Hi
I have a small ESP32 panel at home which I am trying to configure to do lots of things - and so far it has been pretty good.
I can get it to read the room temps, which it displays, alongside the state (heat or not) by way of changing an icon colour.
I can get it to run the tado.set_water_heater_timer or tado.set_climate_timer quite nicely by pressing a button on the LVGL display.
what I cant do is work out how to set the TRVs back to ‘auto’ mode(ie following the pre-set schedule) or even turn it off - i cant see how this fits into the tado services.
I got an AC in one of the bedrooms, in that bedroom I also got a Tado controlling the radiator. When the AC starts cooling I shut down the tado, otherwise the tado thinks its too cold and starts heating.
So what I do is, when the AC starts I shut down the tado and when the room hits the desired temp it stops the AC and switch the Tado back to Auto.
alias: Deactivate AC in bedroom when target temperature has been reached
description: ""
mode: single
triggers:
- entity_id: climate.airco
attribute: current_temperature
below: 20
trigger: numeric_state
conditions:
- condition: state
state: cool
actions:
- data: {}
entity_id:
- climate.airco
action: climate.turn_off
- data:
hvac_mode: auto
entity_id: climate.tado_bedroom
action: climate.set_hvac_mode
