i´m trying to turn off my Tado Thermostats when the Window Sensor reports open and back on when closed again.
I tried this via GUI and set a trigger for opening the window. As action i defined run service “climate.set_operation_mode”
Data: operation_mode: “Off” (Like I read this multiple times in the forum)
The trigger is working but the Thermostat is not off. Any hint what i´m doing wrong?
Ok figured this out by myself.
Due to the changed climate component “operation_mode” is not valid anymore.
Instead i´m using hvac_mode: ‘off’ and hvac_mode: auto with climate.set_hvac_mode.
I am new to HA and am trying my first automation.
I also want to turn off my Tado heating thermostats when Tado detects an open window and turn the thermostat back on when the sensor detects closed again.
I also want to get a message on my iPhone, door open or door closed.
I have already made the automation via the web interface and when I start the automation with the iPhone for testing, it also works.
Only when the sensor detects the open window, the automation is not started.
Can anyone tell me what my error is?
It looks like this:
Thanks for your help and snowy greatings from the allgäu
