I am new Home Assistant user. I have successfully added Xiaomi gateway to configuration file and it worked flawlessly. However, when I add the following lines to my configuration file the frontend crashes (“Refused to connect” error):
Example configuration.yaml entry
tado:
username: YOUR_USERNAME (I am adding my email here)
password: YOUR_PASSWORD (I am adding my password here)
Can you help me out what I am doing wrong?
Thank you!
Update: Apparently it happened due to symbols in my credentials.
Please read the blue box on top of the topic. It explains how to post your configuration, it’s important as the syntax of configuration files is essential.
