I reverse engineered the FX4100’s status page json-rpc and made a sensor configuration for your configuration.yaml and I provde an example entity card that uses template-entity-row for the connection tech field.
Here is the configuration.yaml addition:
rest:
- scan_interval: 5
method: POST
verify_ssl: false
payload: '[{"jsonrpc":"2.0","id":1,"method":"call","params":["00000000000000000000000000000000","sysinterface.ui","get_status_bar_data",{}]},{"jsonrpc":"2.0","id":1,"method":"call","params":["00000000000000000000000000000000","sysinterface.ui","get_lp_device_info",{}]},{"jsonrpc":"2.0","id":1,"method":"call","params":["00000000000000000000000000000000","sysinterface.ui","get_lp_sim_info",{}]},{"jsonrpc":"2.0","id":1,"method":"call","params":["00000000000000000000000000000000","sysinterface.ui","get_lp_settings_info",{}]},{"jsonrpc":"2.0","id":1,"method":"call","params":["00000000000000000000000000000000","sysinterface.datausage","get_interface_data_usage_info",{"sim_slot":1}]},{"jsonrpc":"2.0","id":1,"method":"call","params":["00000000000000000000000000000000","sysinterface.ui","get_lp_wifi_info",{}]},{"jsonrpc":"2.0","id":1,"method":"call","params":["00000000000000000000000000000000","sysinterface.ui","get_basic_info",{}]}]'
resource: https://192.168.1.1/ubus
- name: "tmob_get_status_bar_data"
json_attributes_path: "$[0].result[1]"
value_template: "OK"
json_attributes:
- "status_bar_antenna_status"
- "status_bar_roaming"
- "status_bar_femto"
- "status_bar_traffic_status"
- "status_bar_service_status"
- "status_bar_airplane_mode"
- "status_bar_connection_status"
- "status_bar_ethernet_supported"
- "status_bar_ethernet_enabled"
- name: "tmob_status_bar_data_sim_info"
json_attributes_path: "$[0].result[1].status_bar_sim.info[0]"
json_attributes:
- "carrier_id"
- "slot"
- "status"
- "carrier_lock_status"
- "operator_name"
- "operator_id"
- "bars"
- "technology"
- "icon_type"
- name: "tmob_lp_device_info"
json_attributes_path: "$[1].result[1]"
json_attributes:
- "device_name"
- "imei"
- "imeisv"
- "mac_address"
- "sku"
- "fw_version"
- "pri_version"
- "cute_version"
- "os_version"
- "antenna_status"
- "lan_ip_address"
- "mesh_enabled"
- "nodes"
- "total_devices"
- "wifi_devices"
- "ethernet_devices"
- "usb_devices"
- "blocked_devices"
- "active_wan"
- "eth_wan_state"
- "wwan_wan_state"
- "wan_conn_duration"
- "active_ethernet_port"
- "service_status"
- "connection_status"
- "wan_ip_address"
- "sim_status"
- "tech"
- "roam"
- "operator_name"
- "band"
- "bandwidth"
- name: "tmob_lp_sim_info"
json_attributes_path: "$[2].result[1].sim_info[0]"
json_attributes:
- "slot"
- "imsi"
- "iccid"
- "mdn"
- "tech"
- "roam"
- "sinr"
- "rsrp"
- "rsrq"
- "snr"
- "rssi"
- "pci"
- "operator_name"
- "apn"
- "ecgi"
- "sim_status"
- "service_status"
- name: "tmob_lp_settings_info"
json_attributes_path: "$[3].result[1]"
json_attributes:
- "ippt_enabled"
- "port_foward_enabled"
- "port_filter_enabled"
- "gps_enabled"
- "inseego_connect_enabled"
- name: "tmob_interface_data_usage_info"
json_attributes_path: "$[4].result[1]"
json_attributes:
- "du_available_state"
- "plan_type"
- "cycle_start_date"
- "cycle_end_date"
- "usage_timestamp"
- "plan_limit"
- "line_usage"
- "shared_usage"
- "tx_bytes"
- "rx_bytes"
- "plan_limit_bytes"
- "tx"
- "rx"
- "unit"
- "prepay_indicator"
- "mdn"
- "is_data_available"
- name: "tmob_lp_wifi_info"
json_attributes_path: "$[5].result[1]"
json_attributes:
- "wifi_primary_enabled"
- "wifi_primary_ssid"
- "wifi_primary_password"
- "wifi_guest_enabled"
- "wifi_guest_ssid"
- "wifi_guest_password"
- name: "tmob_basic_info"
json_attributes_path: "$[6].result[1]"
json_attributes:
- "product"
- "user_guide_url"
- "language"
- "date_format"
- "hour_format"
- "numeric_format"
- "model"
And here is an example entity card that hits the important attributes:
type: entities
entities:
- type: attribute
entity: sensor.tmob_basic_info
attribute: model
- type: attribute
entity: sensor.tmob_status_bar_data_sim_info
attribute: bars
suffix: bars
- type: attribute
attribute: operator_name
- type: attribute
attribute: operator_id
- type: attribute
entity: sensor.tmob_interface_data_usage_info
attribute: tx_bytes
suffix: B
- type: attribute
attribute: rx_bytes
suffix: B
- type: attribute
attribute: usage_timestamp
- type: attribute
attribute: mdn
- type: attribute
entity: sensor.tmob_lp_device_info
attribute: fw_version
- type: attribute
attribute: pri_version
- type: attribute
attribute: cute_version
- type: attribute
attribute: os_version
- type: attribute
attribute: total_devices
- type: attribute
attribute: mac_address
- type: attribute
attribute: lan_ip_address
- type: attribute
attribute: wan_ip_address
- type: attribute
attribute: wwan_wan_state
- type: attribute
attribute: wan_conn_duration
suffix: s
- type: attribute
attribute: sim_status
- type: attribute
attribute: service_status
- type: attribute
attribute: connection_status
- type: attribute
attribute: tech
- type: custom:template-entity-row
state: >-
{% set st = state_attr("sensor.tmob_lp_device_info","tech") %} {% set sm =
{0:"None",1:"Wi-Fi",2:"GPRS",3:"1XRTT",4:"EVDO
REV0",5:"UMTS",6:"HSDPA",7:"EDGE",8:"EVDO
REV0",9:"HSUPA",10:"HSPA+",11:"4G LTE",12:"4G LTE+",17:"5G"} %} {{
sm.get(st, "Unknown") }}
- type: attribute
attribute: band
- type: attribute
attribute: bandwidth
- type: attribute
attribute: antenna_status
- type: attribute
attribute: roam
- type: attribute
entity: sensor.tmob_lp_settings_info
attribute: port_foward_enabled
- type: attribute
entity: sensor.tmob_lp_sim_info
attribute: imsi
- type: attribute
attribute: iccid
- type: attribute
attribute: sinr
- type: attribute
attribute: rsrp
suffix: dB
- type: attribute
attribute: rsrq
suffix: dB
- type: attribute
attribute: snr
suffix: dB
- type: attribute
attribute: rssi
- type: attribute
attribute: pci
- type: attribute
attribute: apn
- type: attribute
attribute: ecgi
- type: attribute
entity: sensor.tmob_lp_wifi_info
attribute: wifi_primary_ssid
I hope this helps anybody who would like to see the same data that comes from the status page and updates every five seconds to that page, but going to home assistant. This is actually more performant since their page requests each of these rpc endpoints with separate rest calls. I just do one rest call with all rpc-json endpoints in the same post data and have the sensor response pull out the dictionaries and make attributes where each entity has a major dictionary list in the json reply.
Works with firmware 1.071.1.6. They may change these values in the future.
