Tado: Add Bridge Mac Addr as Device Identifier
Home Assistant has the ability to merge devices with the same identifiers.
I would be nice if the integration would use the bridges mac address as device identifier.
See Device registry | Home Assistant Developer Docs
Would that not merge all devices into one?
And what if the bridge host several devices or the same type, so you end up with 10 temperature sensors with the same name under one device?
