Ive set up TADO in HA and I can see temperatures and humidity and everything else but one thing I would like to do is change to Away mode when I and my wife leave the house and nobody is in. This is a feature of their new subscription but I dont subscribe, so was wanting to do this via HA and Automation and or with Node Red if necessary.
I have 2 Thermostats, extention kit amd bridge TADO set up. Has anyone done this with V3+ ?
One thing I cant do also now that its all paired up is use the Intergration HA that seemed to happen when I first turned on on my old HA set up.
I think this shouldn’t be too hard to get done, I’m fairly new to HA and sadly no clue yet. I’m hoping someone would read this and help.
The PyTado that is included (AFAIK) in HA has these methods available:
Someone explained the API and has an (kind off) integration according to the screenshot. https://wirres.net/article/articleview/11348/1/6/ The page is in German, However the API calls are clear, else I suggest Google Translate.
I manage to make an automation, and can change the value manually, but in 2 seconds, value return to last value. It seems like i can’t change the value in cloud server : (
Same request, it will be usefull to switch from home to away mode without doing it manually in the app, also because in my family due to battery drain 1 phone as not gps tracking activated on tado app and also without subscription it would be fine to have this sensor switch from home to away, but if it a rule from tado in order to subscribe to their sercices maybe this thing is not possible?
