The last year I have been playing around with a couple of DIY projects to implement into Home Assistant. Just thought I could share the projects with you, in case it could be for inspiration or something.
The projects are not at all professionally made, but they work for their purposes and is basically good enough in most cases. That said there is room for a lot of improvements, and I would love to see you do so!
I have not had the time to write some detailed instructions, but the repos will suffice for showing of the ideas and partly show how I did it.
The roller blind is probably my favorite. There’s something magical when the roller blind just goes up along with your alarm and down when you get in bed.
Again I’m sorry for not coming back at you. Just been busy with work and other stuff as of late. Was looking at it for a couple of minutes yesterday, and saw that I got the same error as you if my board upload settings were incorrect. Could this be tha cause for you too? When I changed the upload settings, the errors disappeared.
