I’m getting an error the moment I want to enable the Tado Hub Component in my configuration.yaml
The following components and platforms could not be set up:
tado
Please check your config
Additonal error log:
Sat Mar 03 2018 12:26:23 GMT+0100 (CET)
Error during setup of component tado
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/urllib/request.py", line 1318, in do_open
encode_chunked=req.has_header('Transfer-encoding'))
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/http/client.py", line 1239, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/http/client.py", line 1285, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/http/client.py", line 1234, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/http/client.py", line 1026, in _send_output
self.send(msg)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/http/client.py", line 964, in send
self.connect()
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/http/client.py", line 1400, in connect
server_hostname=server_hostname)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/ssl.py", line 407, in wrap_socket
_context=self, _session=session)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/ssl.py", line 814, in __init__
self.do_handshake()
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/ssl.py", line 1068, in do_handshake
self._sslobj.do_handshake()
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/ssl.py", line 689, in do_handshake
ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:777)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/setup.py", line 148, in _async_setup_component
component.setup, hass, processed_config)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/futures.py", line 327, in __iter__
yield self # This tells Task to wait for completion.
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
future.result()
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/futures.py", line 243, in result
raise self._exception
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/components/tado.py", line 47, in setup
tado = Tado(username, password)
File "/Users/administrator/.homeassistant/deps/lib/python/site-packages/PyTado/interface.py", line 292, in __init__
self._loginV2(username, password)
File "/Users/administrator/.homeassistant/deps/lib/python/site-packages/PyTado/interface.py", line 154, in _loginV2
response = self.opener.open(req)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/urllib/request.py", line 526, in open
response = self._open(req, data)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/urllib/request.py", line 544, in _open
'_open', req)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/urllib/request.py", line 504, in _call_chain
result = func(*args)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/urllib/request.py", line 1361, in https_open
context=self._context, check_hostname=self._check_hostname)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/urllib/request.py", line 1320, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:777)>
For information purposes, I’m running Home Assistant on macOS High Sierra. I know the username/password combination is correct as the Tado device tracker component (using the same username/password) is working fine.
Any ideas on how to solve this?
