I’ve tried to add the tado component to connect to my tado thermostat.
CHECK CONFIG
Error loading /config/configuration.yaml: while parsing a block mapping in “/config/configuration.yaml”, line 1, >column 1 expected <block end>, but found ‘<block mapping start>’ in “/config/configuration.yaml”, >line 97, column 2
# Example configuration.yaml entry
tado:
username: YOUR_USERNAME
password: YOUR_PASSWORD
this looks pretty simple. I cant see whats wrong here?
