: File "/usr/local/lib/python3.4/dist-packages/systemd_dbus/manager.py", line 42, in __init__
Sep 18 22:04:46 localhost appdaemon[760]: self.subscribe()
Sep 18 22:04:46 localhost appdaemon[760]: systemd_dbus.exceptions.SystemdError: AlreadySubscribed(Client is already subscribed.)
Sep 18 22:04:46 localhost appdaemon[760]: 2017-09-18 22:04:46.790218 WARNING ------------------------------------------------------------
Sep 18 22:04:46 localhost appdaemon[760]: 2017-09-18 22:04:46.793625 INFO App initialization complete
Sep 18 22:04:47 localhost appdaemon[760]: 2017-09-18 22:04:47.521643 INFO Connected to Home Assistant 0.53.1
Sep 18 22:04:47 localhost appdaemon[760]: 2017-09-18 22:04:47.735995 WARNING Scheduler clock skew detected - delta = 3.4630050659179688 - resetting
Does anyone can help me on this ? Thx a lot.
